Old Feb 15, 2012, 04:08 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Originally Posted by xatled99 View Post
I had a hard time reading the manual too, but it looked like 15mm from the LE. Eyeballing it, this seems pretty far forward to me. Peterperfect said that he had his CG at the servo wires. My plane felt tail heavy when I flew it, so I'm hoping to try a bigger pack this weekend.
Has anyone measured the dimensions of the stock prop?
Did you also balance your plane on the servo wires?
BTW, the stock prop included with the Solo 1500 is the same prop included with the Vector 850 which is also made by Bridgesky, According to Hobby King, that prop is a 5x4..5.
Doubletap is offline Find More Posts by Doubletap
Old Feb 15, 2012, 07:52 PM
xatled99 is offline
Find More Posts by xatled99
xatled99's Avatar
Joined May 2007
I just used the TLAR method for CG... My 1500 mAh pack showed up today, hopefully I'll be able to try it out on Saturday.
edit: with the 1500 mAh pack, CG is maybe 1/4" ahead of the servo wires.
Cool, thanks. APC makes a 5.1x4.5. My prop was way out of balance too, so I just sorted it out with a piece of heli blade balancing tape.
xatled99 is offline Find More Posts by xatled99
Old Feb 17, 2012, 10:53 PM
Peterperfect is offline
Find More Posts by Peterperfect
There's Always a Way
Peterperfect's Avatar
Australia, NSW, Stonehenge
Joined Mar 2008
I balanced mine exactly on the wing servo wires and have no reason to change it.
Slope soaring is a bit of a challenge when gusty.
Thermalling for over an hour still had plenty juice in battery for probably another hour.
Peterperfect is offline Find More Posts by Peterperfect
Old Feb 18, 2012, 01:27 PM
Doubletap's Avatar
Joined Jul 2005
OK! I also plan to use mine for mostly power off soaring, will balance on the servo wires then.
Old Feb 18, 2012, 01:49 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
I just got back from flying. It handled much better with the 1500 than with the 1300. Windy again today, but it did fine. Did a little thermaling and some FPV. Three flights, about 20 minutes apiece. Each took out about half of the pack. Much smoother with the prop balanced. I wonder how a 5x5 folding prop would do.
Old Feb 21, 2012, 12:12 PM
JohnStef is offline
Find More Posts by JohnStef
Joined Nov 2011
Vector 850 - Wing Problems, very unstable
Started new thread in Foamies (kits)
John
JohnStef is offline Find More Posts by JohnStef
Last edited by JohnStef; Feb 21, 2012 at 11:06 PM. Reason: moved post to new thread
Old Feb 21, 2012, 05:56 PM
Doubletap's Avatar
Joined Jul 2005
Don't be rude....start your own thread.
^ ^ ^ ^ Start your own thread in either this forum or in the "Foamies Kits" forum to ask your question you ARE trying to hijack this thread.
Old Feb 26, 2012, 08:45 PM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
The CG for this plane is 45mm from LE. This was confirmed to me by BridgeSky.
ozair is offline Find More Posts by ozair
Old Feb 27, 2012, 12:06 PM
Doubletap's Avatar
Joined Jul 2005
Excellent! Thanks for checking, I knew that the "15mm" printed in the manual couldn't be right.
Old Feb 28, 2012, 03:03 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Does anyone know if bridgesky sells replacement parts for this plane? I'm in need of a new vtail.
Alternatively, if anyone built it up as a conventional tail and doesn't need their vtail parts...
Old Feb 28, 2012, 06:26 PM
Doubletap's Avatar
Joined Jul 2005
I assembled mine with the V-tails also, so have the unused spare horizontal stab, I'd venture that virtually everyone uses the V-tail.
Old Feb 28, 2012, 08:06 PM
xatled99 is offline
xatled99's Avatar
Joined May 2007
I figured it was worth a shot
I crashed while flying FPV and smashed the nose in. I'll have to cut it back, make a new firewall, and laminate a new nose. I'll have to put the conventional tail on.
edit: the ballast slugs are 20g apiece, 40g total. That should let me go from a 1500 mAh pack to a 2200.
Old Mar 01, 2012, 05:46 AM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
If you contact BridgeSky, they will either sell you the part(s) or refer you to a seller nearby. They are very helpfull and if you ask nice enough they may even just send it to you (just praise thier product)
Old Mar 01, 2012, 09:16 AM
xatled99 is offline
xatled99's Avatar
Joined May 2007
Thanks for the suggestion! I contacted them and they responded immediately and seem willing to sell individual parts.
Old Mar 05, 2012, 09:03 AM
xatled99 is offline
xatled99's Avatar
Joined May 2007
I wound up rebuilding the nose with some scrap foam, a couple of CF rods, and some 1/16" plywood. Everything from the canopy magnets forward had to be replaced. It looks like a boat and will probably fly like one, but it will fly again. The bay in the front is now a little roomier; I figured without the 40g of ballast, I could afford to make it a bit bigger. 1800 and 2200 packs are on the way. With the correct CG as mentioned previously, it should balance on the spar.
I took the opportunity to replace all the servos with hxt900s, and reworked the tail with dubro .047 pushrods. They're much stiffer and don't flex like the stock ones did.
I removed some of the stock decals by applying painters tape to them and yanking them off. I'm planning on putting some high visibility stripes on the undersides of the wing with some monokote trim sheets.
New Product Nine Eagles Solo Pro 100D / Solo Maxx 3D Frank_fjs Micro Helis 1873 Jan 17, 2016 01:29 AM
Build Log neRecv - Solo/Solo Pro TX as HID Joystick or PPM simulator controller kile DIY Electronics 51 Jul 09, 2013 06:36 AM
Mini-Review HXT 2730-1500 (~1690Kv) and Turnigy R&B 2730-1500 (~1600Kv) Dr Kiwi Power Systems 73 Mar 07, 2012 05:14 PM
Sold Nine Eagles Solo Pro/SOLO/Free Spirit/BRAVO III Battery Charger palomo Aircraft - Electric - Helis (FS/W) 0 Feb 17, 2010 06:38 PM
