Old Jan 25, 2012, 11:38 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
You can always find Gents who have problems...that is the nature of this hobby... I suspect there might be different revisions of the same version of 1.22 and that would our explain different experiences
BTW, You can be a great help to all of us if you speak and read Chinese/汉语/漢語/Mandarin/Wu/Cantonese/Min, etc
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Originally Posted by 217176 View Post
i havd understand why you say 1.22 have no problem
jesolins is offline Find More Posts by jesolins
Old Jan 25, 2012, 11:50 AM
Flyingfool is offline
Find More Posts by Flyingfool
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
Hey Guys,
I'm trying to wrap my head around this and need someone elses opinion.
My quad wants to drift to the right no matter how many times I calibrate it, So should I shim the left side up a bit during calibration to help eliminate this drift?
I cant find my little bubble level anywhere to actually check if the quad if perfectly level.
Maybe my house is leaning some so sitting on the counter it is not perfectly level during calibration.
Flyingfool is offline Find More Posts by Flyingfool
Old Jan 25, 2012, 12:00 PM
C team MOD is offline
Find More Posts by C team MOD
Flying Like Evil
C team MOD's Avatar
France, Languedoc-Roussillon, Garons
Joined Oct 2010
I don't have that chance ........ (to understand)
C team MOD is offline Find More Posts by C team MOD
Old Jan 25, 2012, 12:40 PM
jesolins is offline
Joined Feb 2007
FF,
Yep. But when calibrating the IMU/accelerometer you need to put the shim under the side of the multicopter that it drifts to to raise what it is seeing as level so the drift is cancelled.
Cheers,
Jim
Originally Posted by Flyingfool View Post
Hey Guys,
Old Jan 25, 2012, 02:23 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Got my board today! Ordered it on 1/6 and it shipped on 1/8 so 19 days in transit, not bad. Came in a bubble wrap padded envelope with all components in ESD type zip lock bags.
For my sanity and for the benfit of others, I plan on creating a rewrite of the english manual with pictures and tips, including those for the PID app.
If you have any specific tips/ideas/gotchas that you would like included in the manual, please PM them to me. You will of course be given credit for your input.
Jose
rcjose is offline Find More Posts by rcjose
Old Jan 25, 2012, 03:53 PM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
Originally Posted by jesolins View Post
... I checked it with another Tx/Rx set, Spektrum and got the same results of ~(-10) displayed at the low end instead of an expected -128, but it responds properly in all channels nonetheless.
żJesolins are you sure it´s -10 and not -100?
Today I had a maiden flight with my second FF build. I had to do some adjustments and my laptop was not nearby. I had to use another mac with a virtualized vmware XP virtual machine.
Loaded ZNS 1007 and noticed my lower end was at -12...moved it with the stick and noticed that it was actually going from -128 to 128. Problem is that the soft adds a minus "-" sign on the lower values. That makes it to display -10,-20....-90 and then when it reaches -100 it shows -10. It seems (at least on my pc) that it cannot display more than 3 characters, so once it gets to -100 it actually displays -10 at -110...-11 and so on.
Maybe your soft has the same issues, and because of that even getting confusing values (which are not real) we still get a proper flight.
Here some photos of the new build...
apejovic is offline Find More Posts by apejovic
Old Jan 25, 2012, 04:05 PM
jesolins is offline
Joined Feb 2007
Hi A,
Ha... so there is anolther one like mine out there That is what the display shows as in my attachment to that post, but since it operates correctly as your does in flight I know it is just a display issue. As I posted previously, when I move the sicks It cycles from 128 down to 0 then up to 99, then 0 and a negative number count. Strange. It is FF v1.22 but could be a different revision of that if others with v1.22 see thee range count normally. BTW the same strange range values appear in the ZN v1.05 setup utility too. I am using a PC WinXP.
Nice build
Cheers,
Jim
Originally Posted by apejovic View Post
żJesolins are you sure it´s -10 and not 100?
Old Jan 25, 2012, 07:51 PM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I am waiting for the FF board to arrive in the post and am just setting up the frame, esc etc.
I have done electric planes for a long time but have not hooked up 4 ESC's before. I understand it is very simple when you know how to do it.
I have installed four EMax BL 2215/20 motors and 30amp Pentium ESC's and now have to connect the 12v power wires of the ESC's.
I guess you wire the four ESC's together and then to two wires to a plug for the LiPO. I intend to use a Castle Creations 10amp SBEC for the receiver.
Just wondered if there is a circuit diagram somewhere and close up pictures of setups.
Firepower is offline Find More Posts by Firepower
Old Jan 25, 2012, 08:23 PM
rcjose is offline
Joined Aug 2010
All four of the black lipo leads from the escs get wired together and the red lipo leads get wired together. You can purchase a power distribution board or make a harness called a power spider. I have a video on how to make one on my YouTube channel www.YouTube.com/rcjoseb
Old Jan 25, 2012, 08:48 PM
Firepower
Firepower's Avatar
Joined Mar 2010
Thanks - A lot of good video viewing there. That will shut me up for a while but good stuff.
Old Jan 26, 2012, 02:24 AM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
I just had a fly of my FF copter after I had changed the PID values and upped the Yaw gain.
It flies more like I am used to, but somewhat less stable. Yaw gain is better but... now I have lots of left Yaw and almost no right. I'm sure I've seen others report similar.
HappySundays is offline Find More Posts by HappySundays
Old Jan 26, 2012, 05:19 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
processor-killed,
what now?
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jan 26, 2012, 05:26 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by JUERGEN_ View Post
processor-killed,
what now?
also buzzer is stolen
jaccies is offline Find More Posts by jaccies
Old Jan 26, 2012, 06:42 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
processor-killed,
what now?
http://search.digikey.com/us/en/prod...063-ND/1646338
Here you go.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 26, 2012, 07:04 AM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Originally Posted by timecop View Post
and copy protection?
why not? STM32F103CBT6
I have the.
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
