Espritmodel.com Heli Air
Old Dec 03, 2011, 09:42 AM
TAREK.SAADE's Avatar
London-UK
Joined Sep 2007
Burned fat shark 5.8 GHZ Tx 100 mw
I accidently burned my Fat Shark 5.8 GHz TX 100 mw while Trying to provide 12 V to my new FPV Camera,
Anyone has Idea where and how to adjust it?
Cheers
Tarek
TAREK.SAADE is offline Find More Posts by TAREK.SAADE
Old Dec 03, 2011, 05:27 PM
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Cheers
Tarek
Hmmm, according to the manual of this transmitter, it should accept 12 volts. Did you mixed up positive and negative?
It looks like the first cap of an LC low pass filter blew up. I can't read the numbers on the two what seems to be ST linear regulators. If they are linear regulators, chances are they survived. In case it's a switching regulator, you most likely would have to replace that one too.
If you "just" mixed up pos and neg wires, chances are pretty high you get a way by replacing the capacitor alone.
Markus
markus123456 is offline Find More Posts by markus123456
Old Dec 04, 2011, 01:23 AM
London-UK
Joined Sep 2007
Hi, I burned My TX by connecting the out put red wire 5v from TX to 12 VCamera and then Connecting 12 V red wire from 3S Battery to my camera and I totally forget to cut the 5 v wire to the camera!! the result is a Smelly White Magic Smoke!...
the Burned /regulator has code ( 470 7m).
Am not Into Electronic Field and Part but i could replace them if you Help me to find these burned parts.
Thanks In advance
Old Dec 04, 2011, 02:50 PM
Registered FPVer :)
Joined Aug 2006
Thanks In advance
The "Burned regulator" as you call it is an electrolytic capacitor. I'm pretty sure its 470uF and rated for 6.3 volts, but note, I can't be held responsible for this information! If replacing this part with the one I suggest blows up your home or city, or does other harm, that would be entierly your problem!
You could buy one of those (well, a similar rated one that should do) here:
http://search.digikey.com/us/en/prod...9-2-ND/1859876
Or here:
http://ch.mouser.com/ProductDetail/V...Tydue3xwh8w%3d
Note, I asume it's size is 4.3 mm W x 7.3 mm L x 4mm H, if not, you could use those sites to search for a matching one. Unsoldering the blew up one is not that simple for the unexperienced. You thus may try to locate someone with experience doing SMD repairs. The other thing is that replacing this capacitor is not guarnateed to bring your trasmitter back to life, but IMHO chances are at least in tact it would.
HTH
Markus
Old Dec 04, 2011, 03:08 PM
Team White Llama!
gundamnitpete's Avatar
if you want to do it youself, i find a solder sucker is much more easy to use, than a braided peice of copper!
gundamnitpete is offline Find More Posts by gundamnitpete
Old Dec 04, 2011, 03:39 PM
London-UK
Joined Sep 2007
Hi, I contacted customers Service from Fat shark, and they asked me to remove the Burned / regulator and I did. My Tx back To life again and it is working Just fine,
their comments:
Since I am using 12 V camera so no need for that regulator/diode....etc.
Problem Resolved..
Thanks Fat shark- Gregory French
And thanks for Your Help Markus!
Old Dec 04, 2011, 03:40 PM
Team White Llama!
greg's the man! glad it's working for you
Old Dec 04, 2011, 03:41 PM
London-UK
Joined Sep 2007
Thanks & Cheers
Discussion 5.8 ghz 800/600 mw transmitter Pilotlevi Video Piloting (FPV/RPV) 2 Nov 22, 2011 11:59 PM
Sold Fat Shark RCV922+ 5.8GHZ TX/RX Best offer Here! Bamromz FPV/RPV - Equipment and Vehicles (FS/W) 0 Nov 13, 2011 04:38 PM
Discussion Burned 5.8 Ghz 500mWt transmitter from fpvhobby.com kedrikov Video Piloting (FPV/RPV) 11 Oct 13, 2011 07:27 AM
Sold 5.8 ghz setup Camera TX vRX and regulator indycobra FPV/RPV - Equipment and Vehicles (FS/W) 8 Sep 06, 2011 07:15 PM
Discussion 5.8 ghz TX/RX 100 m range. Ghelmet Video Piloting (FPV/RPV) 8 Dec 04, 2009 10:33 AM
