Old Dec 03, 2011, 01:16 AM
Florida Mike's Avatar
United States, FL, Jupiter
Joined May 2011
Which motor/Prop for HobbyKing FPV-UAV Composite 1.66m V2
I would like to stick with 3S or 4S. I am looking for quality and not cost. I have been looking at the following with a 9X7X3 prop in mind:
Pulso 2820/8
2628/8, /10
Cobra C-2820/8, /10, /12, /14
C-2628/8
C-3510/10, /12
Link to plane: http://www.hobbyking.com/hobbyking/s...dProduct=16828
Florida Mike is offline Find More Posts by Florida Mike
Old Dec 07, 2011, 07:01 AM
fpv noob
Stu_D's Avatar
Australia, VIC, Melbourne
Joined Dec 2007
I'm in the same boat . I have just completed my first FPV plane/system and during the process I bought one of the HK Long range 168 to use for my second and more serious equipment .
There are plenty of well described videos on Youtube re this plane so you should find all the info you are looking for .
Stu
Stu_D is offline Find More Posts by Stu_D
Old Dec 07, 2011, 09:37 PM
chancesAU's Avatar
Australia
Joined Apr 2008
The good motors can fail too but I think the quality control from some of the more reputable brands is worth the extra cash.
The way I like to start working it out is by getting the weight / approx weight of the plane then stick with your 9" prop cause you cant go much bigger on the SW.
Then you need to check with the motor specs as to what will give you around 1.5kg thrust with your prop.
On my Skywalker I used a Hyperion 3020-10 motor on 4cell which go for around $100
My ESC was a CastleCreation IceLite 75A which was about the same price as the motor.
Straight up I knew that I would have more than enough power and my ESC should never fail/overheat.
That heavy brick of a plane leaped out of my hand on full throttle!!
chancesAU is offline Find More Posts by chancesAU
Article HobbyKing FPV-UAV Composite 1660mm Electric Airplane ARF Review Michael Heer Video Piloting (FPV/RPV) 12 Jan 06, 2012 03:32 AM
Help! which motor for 10x4.7 sf prop quad? rcta15 Multirotor Talk 6 Aug 26, 2011 05:25 AM
Discussion HobbyKing FPV / UAV Fiber Glass Kit, looks like SkyWalker Talajouy Video Piloting (FPV/RPV) 3 Feb 04, 2011 07:48 AM
Discussion Which hobbyking brushless outrunner / prop for 2m electric glider dwalk Electric Sailplanes 18 Feb 19, 2010 02:15 PM
