Old Sep 28, 2003, 10:42 PM
duganderson is offline
Find More Posts by duganderson
Joined Nov 2002
Can Triton temp. sensor prevent Lipo fires??
I'm considering getting a couple of the new 2 cell Kokam 1500 Lipo batteries but am considered about everything I've heard about Lipo fires.
Does the Triton temperature sensor help prevent fires, or could a fire start before the outside of the pack gets too hot??? The sensor is supposed to shut off the charger if the sensor determines the battery is too hot.
Any other tips for fire prevention?
Thanks, Doug
duganderson is offline Find More Posts by duganderson
Old Sep 29, 2003, 03:25 AM
frederm2002 is offline
Find More Posts by frederm2002
CheapBatteryPacks.com
Beaverton, OR
Joined Dec 2002
I think that is a great question and suprised there is no response.
Surely someone that did some extreme testing would have an opinion on this.
It would seem to me that problems caused by over charging would first result in heat in the cell. but I do not know this first hand.
if that heat, as you suspect, is higher then the cutoff limit then the triton would shut off.
Lets hope we get some more info on this as I am also very interested in knowing. well worth the $15-$20.00 for the probe if it would.
frederm2002 is offline Find More Posts by frederm2002
Old Sep 29, 2003, 07:46 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
Mike, maybe nobody knows. Personally, I wouldn't rely on "automatic" temp. sensing and charger cutoff.
When I used a MAHA Plus charger some months ago, the temp. sensor did not cut off even though some NiMH cells I was charging got too hot, IMO. I can't say how sensitive the Triton's sensor is - I've never used it.
There have been reports of apparently cool LiPo packs "puffing".
So far as I know, there haven't been any reports of apparently cool packs catching fire.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Sep 29, 2003, 08:00 AM
STL.SF is offline
Find More Posts by STL.SF
St Charles Flyer
St Charles, IL
Joined Sep 2002
I could imagine that if the failure mode of the Lipo cells is that they "puff" prior to catching on fire then the temperature probe may never see a hot cell. The gas inside the puffed cell would tend to insulate the outside of the cell.
Does the cell heat prior to "puffing"??? Does anyone know enough about these failure modes?
STL
STL.SF is offline Find More Posts by STL.SF
Old Sep 29, 2003, 08:05 AM
STL.SF is offline
St Charles Flyer
St Charles, IL
Joined Sep 2002
Added Thought
Do the Lipo cells puff before catching fire?
If so, then maybe a fixture that included a microswitch to cutoff charging if the cell expanded would be a means of increasing safety. This could be rather inexpensive to add to existing chargers.
STL
Old Sep 29, 2003, 11:10 AM
dmccoach is offline
Find More Posts by dmccoach
Kutztown, PA
Joined Feb 2001
Guys, I have been thinking along the same lines, and we need to urge the designers to come up with a solution...
The cells definately warm up during overcharge, then they puff, then they get hotter, then they burst and flame... I know I have overcharged one, and caught it just as it "puffed"... It was about 120F at that point.
So I envision a casing that the cells are placed into either at MFG, or Post-MFG by a value-added reseller.
The casing (I have no idea what material) would have thermal AND pressure-sensitive circuitry that could cut the charge voltage to the cells... This would not be the "normal" cut-off for charging, but a circuit-breaker system...
I imaging the charging would have to take place "through" this casing-circuitry.
I wish I was an engineer, I would set to work on it.
Thanks, Dan
dmccoach is offline Find More Posts by dmccoach
Old Sep 30, 2003, 12:01 AM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
Ive tested the temp probe on the triton. even sometimes by accident when i set the cut off temp 10 degrees above ambient in my house to find the charger shut off on me the next day charging outdoors. the temp probe works, and i believe it will keep a lipo from exploding, However, i still wouldnt leave the charger unattended while charging......ever
Dylan
Dylwad is offline Find More Posts by Dylwad
Old Sep 30, 2003, 01:07 AM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
http://www.rcgroups.com/forums/showt...402#post806402
DNA is offline Find More Posts by DNA
Old Mar 04, 2014, 01:41 PM
chuck75 is offline
Find More Posts by chuck75
Georgia
Joined Jun 2007
The potential problem with Lipos is that they can get hot between the inner cells, and still be just a bit warm on the outside.
chuck75 is offline Find More Posts by chuck75
Old Mar 04, 2014, 02:19 PM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Did not notice it was a 10 year old thread....
Zeeb is offline Find More Posts by Zeeb
Old Mar 04, 2014, 02:20 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Bumping a 10+ year old thread might be a record!
I rather suspect that the OP has long moved on from his Triton by now...
mrforsyth is online now Find More Posts by mrforsyth
Old Mar 04, 2014, 02:21 PM
Zeeb is offline
Zeeb's Avatar
Joined Jun 2006
Yep, you'd think I'd learn to look at more than the last post date especially when the subject matter is that old..... lol
Old Jun 23, 2014, 01:57 AM
chuck75 is offline
Georgia
Joined Jun 2007
It's not so much the age of the post, or the mfr of the charger. It has more to do with the usefulness of a temperature sensor. I have a couple of sensors, and due to reasonable charging currents, have never had them show anything significant. Use with NiCads and NMIH batteries can be a totally different story.
Old Jun 23, 2014, 08:14 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
A thickness change trigger wold be much more effective. Lipos do expand slightly on charging but nothing in comparison to the expansion when they are being overcharged.
hoppy is offline Find More Posts by hoppy
Old Aug 25, 2014, 10:53 PM
_nicos is offline
Find More Posts by _nicos
_nicos's Avatar
Australia, ACT, Canberra
Joined Jan 2013
Well, 10 years old or not, I'm now interested in this thread on account of a fire I had at my place last weekend.
I was charging 6x 2s 300mah on a parallel harness... I don't believe they were overcharged and were in good physical shape... it was nasty and could have been SOOOOO much worse. It started with one, then all hell broke loose right in front of my face. Another 5 minutes more and it would have been time to call emergency services.
So I'm into getting a temperature probe that will work with one of these chargers... perhaps this one?
_nicos is offline Find More Posts by _nicos
Sold Triton Charger, Like New w/temp sensor, box and manual. code Aircraft - Electric - Batteries & Chargers (FS/W) 3 Dec 30, 2006 11:53 PM
Sold Triton Charger with temp sensor $70 jbachman Aircraft - Electric - Batteries & Chargers (FS/W) 5 Dec 22, 2006 07:02 PM
Alert Triton temp sensor and lipo fire gfcermak Batteries and Chargers 83 Sep 01, 2004 12:24 PM
Triton charger with Temp. sensor FLYERFRIEND Aircraft - Electric - Airplanes (FS/W) 7 Aug 25, 2004 09:45 AM
FS- Triton charger with temp sensor and CC 20P Etonic Aircraft - Electric - Airplanes (FS/W) 2 Mar 22, 2004 09:46 PM
