Old Jan 16, 2012, 05:44 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Sounds like maybe some luminary micro part or maybe an unknown chinese knockoff. Pinout didn't match anything sensible but I didn't spend a lot of time looking. Whatever I2C "problems" exist don't affect normal operation/usage. I've done I2C on both STM8 and STM32 as master and slave and had no issues. Its quirky, such as 2-byte buffering stuff, but once you get it, it makes sense.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 16, 2012, 07:21 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Guys, question on low temperature problem: do you think the sensors need to accommodate to ambient temperature or they simply don't work in lower temperatures?
I also have simple FPV TX/RX (5.8GHz RC 305) and when it is like 5 degrees or less I have no image. It looks like it gets untuned or something. It works nicely inside or outside when temperature is higher.
So I wonder if this board simply does not work in cold or needs to acquire outside temperature before power up...
alek3d is offline Find More Posts by alek3d
Old Jan 16, 2012, 07:32 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Eaton,
Good to see you here too ...and now Prof Greg too while he awaits his own version of cheapo FCB fun with the Rabbit board
As was asked by someone earlier, did you check and save the 12c switch in the ZN setup utility? Are you using the ZN v1.07? You should try to change the PID first before you attempt an upgrade. If you do decide to upgrade make sure you follow the steps exactly as there have been some upgrade issues. Review the first post in this thread. One found key to upgrade success is to not check the erase all pages block.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Originally Posted by eaton View Post
Hi Jim
Good to see you here!
I used the default PID setting that worked fine with PWM ESC.
I can't believe why I2C was slower than PWM, and may need to adjust PID.
By the way, in order to adjust PID, should I upgrade to 1.24?, and
is there any issue to upgrade from 1.21 to 1.24?
Eaton
jesolins is offline Find More Posts by jesolins
Old Jan 16, 2012, 07:38 AM
timecop is offline
Joined Dec 2010
He might be wasting his time with the rabbit, unknown CPU and I don't think debug stuff is broken out.
Old Jan 16, 2012, 07:49 AM
jesolins is offline
Joined Feb 2007
Alek
A best practice for multicopter FCB's is to let them acclimate to the flying environment temps for 10-15 minutes before a flight. It has yet not been cold enough here to see any drifting from only a 20 degree temperature change, so a test for later for me
Suggestions: Hook up an old lipo to it while it acclimates too as that will also change the board temp as the regulator heats up. Remember that it zeroes the gyros in the first two seconds of power on, so when you put on a flying lipo, make sure it is absolutely still for those seconds after applying power. Other than that you might try to recalibrate the IMU while it is acclimated to thee cold temperatures. That would be a pain.
Another thing that can cause drift or flipping on a multicopters in a cold flying environment are the ESCs. Some are notorious for not arming or for changing their throttle range in cold temperatures of about 20F/-7C or less. Again recalibrating them while they are acclimated in those low flying temperatures seems to make them work OK.
Hope that helps
Cheers,
Jim
Old Jan 16, 2012, 07:56 AM
alek3d is offline
Slovakia
Joined Nov 2010
Hope that helps
Cheers,
Jim
Well, I think the most likely it is board sensors that get mad because my cam gimbal gets totally off the basic position when this occurs. I mean, after that short flight when I noticed level problem I landed and repowered the board. Gimbal got full roll and pitch responded like it was almost frosen. I moved the quad and pitch barely responded to my moves. This suggests like angle sensors output nonsense values.
This quad has HobbyKing SS porgrammable ESCs but I think they are similar if not the same like Plush. I flew Plush and Mystery ESCs in my airplane in much much colder weather, like -13, and I did not notice any problems with them.
I'll try temperature accommodation later today to see if that helps.
Old Jan 16, 2012, 08:33 AM
jesolins is offline
Joined Feb 2007
Alek,
OK. Yes it sounds FCB related in your case. Remember that you must re-power after you let it acclimate before flying.
Cheers,
Jim
Old Jan 16, 2012, 09:41 AM
timecop is offline
Joined Dec 2010
Originally Posted by snapper1234 View Post
Can you ask your Chinese friends on QQ which version of RealView they're building the firmware with? Thanks ~
Old Jan 16, 2012, 11:04 AM
ferrocium is offline
Find More Posts by ferrocium
Hooked on FPV
Joined Jan 2012
Repost because nobody answered:
Sorry, these questions may have already been answered but I don't have enough free time to go through the 50 pages of posts...
Does this new free flight card have a baro or compass?
Is there a diagram showing what each chip on the board is?
Is it really plug and play or does it take some tweaking?
Do they have the software in English yet?
ferrocium is offline Find More Posts by ferrocium
Old Jan 16, 2012, 11:08 AM
jesolins is offline
Joined Feb 2007
Hi,
I suggest that you start reading at the first post that Chris keeps updated as the FreeFlight controller information becomes available. All your questions are answered there.
Cheers,
Jim
Old Jan 16, 2012, 11:17 AM
alek3d is offline
Slovakia
Joined Nov 2010
1. No baro, no compass.... for $50???
2. It was not really PNP for me, but I had problem with my frame too. But it flies and for others it was PNP.
3. Manual in the first post.
Alek
Hope that helps
Cheers,
Jim
Ok, so I did a test and the board failed. I left it outside for about 15 minutes. It is -3 right now. Then I tried to fly it. It drifted more and more in a matter of seconds, battery reconnect did not help much. Finally, after battery reconnect it would not even arm. Took home, waited about 15 minutes, it arms again.
Hmmm, this board is for summer only
Old Jan 16, 2012, 11:33 AM
eaton is offline
Find More Posts by eaton
Boston
Joined Mar 2006
Hi Eaton,
Cheers,
Jim
Hi Jim,
Yes, I selected I2C when tested.
Unfortunately, my board did not work, after upgrading to 1.24.
Everything working fine with PC program (I did RC cal and IMU cal),
but I could not ARM the motors.
Then, I have returned to original version (1.21) which I saved before upgrading to 1.24.
The Board is now working, but it shows glitches.
I am not sure it is related with upgrading and downgrading issue, or
some connections are bad.
I need to install UAVP on the same frame, and confirm any wiring issue, or
contact issue
Eaton
eaton is offline Find More Posts by eaton
Old Jan 16, 2012, 11:43 AM
jesolins is offline
Joined Feb 2007
Alek,
Not arming in the cold also points to ESCs. What ESCs are you using?
Cheers,
Jim
Old Jan 16, 2012, 12:13 PM
alek3d is offline
Slovakia
Joined Nov 2010
Alek,
Cheers,
Jim
Hobbyking SS Series 18-20A ESC (card programmable)
http://www.hobbyking.com/hobbyking/s...idProduct=6548
I still think it is the board. Gimbal was dead, and it normally works even if the board is not armed, only powered is enough for gimbal to work. But it was dead.
Old Jan 16, 2012, 01:35 PM
jaccies is online now
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
curious...what is a gimbal??
jaccies is online now Find More Posts by jaccies
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
