United States, WI, Fond du Lac
Joined Sep 2008
Got a few more flights in today. Increased flaps to 25 degrees, upped the rates a bit, tested the retracts. Starts to get slightly pitchy with the gear up so the CG is about as far back as it can be. Cruises well at about 2/3 throttle.
Slows down nicely with full flaps and can maintain altitude at about 1/3 throttle with flaps down. Curiously, no elevator correction needed with flaps. Pretty good aileron authority at slow speeds but it was really calm today. Not sure how well it would do in turbulence. Sure wish I'd had this CG and settings on the first maiden! Live and learn. |
Just discovered this thread (after having found an interest in the Beech 18 by accident - spotted a free plan by designer Cyril Carr in the British magazine RCM&E).
What an inspirational story your build-log is pmullen503. Loads of great building tips and techniques, and an admirable demonstration of persistence in ironing out the wrinkles when the maiden proved to be a harsh lesson. Really very good mate, one of the best threads I've ever seen on RCGroups - thanks for sharing it all and give yourself a beer!
Joined Sep 2008
Thanks yarrumevets and Steve,
The Beech wasn't my first scratchbuild to have a troubled maiden and it won't be the last! It is especially satisfying when you start with a three view and end up with a model that flies well; however bumpy the road was to get there. |
Jumping in.
Pat, I love your videos!
I can totally relate to how you feel before the flight. I am the same way- pulse is pounding in my head and butterflies are flying in my stomach. Your re-maiden was great! Yes, the landing wasn't great- I would be saying the same to myself. Did it sink faster than you anticipated on the approach?Bob |
Joined Sep 2008
The D-18 is pretty much dialed in now. Just have to reset the linkages mechanically to match the limits I now have programmed in the TX. I'll do that when I finish painting it. It's low speed handling is good, flaps are set up so that I still have aileron authority at full flaps. Tip stall is a non-issue at that speed. Elevator trim didn't change much at all at full flaps either. I'll tell ya, damn thing sure is durable! This is the second plane I've done with kraft paper over foam (DO-335 was the first) and it really takes a beating. Someday, I'll join the local club to access their really nice field but it's so convenient to walk out your back door and fly. |
My feelings exactly.
Pat, I have a soccer/lacrosse field down the street, but I would rarely fly there as there are simply too many houses/trees/children/dogs/joggers/walkers/yada yada.
I work on the local Army base, so the parade field over there is usually good- except when the cheap-skate golfers go there to use it as an unauthorized driving range. I can't really do anything as flying is not specifically permitted either, but the police don't really do anything unless you're speeding. Anyway, back on topic the Beechbaby looks great and now that you have a handle on its flight characteristics I will bet you are really enjoying it.![]() Bob |
| Thread Tools | |
| Discussion Fun Build 5 (?) Design - 51" Span Lancaster in Pink Foam or (gasp!) Depron | Steve85 | Scale Electric Planes | 22 | Oct 27, 2011 05:06 AM |
| Discussion Fun Build 4 - Guillows 18" British SE5, Kit WW-5, with Aero-Werks parts | MPP | Scale Electric Planes | 302 | Jun 27, 2011 03:59 PM |
| Wanted Pricing for a Ziroli Full Kit Beechcraft D-18 / C-45 Expeditor | 4075aaron | Aircraft - Fuel - Airplanes (FS/W) | 3 | May 06, 2011 09:26 AM |
| For Sale Beechcraft D-18 Ziroli Kit and More | pilotdoug | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jan 04, 2011 08:33 PM |
