Old Dec 02, 2011, 06:01 AM
Jennik is offline
Find More Posts by Jennik
Jennik's Avatar
Czech Republic, Prague
Joined Sep 2009
Build Log
Vintage Sparky electric conversion
Hi guys.
Before I have completely finished my rubber motor Sparky model and saw it flying (even without the fuselage covered), I realised I just can't resist to try to convert it for radio control, thus electric powered.
The thing is, I don't know what engine/prop would be best to use.
It must be very light as the model now has about 75 grams now (!) even though it's 103cm wingspan. Counting in the covering tissue and some construction strengthening and control surfaces modifications I guess the weight without equipment shouldn't exceed 100 grams.
Sparky would really look nice with a larger propeller, possibly 8-10'' so it seems it would need motor with gearbox to pull such prop.
I'm decided to buy all the equipment on hobbyking shop as I found theirs stuff is good price/performance/quality ratio and low shipping cost. So if anyone would be so kind to suggest the equipment it would be much appreciated, thanks!
Model specs:
Wingspan: 103 cm / 41 inch
Weight w/o equipment: appx. 80-100 grams / 3-3.5 ounce
Desired prop diameter: 20-24 cm / 8-10 inch
Desired maximum motor diameter: 2.8 cm / 1.1 inch
Desired motor mount: behind firewall (inside)
Jennik is offline Find More Posts by Jennik
Old Dec 02, 2011, 12:44 PM
Stantheman is offline
Find More Posts by Stantheman
Stantheman
LaGrange, Ky.
Joined May 2004
I don't have a recommendation for the plane....but that picture of your daughter holding it is priceless! Make yourself some copies and put them away so that you can preserve the memory. They grow up so fast........
Stantheman is offline Find More Posts by Stantheman
Old Nov 28, 2014, 09:58 AM
Jennik is offline
Jennik's Avatar
Joined Sep 2009
I just found this thread of mine realizing I didn't updated it for a "little while" (3 years)
So, for anyone still interested, I finished the model successfully with the rubber motor and actually flew it briefly. Well, it rather glided only. I didn't glued the rudder and elevator permanently as I planned conversion to electric flight. I was also afraid that full unguided flight was too risky and the model would have easily get damaged.
Then I started the conversion. Put two servos inside, the receiver and battery and ESC. But I struggled with the electric motor. The firewall turned out to be very fragile and small to safely support engine weight, vibrations and torque.
Finally, lot of changes in my personal and professional life had changed as well and I had to put my models aside for a while.
So, the recent status is: well, stand by... The model is lying in a box and waiting for it's big day. Hopefully, it's coming next summer
I have attached some pictures illustrating the progress done so far.
Old Nov 28, 2014, 06:39 PM
Bruno Stachel is offline
Find More Posts by Bruno Stachel
Bruno Stachel's Avatar
Edgewood, KY (Cincinnati)
Joined Jan 2004
That's a beautiful model Jennik. Great pictures.
Bob Holman Plans sells a 41" RC version of the Sparky. (A short kit.) I had one, but never got around to building it. I wish I hadn't sold it now.
Subscribed and standing by.
Bruno Stachel is offline Find More Posts by Bruno Stachel
Old Nov 28, 2014, 07:11 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
BHOFM is offline Find More Posts by BHOFM
Old Nov 29, 2014, 04:09 AM
jonquinn is online now
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
Pat Tritle has a Sparky kit although his model has a 55" ws.
Here is the thread
http://www.rcgroups.com/forums/showthread.php?t=1024923
jonquinn is online now Find More Posts by jonquinn
Old Dec 04, 2014, 06:50 AM
Jennik is offline
Jennik's Avatar
Joined Sep 2009
This is really nice picture! How old is it?
Old Dec 04, 2014, 09:12 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
If you are referring to my post, 1955.
I was helping Mom at the church rummage sale and found the camera, bought it for
a nickle, it had film in it, went home and took the picture. Thirty five cents to have
it developed. This was the beginning of a fifty year career as a freelance photographer.
The camera looked like this;
Old Dec 04, 2014, 01:31 PM
failboat is offline
Find More Posts by failboat
yank and bank!!
Joined May 2013
Realistically, at the very least the nose area is going to have to strengthened to accommodate the motor.
Honestly, with a 40" wingspan I would sheet the front half of the fuselage with 1/16" balsa for rigidity and to contain the battery and esc.... but that's just me.
failboat is offline Find More Posts by failboat
Old Dec 08, 2014, 03:02 PM
Jennik is offline
Jennik's Avatar
Joined Sep 2009
I have used very thick paper as a cover and it's quite firm and resistant on most places. The most weakest part is the place where you place your thumb and index fingers while throwing the airplane into the air. I plan to strengthen this one as well.
For the motor, there just wasn't much place to attach it to. So I think I'm going to cut the first two formers, then glue a plywood firewall to them and attach the motor from the front. I know, It's not very elegant idea, but as I mentioned, I want it fly one day - so I must do compromises.
Old Dec 08, 2014, 03:22 PM
Jennik is offline
Jennik's Avatar
Joined Sep 2009
Wow! I used to be photographer as well, even studied it. My first camera given by my father was this one. That's why I always incline to B&W and square format. Perhaps, my story just happened a couple of years later then yours, because this camera of mine, made in late fifties, was already antique when I got her in middle 90s
Old Dec 08, 2014, 11:29 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
I know we are getting a bit off topic here?? I followed the F1 cars for several years. (17)
When I moved in 1999 six boxes of pictures and negatives were either taken from the apartment
or truck and forty years of work was gone. twenty years of racing history.
Old Dec 09, 2014, 03:06 AM
Jennik is offline
Jennik's Avatar
Joined Sep 2009
I don't mind being slightly off topic for the moment Once I make some progress on Sparky I'll bring the topic back on tracks
Nonetheless, that story of yours is pretty sad... That's one of advantages of digital photography: easy to backup. I myself have thousand plus negatives and can't imagine loosing them... What are you doing these days?
Old Dec 09, 2014, 04:13 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
This was pre digital. 35mm, 2 1/4X2 1/4 and 5X7. I retired from the photography game in 1997.
Worked as an OSHA inspector for several years and then as a part time teacher, custodian and
retired for good in 2008. Now I ride bicycles, build, fly RC and row and sail. I did work with the
team that did the graphics for the History Channel show Dogfights. Still have all the software
and flightsim.
Old Dec 09, 2014, 08:59 AM
Jennik is offline
Jennik's Avatar
Joined Sep 2009
and flightsim.
Nice to meet such a veteran of everything I like as well I spent some time with games when working in Bohemia Interactive for 6 years. ARMA series, Take On Helicopter and other games. Wonderful job it was, really. But one day, I had to move on.
Used to play simulators a lot, even as a "virtual airline" pilot. But once I tried airplanes for real, while training for license as a glider pilot, virtual flying lost some of it's beauty for me, I'm afraid. I even tried helicopter and acrobatic plane. Wonderful.
So, while working hard to save some money for real flights, I'm building these little to stay in touch with the sky...
Build Log Vintage Kalt Baron 28 Electric Conversion AtomicPunk Large Electric Helis 205 Apr 08, 2013 10:00 AM
Off Site Electric Conversion Ready - Vintage Cox Lazy Bee RTF RC Radio Control Airplane ALL American Aircraft - Electric - Airplanes (FS/W) 0 Jul 29, 2010 01:58 PM
Comet Sparky Conversion mlbco Parkflyers 29 Apr 26, 2010 09:32 AM
Discussion Vintage Playboy Senior glow to electric conversion Ercoupe Ed Glow to Electric Conversions 1 Jun 26, 2009 03:57 PM
Discussion Vintage aircraft plans for electric conversion rubber rocket Vintage & Old-Timer Designs 21 Mar 11, 2009 12:18 PM
