Old Jan 24, 2012, 08:21 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Originally Posted by navihawk View Post
so i use the radio to get all the sliders to the left, and hit save?
Which manual are you guys reading!? Are you using the more-or-less corrected manual on the first post of this thread, or something else? I can see nothing in my manual that even hints at moving sliders and clicking save... What are you trying to do?
HappySundays is offline Find More Posts by HappySundays
Old Jan 24, 2012, 08:38 PM
navihawk is offline
Find More Posts by navihawk
United States, FL, Orlando
Joined Nov 2006
The one on page 28, http://www.rcgroups.com/forums/showp...&postcount=419
navihawk is offline Find More Posts by navihawk
Old Jan 24, 2012, 08:40 PM
quentusthetroll is offline
Find More Posts by quentusthetroll
Joined Mar 2011
hum, what do you want to do exactly ?? To use the softwar, connect the lipo to your board, turn on the radio, connect the board to usb interface, click on "open" ! that's all !
If you want calibrate stick : click on "calibration RC" and move stick in every direction ! when it's finish click again on the same "calibration RC !
quentusthetroll is offline Find More Posts by quentusthetroll
Old Jan 24, 2012, 08:47 PM
navihawk is offline
Joined Nov 2006
Page 3,step 3,on the manual on first page of this thread,also on manual found on page 28 of thread
Old Jan 24, 2012, 08:50 PM
navihawk is offline
Joined Nov 2006
Im just confused because it says in the manual,and shows in the picture to put all the slider to the left,but it looks to me like thos sliders are to show stick position when you move a controll on the transmitter
Old Jan 24, 2012, 08:57 PM
Joined Feb 2011
....it doesn't say anything about moving the sliders on Page 3 Step 3... it just happens to show them at the left. Ignore completely that thing on page 28 as it is rubbish.
On Step 3 Page3, it simply tells you how to change settings. That's all. There are a number of tabs and sliders to change throughout the program, but that picture shows the first RC input page, which just mirors your transmitter.
So in summary, you've misunderstood the manual. Throw away that other manual and just use the one on the first post. Forget the sliders.
Old Jan 24, 2012, 08:58 PM
navihawk is offline
Joined Nov 2006
Guess what I am trying to find is if there is a way to adjust the sensitivity of the board,like gain pots on boards with gyros,to make it more stable
Old Jan 24, 2012, 10:08 PM
Joined Feb 2011
OK, what you need is the other piece of software, the PID value adjuster (somewhere in this thread) which allows that. It's not very user friendly, so use at your peril
Old Jan 24, 2012, 10:14 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi NH,
Go to the thread search menu above and put in PID. A Gent named Snapper1234 has posted English versions of the PID utility. Also use the PID utility versions that your ZN si showing in the bottom of the window. EDIT: I found 20 seconds to do it for you see below...
@ Chris,
Please post those in your first post
* Edit:
-- FF PID v1.22
-- FF PID v1.24
and also:
--FF PID Adjustments 101
--FF yaw issues and mechanical neutral stability setup 101
--Multicopter Mechanical Dynamic Neutral Stability setup 101
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jan 25, 2012, 03:51 AM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
Lazyzero has now added Mike's esc calibration hex to the KK flashtool to make it easier for people to use his firmware for esc calibration, you can download the flashtool here
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
Gaza07 is offline Find More Posts by Gaza07
Old Jan 25, 2012, 04:10 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Hi,
I am trying to post a request to the product forum on GLB site but when I submit my post, it does nothing. I do not see my posts there. If anyone is able to post there or knows contact to manufacturer/developer, I would like to request some things:
1. manual pitch adjust of PTZ (camera gimbal) via channel 7 is not working
2. support of more configs, like tricopter or hexa
3. version with baro sensor and altitude hold - as good as Naza
4. include PID settings in the basic PC application
5. remove 3D mode and simply make it acro (without auto level)
6. user friendly firmware updater
This is all I am missing now. If that would be done than this is as good as Naza for half price.
Thanks!
alek3d is offline Find More Posts by alek3d
Old Jan 25, 2012, 05:43 AM
Flyingfool is offline
Find More Posts by Flyingfool
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
What were the changes in the newest firmware? Is it worth upgrading?
Flyingfool is offline Find More Posts by Flyingfool
Old Jan 25, 2012, 05:59 AM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
I went with v1.4 mainly because the arming and disarming are more secure i.e its almost impossible to accidently disarm the FCB. Also at that time the PID tool was in english wheras the v1.22 was still in Chinese(its in english now)
whiteturbo is offline Find More Posts by whiteturbo
Old Jan 25, 2012, 06:10 AM
alek3d is offline
Slovakia
Joined Nov 2010
Can you please test if manual pitch adjust of the camera mount is working in 1.24? You can test it just using two servos connected to CH1 and CH2 outputs from the board. Then enable PTZ in PC app. Now, when you power up the board and you move it, the two servos should move too because they try to stabilize the camera.
To test manual adjust try connecting spare channel of your receiver to CH7 input of the board. Also map a knob in your TX to that spare channel so that when you turn it, it changes proportionally the signal going into CH7 of the board inputs. I believe this is how it is supposed to work, but it does not in my version 1.22. Thanks!
Old Jan 25, 2012, 06:54 AM
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
would love to except i am fresh out of servo's sorry!
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
