This thread is privately moderated by iflytailies, who may elect to delete unwanted replies.
Old Dec 03, 2011, 07:32 PM
iflytailies is offline
Find More Posts by iflytailies
Trader Rating: 94
aka Schleppmeister
PA
Joined Feb 2006
Trader Rating: 94
Sold
Wing Retainer System & Wing Lock Set
A) Wing Lock Set F-115. Wings will lock in place by using the snap fasteners. No tool needed to lock wings. Includes one set (see picture). Made in Europe. This set is very similar to the Multiplex lock set, which are no longer being made.
$10 shipped
B) Wing retainer System F-116: Self locking system for wings. Suited for fuselage widths between 60mm/2.36in. and 110mm/4.33in. Holding power may be adjusted by using different spring washers. The screw nuts need to be glued into the wing. The couplings will be screwed in and adjusted to fuselage width.
$13 shipped
iflytailies is offline Find More Posts by iflytailies
Old Dec 03, 2011, 08:17 PM
cpdude is offline
Find More Posts by cpdude
Trader Rating: 26
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Trader Rating: 26
Hey Alex,
I'd like to get your opinion on how well the F-115s would work on my big Horten IIIe. I was planning too use Multiplex Multi-locks but like you said they are getting pretty hard to find. Anyway, I'm not sure that pushing the wing slightly toward the tail will work on the Horten. And no I'm not tring to be funny. The root rib cord is about 25 inches and I'm using a 1 1/2" diameter wing joiner tube some shouldn't get much flexing.
So do you think these will work?
Brian
cpdude is offline Find More Posts by cpdude
Old Dec 03, 2011, 08:41 PM
Trader Rating: 94
aka Schleppmeister
PA
Joined Feb 2006
Trader Rating: 94
They use those on 4m and bigger sailplanes. Therefore, the F-115 should work on your 4.1m, too. To separate your wings, you could either have one person pull on each wing. Or make wedges to help you separate the wings.
Another hint: dry fit the F-115 parts. If you think the friction is too strong then carefully sand just a tiny bit off the collars at a time till you are happy with the friction.
If you have an access hatch, an even better option would be to use "Wing Retainer Systems F-101":
http://www.iflytailies.com/store/win...ainer-systems/
Discussion Any tips for a shoulder mount wing retainer besides tape? hog2soar Sailplane Talk 27 Oct 30, 2011 08:36 PM
For Sale Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 0 May 28, 2011 01:17 PM
Sold Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 0 Mar 31, 2011 11:27 PM
Sold Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 0 Feb 14, 2011 09:37 PM
Sold Graupner Wing Retainer System iflytailies Aircraft - Sailplanes (FS/W) 4 Dec 12, 2010 02:17 PM
