Old Dec 01, 2011, 10:10 PM
Mactadpole is offline
Find More Posts by Mactadpole
San Marcos, TX
Joined Jan 2010
Alert
For Sale: Heavy Lift Y6 Ready-To-Fly w/HoverflyPro FC, Futaba T10 w/2 rx,& cam gimbal
SOLD!
Sorry for the cross-post but I know not everyone knows to look at the classifieds. Thanks!
I am selling my Heavy Lift Y6 to help fund a new project. Originally this copter was a hexa that I converted to a Y6 for redundancy purposes. I rarely fly it because I mainly use my MK X8, the Y6 was a backup I put together. It flys very smooth and is perfect for someone who wants to get their feet wet doing APV with the ability to add a full-size gimbal and landing gear in the future for advanced work. I did attach my Droidworx's extended landing gear with AV130 camera gimbal at one point when it was a hexa and it worked great.
This copter is unique in that it has rubber grommets in the arms that go between the arms and center plates. This technique has worked very well for me at reducing vibrations. I just installed all new grommets for the sale and will include a bag of them for when you want to change them in the future.
It can be flown with 1 or 2 batteries. You just change the orientation of the batteries in the tray to fit 2. Comes with Deans parallel cable to plug in both batteries.
INCLUDES EVERYTHING (frame, fc, transmitter, receiver, etc.) to get flying except lipo battery.
Specs:
  • Weight: 2055g w/o battery
  • Motor-to-motor distance: 673mm (26.5")
  • Flight time (no camera): 4s 4500mah = 7-8 minutes, 2x 4s 4500mah (9000mah total) = tbd, 4s 6000mah = tbd, 2x 4s 6000mah (12000mah total) = tbd (It was super windy today, but will try tomorrow for these times)
Equipment included:
  • 9 ea. - Pulso 2814/22 760kV motors - 6 on the copter have seen less than 4-5 hours of use, 2 have less than 2 hours of use (1 has a little shaft play), and 1 is brand new in box. These are the same as the Pulso U28-M w/o long wires and short shaft.
  • 8 ea. - RCTimer 30A programmable ESC's - 2 spares
  • 1 ea. - Hoverfly Pro Flight Controller V2 (green board) - has a piece of closed cell foam hot glued to board over altitude sensor to reduce wind effect
  • 1 ea. - Power supply filter for board, LC type - modified with 35 volt capacitor for use with 4s batteries
  • 1 ea. - Custom power distribution ring w/ 8 deans connectors - two sets of auxiliary bullet connectors connected to one of the deans (1 set of bullets used to power LED's) and the other is not in use - emits no electromagnetic interference (at least none that I can detect)
  • 1 ea. - Deans parallel battery connector - allows you to connect two batteries in parallel.
  • 4 ea. - G10 custom center plates - 3 on copter, 1 extra. Can be used to make flat hexa
  • 4 ea. - AGL Hobbies motor mounts - these things are heavy duty with no twisting and always square on the square aluminum arms
  • 7 ea. - 1/2" aluminum arms - custom drilled, 3 extras with LED's, 1 extra just drilled
  • 3 ea. - APC 12x3.8 slow flyer propellors - good condition and balanced
  • 3 ea. - APC 12x3.8 slow flyer pusher propellors - good condition and balanced
  • 6 ea. - LED strips for use with 4s batteries - 3 on copter, 3 on extra arms
  • 1 ea. - Lipo alarm
  • 1 ea. - Mikrokopter HiSight III (bridge) 2-axis camera gimbal - works well with HFP board, mounted with 15mm vibration dampeners, roll servo rebuilt recently with new gears
  • 1 ea. - MK FlexLander XL landing gear
  • 1 ea. - Futaba T10CAP transmitter - 2.4ghz 10 channels - comes with original box, manual, battery charger, and neck strap. modified for smooth throttle (no ratchet)
  • 1 ea. - Futaba R6014HS receiver - 14 channels, modified to output buffered RSSI for use with OSD's
  • 1 ea. - Futaba R617FS receiver - 7 channels, extra rx, use it for your fpv practice quad! I currently have this one installed in the copter but will put in the R6014HS when it sells.
  • It will also include all the miscellaneous bits of extra hardware that I have for it. There is quit a bit!
This list does not include miscellaneous items like wire, connectors, hardware, braided wire protector, etc. Most importantly, it does not include the labor and time required to get such a machine flying.
I am asking $1750.00 and I will cover the shipping in the CONUSA. To build this new just the components would cost about $2700.00 US. I have an excellent ebay rating and have completed several transactions through RCGroups with happy buyers. I will sell without HFP FC board for $1450.
It will be totally assembled except for the props and landing gear w/gimbal. Only requires 6 nuts to fasten the landing gear/gimbal plate.
I finally shot a video yesterday from the copter. I had changed the bottom props to APC 13x6.5 thin electrics based on a user’s research in the Hoverfly forum. It had the 12x3.8 slow fliers on top. I was running two nano-tech 4s 4500mah in parallel. I had the gopro set on r3 and was mounted on a custom anti-vib plate I made for it, as well as a 1 ounce fishing weight velcro’d on each side of the camera gimbal plate (see pics added below). This gimbal really isn’t the best for video but it does ok and is excellent for photography. I can add some photos taken with it when this copter was a flat hexa upon request. The board was running the most current firmware (v3.1.458) as of today and the gimbal was plugged into the fc and setup with minimal tuning done. The total flying weight was 3.337kg and I got just over 12 minutes of flying time. There was a steady 4-8 mph breeze. Altitude hold worked well; I did not try auto-leveling but it has worked good too, I just don’t really use it. I wasn't trying to fly smoothly for video, just flying around, hovering, and switching AH off/on while doing gain adjustments.
I mounted the droidworx landing gear with AV130 gimbal to the extra bottom plate. I will try to fly it tomorrow (weather dependent) with 4s 6000 single and 2 in parallel.
It flew superbly (just a little gain adjustment needed at the beginning of flight) and really does fly best with some weight added to it. I look forward to getting some video with gh2 under it.
20111218_Y6 (13 min 4 sec)
Mactadpole is offline Find More Posts by Mactadpole
Last edited by Mactadpole; Dec 27, 2011 at 12:16 PM. Reason: added pics and update info; SOLD!
Old Dec 02, 2011, 07:43 PM
San Marcos, TX
Joined Jan 2010
I've had a few folks ask about selling it without the HFP FC. Without the HFP board I would let it go for $1450. I haven't heard back from them since last night so let me know if interested for it that way.
Shawn
Old Dec 19, 2011, 08:35 AM
San Marcos, TX
Joined Jan 2010
Old Dec 19, 2011, 02:02 PM
San Marcos, TX
Joined Jan 2010
Here are some pics with the Droidworx extended landing gear and AV130 mounted to the extra plate. I included the MK gear and gimbal that come with it for size comparison.
The DW gear and gimbal are not included in the sale.
Old Dec 27, 2011, 12:16 PM
San Marcos, TX
Joined Jan 2010
Sold!
Sold Heavy Lift Y6 Ready-To-Fly w/HoverflyPro FC and Futaba T10 plus much more Mactadpole Aircraft - Electric - Multirotor (FS/W) 6 Dec 19, 2011 02:02 PM
Help! Super heavy lift Y6 prop selection basshead Multirotor Talk 2 Sep 01, 2011 06:42 AM
For Sale Loaded Align TREX 700N w/ SPEKTRUM AR8000, TM1000 Telemetry Ready To Fly + Many Extra wckfthai Aircraft - Electric - Helis (FS/W) 5 Aug 29, 2011 11:49 PM
Help! Y6 AP Heavy lift motor suggestions.. AshFPV Multirotor Talk 109 Aug 11, 2011 06:23 PM
Discussion Heavy Lift Y6 Prop Recommendations nicnaimless Multirotor Talk 4 Jun 24, 2011 02:44 PM
