Old Feb 26, 2012, 07:57 PM
pmullen503 is online now
Find More Posts by pmullen503
United States, WI, Fond du Lac
Joined Sep 2008
Thanks, guitar strings would work!
pmullen503 is online now Find More Posts by pmullen503
Old Mar 13, 2012, 08:27 PM
Joined Sep 2008
Finally got the gear door mechanism sorted out. The door's hinge pin, which is also the opening spring, was made from .009" steel guitar string (thanks for the suggestion Jeff).
The closing mechanism while simple enough, took a lot of fooling around to get the geometry correct. I had hoped to use a simple cable between the doors that closed when the gear leg pulled the cable down. But the half exposed wheels meant that the gear leg is too close to the doors to pull a simple cable enough to close the doors.
The two curved arms are pushed down by the gear leg as it retracts. The arms in turn pull the doors closed.
Old Mar 24, 2012, 08:33 PM
Joined Sep 2008
Sprayed some paint on the fuselage today. Canopy and cabin windows came out pretty good.
Old Mar 24, 2012, 09:09 PM
redlite is offline
Find More Posts by redlite
Build'm,Fly'm,Crash'm
redlite's Avatar
Sacramento CA
Joined Oct 2009
I agree, pretty good...along with the rest of your model. No painting here for the next week due to much needed rain.
Joe
redlite is offline Find More Posts by redlite
Old Mar 25, 2012, 07:57 PM
Joined Sep 2008
Joe
Thanks Joe.
Looks crude to me next to your trimotor!
Pat
Old Apr 04, 2012, 05:04 PM
Joined Sep 2008
Finishing up the wing. Instead of cutting the ailerons and flaps separately from the complete wing I did the TE in one piece at a 45 degree angle so it acts like an additional spar. It works for the flaps but I needed to close up the gap on the underside of the wing for the ailerons. I fretted for a while about how to accurately cut the tapered, triangular shaped piece.
Then I realized I could just glue on a rectangular piece of balsa and plane the excess flush with the bottom of the wing.
Ailerons and flaps are built up and sheeted with 1/32" balsa. Still have to seal, fill and install the hinges and control horns.
Old Apr 04, 2012, 07:37 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Looking great, not too far off now!
Cheers
Craig
trumps is offline Find More Posts by trumps
Old May 05, 2012, 12:26 PM
Joined Sep 2008
Got the control surfaces installed on the wings. I sanded and primed the wing to see how well the nacelles blend in and it's OK. Not entirely happy with the cowl shape so I might tweek the mold and pull another set.
I'm super busy with work and will be for the next month or so. I hate to have to slow down when I'm getting close to the end!
Old May 05, 2012, 01:20 PM
redlite is offline
redlite's Avatar
Sacramento CA
Joined Oct 2009
Awesome model, Pat, you're doing justice to this rarely modeled subject. A very interesting build with your methods, thanks for the open approach, gives us all more options on our projects.
Joe
Old May 06, 2012, 10:33 PM
Lexta is offline
Find More Posts by Lexta
Lexta's Avatar
Victoria BC Canada
I have been waiting for an update and it looks superb.
Lexta is offline Find More Posts by Lexta
Old Jun 25, 2012, 09:28 PM
Joined Sep 2008
I'm working hard to maiden before the deadline. To that end, I decided to maiden in the next day or two (calm winds forecast!) and not rush to get the paint done. The wings have a single coat of yellow. The bottom half of the fuse will also get painted yellow when I get fillets and the tail cone done.
Lot's of other stuff to do: tail cone, rudder linkage fairings, cockpit, wing fillets, etc. etc. But it's flyable as is.
Did run into a bit a problem with the gear doors. The springs that hold them open and the stops are not adequate when the motors are running. The doors are flapping around a bit and the closer linkage just isn't working right. I need better solution with positive stops at both ends and no slop. I may just hot glue the doors open for the maiden.
Still have to sort out the CG. Two 3s 1800 mAh batteries will balance it but it'll need some surgery to fit. I may just go with a single 2200 mAh and some nose weight.
Old Jun 25, 2012, 09:54 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
She's looking great!
warhead_71 is offline Find More Posts by warhead_71
Old Jun 25, 2012, 10:59 PM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
She's gorgeous, Pat. Good luck on the maiden!
Steve
Steve85 is online now Find More Posts by Steve85
Old Jun 25, 2012, 11:57 PM
Jeanskydive is offline
Find More Posts by Jeanskydive
Jeanskydive's Avatar
Canada, QC, Saint-Jean-sur-Richelieu
Joined Mar 2009
Beechcraft 18
Verry nice work and verry scale like with three blade props just like the one I fly , awesome . Cheers
Jeanskydive is offline Find More Posts by Jeanskydive
Old Jun 26, 2012, 01:12 AM
redlite is offline
redlite's Avatar
Sacramento CA
Joined Oct 2009
Beautiful lines, awesome effort...good luck on the maiden!
Joe
Build Log Fun Build 4 - Guillows 18" British SE5, Kit WW-5, with Aero-Werks parts MPP Scale Kit/Scratch Built 303 Jan 05, 2016 03:56 PM
Discussion Fun Build 5 (?) Design - 51" Span Lancaster in Pink Foam or (gasp!) Depron Steve85 Scale Kit/Scratch Built 22 Oct 27, 2011 06:06 AM
Wanted Pricing for a Ziroli Full Kit Beechcraft D-18 / C-45 Expeditor 4075aaron Aircraft - Fuel - Airplanes (FS/W) 3 May 06, 2011 10:26 AM
For Sale Beechcraft D-18 Ziroli Kit and More pilotdoug Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2011 09:33 PM
