Old Jan 17, 2012, 02:03 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Originally Posted by Julkabas View Post
started to experiment to find a solution for the "3 second great stable hover & start to drift problem"
What i don't understand:
* as long as the quad is in the air, the drift is getting worse & worse
* it drifts to the right AND forward
* i counter it with giving Stick left & back until i am fully left en back with the stick
* if i put the quad on the ground and go back up (without disarming or resetting it first); there is a good stable hover for 3 seconds
Anybody with the same issues or any suggestions ?
I think the next step could be changing the motors/ESC's ?
Julkabas
Hi, I have the same problem but only when in cold environment, around 0C or less. When it is warm enough it is perfectly leveled and does not drift. Look how it hovers inside. Is it cold where you fly?
http://www.youtube.com/watch?v=tiNazHrBGI8
alek3d is offline Find More Posts by alek3d
Old Jan 17, 2012, 03:11 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by eaton View Post
Thanks for a nice advice.
I read a manual again, and found arming was different on 1.24, as you pointed out.
Eaton
tell us , which manual are you talking about?, the manual in the first post
does not mention different arming for firmware versions.
jaccies is offline Find More Posts by jaccies
Old Jan 17, 2012, 03:18 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Nice hovering. But you neglected one iron safety rule: NEVER fly when kids are around!
Those rotating blades have the potential to kill. You'll never know when a glitch occurs and you don't have any control over the craft.
I know it's hard to keep kids away - but multirotors are no toys!
kinderkram is offline Find More Posts by kinderkram
Old Jan 17, 2012, 03:46 AM
alek3d is offline
Slovakia
Joined Nov 2010
Yeah, I know it, I was afraid. He was sitting behind my back (for protection) and then decided to come in. I'll never do that again, just wanted to show it works, outside in cold it drifts.
Old Jan 17, 2012, 06:39 AM
eaton is offline
Find More Posts by eaton
Boston
Joined Mar 2006
Pls see attached
eaton is offline Find More Posts by eaton
Old Jan 17, 2012, 07:04 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Any idea of the changelog for the different versions?
I got mine with 1.22 but I wanted to make sure it's worth to upgrade to 1.24.
One final question, does the 3D mode is on/off? From the manual I got that when enabled it just increases the max rate in the AIL/ELEV channels as it stills will do auto-level when we release the sticks. Is that correct?
IceWind is offline Find More Posts by IceWind
Old Jan 17, 2012, 07:31 AM
snapper1234 is offline
Find More Posts by snapper1234
snapper1234's Avatar
Germany, HB, Bremen
Joined Dec 2008
Originally Posted by timecop View Post
Can you ask your Chinese friends on QQ which version of RealView they're building the firmware with? Thanks ~
pls. send PM !
snapper1234 is offline Find More Posts by snapper1234
Old Jan 17, 2012, 07:36 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
What do you mean? I was asking you
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 17, 2012, 08:00 AM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
Originally Posted by agressiva View Post
Quax, some news about your BARO test ?
No - I couldn't get any reaction during flight. The only activity was the value in the GUI.
Meanwhile I unsoldered the BMP085 and mounted it on a DIL-8 PCB to test it with my MWC.
quax is offline Find More Posts by quax
Old Jan 17, 2012, 11:36 AM
eaton is offline
Boston
Joined Mar 2006
spend a lot of time reading the megaindex. Learned a lot! (thx Jesolins)
What did i do?
programmed the ESC's(HobbyWing Skywalker 20A) individually for:
* throttle range
* brake off
* battery type: NiMH (yes NiMH; see megaindex)
* Cutoffmode: soft cut
* Cutoff threshold: Low
* start mode: normal
* timing: tried high / tried low
other tests:
* Changed the props from 3 blade to 2 blade
* Recalibrate IMU before each test
* Recalibrate the FF board with the CH5 switch(green led) before each test (with full throttle before switch off CH5)
What was NOT tested:
* 3D mode
* Upgrade firmware
Julkabas
I had a same symptom, and replaced the ESCs with no help.
Finally resolved by re-cal IMU with a trick.
My case was, it drifted to the left side.
Before IMU calibration, lifted up the right side of the PCB about 5 mm, so that the PCB tilted to the left side, and hit the IMU cal button.
This fixed my drifting problem.
Old Jan 17, 2012, 06:31 PM
eaton is offline
Boston
Joined Mar 2006
I2C on 1.24
I2C ESC on 1.24 is worse than on 1.21
It hardly turned props.
With 1.21, it was flyable, even though sluggish, but can't fly with 1.24
Yes, I did not forget to change setting to I2C from PWM...
Now I have returned back to PWM, and it works fine.
Old Jan 17, 2012, 06:47 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Recieved my board today from GLB and man it came quick ordered on Friday, and got today. all cables were there etc. well mess with it this weekend.
tc3wins is offline Find More Posts by tc3wins
Old Jan 17, 2012, 07:02 PM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
What about IMU CAL from receiver, did you try it (available on 1.24)? It would be nice to know if it works, since sometimes people need to do IMU Calibration and havent got a PC near.
About the imu cal trick If Im not wrong I have fixed my right side drift lifting the right side of the quad when doing the calibration. You say you had
left side drift and fixed it lifting the right (oposite side), Im confused....
apejovic is offline Find More Posts by apejovic
Old Jan 17, 2012, 07:49 PM
eaton is offline
Boston
Joined Mar 2006
I tried to calibrate IMU from TX by both sticks up and moving to outside, but
nothing happened, no beep, no LED blink...
For IMU cal from PC, please refer attached
I have a flexible mount. Please see the right leg, which is lifted up ~ 3mm.
This mount not only eliminates vibration, and but also helps to adjust drifting at field without PC.
Old Jan 17, 2012, 08:07 PM
Klonk is offline
Find More Posts by Klonk
Joined Jan 2012
Noob
Hi guys, I'm new to this site and sport. This is my first post. I took the plunge and bought the GLB DJI 450 with FF board ARTF kit. It looks awesome. I put it together. Bought myself a futaba t6j. Did the setup stuff and the RC calibration. Now when I try to arm the board nothing happens. I don't know what to do and the quad is sitting on my dinning table rotting. PLS HELP. Anyone has any experience to share. How do I arm the damn thing. I followed the instruction and no green LED is lighting up.
Klonk is offline Find More Posts by Klonk
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
