Old Dec 01, 2011, 01:46 PM
Iboxx83 is offline
Find More Posts by Iboxx83
Joined Mar 2010
Multiplex Funjet in wind tunnel!
Hi everyone,
I spent the afternoon testing a Multiplex Funjet in a wind tunnel at Kingston University (London, UK) since I need this data for my dissertation project: I will be optimizing it for longest range/glide/altitude/climb rate with the help of Arduplane hardware (ardumega, shield, gps and airspeed sensor).
Within a couple of weeks I will be plotting similar curves for different elevator settings, as well as Turnigy 2836 performance (thrust vs current draw at different airspeeds, up to 34 m/s - 122.4 km/h) with APC 5x4.7 prop.
If anyone is into optimisation of this aircraft for long range UAV I'm sure you will find this data interesting, that's why I'm posting.
In a nutshell, this aircraft stalls when AoA reaches about 13 degrees. Best L/D obtained is 4.95 at 10.5 degrees AoA.
Interesting to notice the model was tested up to 128 km/h, thus generating about 8 kg of lift and 1.6 kg drag. The wake generated after reaching stall angle shakes both tail fins violently, I need to trim the video footage which will be on youtube soon.
You can have a look at the chart attached, taken at 20.5 m/s; this is a typical cruise speed for this model - 73.8 km/h or 46.1 mph.
Any suggestions for next tests are welcome!
Emiliano
London
Iboxx83 is offline Find More Posts by Iboxx83
Old Dec 01, 2011, 09:54 PM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
Sounds cool. Do you have a picture of the aircraft?
DPATE is offline Find More Posts by DPATE
Old Dec 02, 2011, 05:20 AM
Iboxx83 is offline
Joined Mar 2010
Just google image "Multiplex Funjet" ;-)
Old Dec 02, 2011, 09:25 AM
yomgui is offline
Find More Posts by yomgui
Joined Feb 2011
Nice!
Do you have ideas of zero lift drag coeff ?
guillame
yomgui is offline Find More Posts by yomgui
Reply With Quote  (Disabled)
Old Dec 02, 2011, 10:07 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Iboxx83,
Very interesting. Your chart shows lift peaking at about 12 degrees. Somewhere (Martin Simon? Selig?) it was shown that lift of a typical airfoil at model sizes (12" chord) developed peak lift at 6 degrees. Your chart does not show appreciable increase in drag with increasing AOA up to 12 degrees. Hmm.
Jim R...
...whose drag is increasing with age...
JRuggiero is offline Find More Posts by JRuggiero
Old Dec 02, 2011, 10:16 AM
Iboxx83 is offline
Joined Mar 2010
Originally Posted by yomgui View Post
Nice!
guillame
Hi Guillame,
at air density obtained at 23C (1.292 kg/m3), Cd at zero lift approximates to 0.1064 (which is mostly skin friction drag)
Old Dec 02, 2011, 10:53 AM
Brandano is online now
Find More Posts by Brandano
Jim, I think you might refer to the optimum Lift/Drag AOA rather than maximum lift angle. 12 degrees seems about right for maximum lift, but drag at this sort of angle should be pretty high already.
Brandano is online now Find More Posts by Brandano
Old Dec 02, 2011, 11:11 AM
Iboxx83 is offline
Joined Mar 2010
Originally Posted by JRuggiero View Post
Iboxx83,
Jim R...
I see where you're coming from, but bear in mind we are not testing an airfoil here, but a whole aircraft instead. That makes the whole picture a little more complicated, it's very hard to predict the exact pattern air molecules are taking on such an "arbitrary" shape. The fuselage itself must be generating some lift as well.
As you mentioned, the increase in drag doesn't seem high, but it makes sense considering that L/D increases going from 0 to 10.5. If L/D increases, it means the increase in drag must be smaller than the increase in lift.
Maximum Cl is normally obtained right before stall, hence if the model stalls about 13 degrees (lift starts to drop and both tail fins shake at this angle), it's reasonable to find maximum lift at approx 10 degrees right?
Old Dec 02, 2011, 11:17 AM
Iboxx83 is offline
Joined Mar 2010
In order to have a noticeable increase in drag and massive drop in lift I think we should go well over stall angle.
Next session I'll plot the curves up to 25 degrees, we'll see
Old Dec 02, 2011, 12:25 PM
yomgui is offline
Joined Feb 2011
Originally Posted by Iboxx83 View Post
Hi Guillame,
all this is very interesting!
But 0,1064 !! that is very high isn't it? half this value would already be high!
Remember this aircraft should be able to reach more than 130 km/h. It's a fast airplane.
My 1/12 Yak-3 has a zero lift Cd estimated around 0,03 to 0,04 (according to wind tunnel thrust data and in flight data).
http://aerotrash.over-blog.com/artic...-90225320.html
Don't be hurt, I'm just trying to help or understand where i may be wrong !
Old Dec 02, 2011, 01:07 PM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
With the quite low aspect ratio of the funjet you don't expect to see the wing stalling at the same alfa as the airfoil does in the 2 dimensional case.
If the airfoil does feature a cl_max at alfa=8, the wing Cl_max may very well be at 10 or even 12.
biber
biber is offline Find More Posts by biber
Old Dec 02, 2011, 01:15 PM
Iboxx83 is offline
Joined Mar 2010
Hey, questions never hurt :-) yours is an interesting point.
I need to find out whether the software that collects the data for this wind tunnel has any kind of calibration that offsets the drag given by the support arms.
I will ask for feedback to my supervisor before the next tests, there might be some kind of flaw which I need to investigate further, thanks for the heads up in the meanwhile
Old Dec 02, 2011, 01:40 PM
yomgui is offline
Joined Feb 2011
Well, I'm not sure ! just find it surprising
Old Dec 02, 2011, 01:47 PM
Capt. Crunch is offline
Find More Posts by Capt. Crunch
It's all fun till Crunch!
Capt. Crunch's Avatar
InSane Diego
Joined Jan 2002
According to Multiplex, this airframe "Blows up" at about 130 MPH, 208kph, so they now make the Ultra FunJet, that should be good to 200MPH, 320 kph.
Keep up the wind tunnel tests, I love them.
Crunch
Capt. Crunch is offline Find More Posts by Capt. Crunch
Old Dec 03, 2011, 05:38 AM
I wonder how you can reliably eliminate the drag from the support arms in the measurement. the drag they produce is not a fixed amount in that setup, they are affected by the model and its AOA. and since they are attached beneath the wing, they are in a higher pressure area where they will produce more drag.
Discussion wind Tunnel Flying Penguins Modeling Science 23 Sep 21, 2012 03:46 PM
Sold Multiplex Funjet NEW IN BOX! craigmel Aircraft - Electric - Airplanes (FS/W) 4 Nov 16, 2011 02:22 PM
Discussion Has anyone attempted to build a wind tunnel to measure drag coefficient of models? MRGTX Foamies (Kits) 1 Sep 27, 2011 09:23 AM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 5 Mar 11, 2011 07:31 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 0 Mar 04, 2011 02:38 AM
