Old Dec 03, 2011, 02:10 PM
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Noob question about ESC/Motor connection
I just bought 4 turnigy plush 12 amp ESC's and 4 Keda 1050KV Brushless Motor (Hacker Style) motors for a quad. Both have 3 black wires coming out of each with no connectors, and I'm about to solder on some 3.5mm bullet connectors. On my other quad (Gaui) there are three colors, two of which I had to reverse certain colors to get the motors to counter rotate. The other motor (Pulso) I have on my other plane also has color coded wires.
Does it matter at all which wires on the motor connect to which wires on the ESC? There is nothing in the instructions helping me differentiate which wire does what. I was thinking I'd color code them with the shrink tube so I can at least tell which one is which, or is this a waste of time and as long as my motor spins the direction I want I'm ok?
Glenstr is online now Find More Posts by Glenstr
Old Dec 03, 2011, 02:13 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
It does not matter.
If you connect it up and the motor spins the wrong way (50/50 chance it will ) then simply swap any two of the connections between the ESC and the motor and it will run the other way.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 03, 2011, 02:20 PM
Glenstr's Avatar
Joined Aug 2010
Originally Posted by pmackenzie View Post
It does not matter.
Pat MacKenzie
Ok, thanks for the prompt answer! Out of curiousity, why are some motors equipped with colored wires then, and when I put together my Gaui is was specific about swapping x color with y color on two of the motors, when in fact swapping any two would have done? (this was the reason I was wondering)
Old Dec 03, 2011, 02:51 PM
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
They do it solely to be confusing to noobs.
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Dec 03, 2011, 03:04 PM
Glenstr's Avatar
Joined Aug 2010
They succeeded then..
Old Dec 03, 2011, 03:06 PM
pmackenzie's Avatar
Joined Dec 2002
The colours are handy once you know which way they need to be connected in a particular model.
If you disconnect them for service/repairs then you just have to remember if they can match or if you need to swap a pair. And swapping any two will work, not two specific ones.
Old Dec 03, 2011, 06:42 PM
O. C. CA
Joined Jan 2005
They got a really good deal on black wire, the people that solder on the wires could be color blind, and don't know where to solder on colored wire.
H.
himeros is offline Find More Posts by himeros
Discussion Noob Push Motor Question kbrand Beginner Training Area (Aircraft-Electric) 27 Sep 30, 2011 09:19 PM
Help! Noob questions about Rx, ESC and servos hook up CryHavocc Beginner Training Area (Aircraft-Electric) 8 Sep 01, 2011 03:22 PM
Discussion Noob question about connectors pro607 Electric Plane Talk 14 Aug 29, 2011 08:54 AM
Discussion Question about prop/motor connection Xaos Beginner Training Area (Aircraft-Electric) 1 Mar 31, 2009 05:27 PM
