Old Dec 02, 2011, 12:00 AM
danpass is offline
Find More Posts by danpass
United States, FL, Miami
Joined Nov 2011
How would you set up control surfaces on a lifting body glider?
Using the X-24a as an example http://upload.wikimedia.org/wikipedi...4A_diagram.png
I'm mostly wondering about speed control. My design will have the rudder. I'm thinking of angling the wings further down for roll control surfaces and using a split rudder as a simple speed brake.
Or I can go with the rudder ... as a rudder lol and upper body flap for a speed brake (but that disrupts flow over the rudder) and then X-24a style rear body flaps for roll control.
I'm looking to minimize weight and control functions.
It only has to stay wings level and autopilot (I'm leaning toward the Ardupilot Mega) itself to preprogrammed coordinates by way of a simple, falling glide.
Does the APM do elevons? If so I believe that would simplify things. And I could hook the throttle control to a split rudder speed brake. No brake='max throttle' and some/all brake='less/no throttle'.
Would a lower body flap (like the shuttle), dropping the nose, increase the horizontal speed component or just the vertical component? Could that be run as a throttle increase by the autopilot?
danpass is offline Find More Posts by danpass
Old Dec 02, 2011, 07:58 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
That thing was designed as a space re-entry vehicle and has nothing to do with a glider. I would be surprised if it's L/D is more than 3:1. In other words, it will drop like a controlled brick.
jkettu is offline Find More Posts by jkettu
Old Dec 02, 2011, 08:07 AM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
Those re-entry vehicles are heavy since they have to be covered in ceramic plates... that's at least something us modelers don't have to deal with. So, if built light enough it probably wouldn't be that bad, but I would not build it as a glider, there are no redeeming glider qualities about it.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Dec 02, 2011, 08:32 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Standard elevon mix on the tail (make sure you can get lots of UP for the flare). Rudders are not especially effective on them.
Your elevator is really going to be your throttle, too (just like a glider). At high alpha you WILL experience a lot of oscillations on roll - just let it rock.
A friend of mine flew the original model that now hangs in the AMA museum.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Dec 02, 2011, 12:45 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
yep, I'd just use elevons or, if mixing is an issue, have the surfaces split with the outer part working as ailerons and the inner as elevators.
As noted by others, the lifting body as a glider will have terrible glide performance. Basically it's about the worst layout it's possible to have for a glider. Unless you plan on re-entering the Earth's atmosphere then there are no redeeming qualities (other than looking cool)
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Dec 02, 2011, 02:40 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
If nothing else, those teach you how to fly high-alpha!
Check out the angle on the pitot probe- I assume it's bent to be horizontal during level flight.
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Dec 02, 2011, 03:18 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
But that one was light enough to fly behind a tow car.
Andy
Site Sponsor
Old Dec 02, 2011, 04:05 PM
danpass is offline
Joined Nov 2011
looking cool is always priority #1
Old Dec 02, 2011, 05:35 PM
herk1 is offline
Find More Posts by herk1
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
This thread might be of some help to you: http://www.rcgroups.com/forums/showthread.php?t=1388037
herk1 is offline Find More Posts by herk1
Discussion Glider / Lifting Body rwaterguy Foamies (Scratchbuilt) 1 Nov 10, 2011 04:44 PM
Discussion How do you set up for "crow/spoilers/reflex" sa-woody Electric Sailplanes 3 Jun 21, 2011 06:03 PM
Question How would you setup an EXI 500 for stability and lifting logicwins Electric Heli Talk 0 Jun 11, 2011 09:11 AM
Question how to set up a JR X9503 Body Box to a DX6I Tetex79 Radios 6 Apr 21, 2011 02:14 PM
Discussion How would YOU set up a 2 day indoor event? lensrc Electric Flight Events 2 Dec 07, 2005 04:29 PM
