Old Jan 28, 2012, 10:42 AM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Ok guys I got everything hookd up, got it to read on the computer, but in rc calibration first page, I hit rc and it does nothing. but it is reading the sensors and the numbers to the right are moving but the sliders are not. also when I didconect from the pc I cycle the quad, turn it on and I get red for a second then blue on solid. if I switch ch 5 the green comes on and stays on no matter if i flip the switch or not. what am I doing wrong? Help Please...
tc3wins is offline Find More Posts by tc3wins
Old Jan 28, 2012, 10:43 AM
DroneBuilder is offline
Find More Posts by DroneBuilder
United States, TN, Brentwood
Joined Oct 2010
Originally Posted by timecop View Post
is nsfboy one of the devs? if so, request:
how about implementing PPM input? Mode-2 only is ok, roll/pitch/throttle/yaw.
plz make it so ch1 input = PPM (as a setting in groundstation/firmware)
EDIT: I was bored of fighting with sidneyw so I spent a few minutes of my worthless time and cloned FreeFlight. You saw that coming, right?
I kept all the stuff same according to the schematic posted earlier, but made it 36x36mm, dumped gigantic switching reg + caps and added onboard USB and mag (there does seem to exist a mag breakout board for freeflight, so maybe software will come soon)?
Aaaanyways.
Now I can actually put this thing into my quad, I couldn't look at the hideous black PCB.
Originally Posted by JUERGEN_ View Post
The new MWC-Platform?
Ha ha! This is great news! I want one!!
And to Juergen's point - Will your version run your STM port of MWC? Also, will it run CC?
Anyway - I want one!
DroneBuilder is offline Find More Posts by DroneBuilder
Old Jan 28, 2012, 10:51 AM
tc3wins is offline
South Carolina
Joined Mar 2009
Ok got the sliders to move in the program, but still nothing when i try to arm the motors after I dissconnect from the pc, I recycle everything (disconect the battery) and I get solid blue. and if i flip the switch I get green and blue and the green will not go away . and I tried the lock and unlock and nothing, I tried the motor arming and nothing.
Old Jan 28, 2012, 10:53 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
so nice
in light-green
and remove the
- Free Flight Clone -
put MWC-NG here.
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jan 28, 2012, 11:09 AM
tc3wins is offline
South Carolina
Joined Mar 2009
Anyone???
Old Jan 28, 2012, 11:14 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Is your receiver getting power?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 28, 2012, 11:26 AM
tc3wins is offline
South Carolina
Joined Mar 2009
Yep. I am following the instructions. now I am running the firmware that was on the board that it came with. and the pc program is 1.0.7 should I goto 1.0.5 everything is reading and working in the program. I can get the motors to work and all. but when I disconect and recycle power, I get blue light red for 3 flases and a beep. and then just blue light. and I try the calibration nothing happens,. and I try motor start and nothing happens. reciever has light on too.
Old Jan 28, 2012, 11:28 AM
tc3wins is offline
South Carolina
Joined Mar 2009
I am using a futaba radio. should I reverse any of the channels?
Old Jan 28, 2012, 11:29 AM
timecop is offline
Joined Dec 2010
Calibration takes up to 30? seconds. You should not move the board at that time.
Unsure about channel reversing, maybe someone else can help.
Old Jan 28, 2012, 11:34 AM
tc3wins is offline
South Carolina
Joined Mar 2009
also in the program I hit the imu tab, and it looks like it switched from 1.22 to 1.24 least that is what the version says now I am getting confused.
Old Jan 28, 2012, 11:40 AM
tc3wins is offline
South Carolina
Joined Mar 2009
am I suppoesd to pull the 5th channel cable after I calibrate the board?
Old Jan 28, 2012, 12:09 PM
Joined Oct 2010
TC3 - You mention that you are flying 1.24.
Despite it being littered throughout this thread, it took me a while to figure out that if I want to arms the motors (after I loaded v1.24) then you have to pull the sticks to the bottom and opposite corners.
That is, throttle low/yaw left and pitch back/roll right.
Also, did you calibrate all four of your ESC's (individually) to set throttle range?
Lastly, you say that the green LED will not go away. Make sure that you don't have anything going on with Channel 5. That is, either disconnect it physically from the board/RX, or at least make sure it is OFF.
I had a similar problem with Radio Calibration - the GREEN LIGHT would not go away after I switched my GEAR switch back down. The TRICK to making the green light go away is to make sure that the throttle stick is HIGH at the end of the radio calibration process. (Well, it has to be high for calibration of 1.24.)
Needless to say, the 'english manual' could use a little help. In fact, I think I'll edit it. . . . Done. Attached. Good luck.
Old Jan 28, 2012, 12:15 PM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
I just move it to the sixth channel then it becomes my mode change switch.
Its not advisable to leave it connected to the fifth channel.
Ray
whiteturbo is offline Find More Posts by whiteturbo
Old Jan 28, 2012, 12:31 PM
tc3wins is offline
South Carolina
Joined Mar 2009
Ok I got it to work, It was that I needed to use both sticks to arm and disarm. now I am going to read up on the yaw thing. it goes to the left ine but hesitates to the right and sometimes takes awhile and sometinmes it works ok. but other then that snhe is flying fine. need to adjust the pid's she is a little shakey but not bad.
Old Jan 28, 2012, 12:48 PM
quentusthetroll is offline
Find More Posts by quentusthetroll
Joined Mar 2011
trouble ?!!
http://www.youtube.com/watch?v=wjO5kTbhwKU
Hello, i fly with free flight ff with 4 lipo and i get trouble in this condition ! It's like their is too much "gain" and the quad is swinging ! Can you explain me how to fix that with PID and tell me what is the value i need to change ?!
Thanks so much your help
Cheers,
Quentin
quentusthetroll is offline Find More Posts by quentusthetroll
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
