Old Jan 15, 2012, 03:34 PM
eaton is offline
Find More Posts by eaton
Boston
Joined Mar 2006
Originally Posted by alek3d View Post
This is my 2-axis camera mount. I still have not figured out how can I use CH7 on the FC to control something. In GLB product description it reads "PTZ pitch angle 7, PTZ pitch angle trimming(ratio CH input)" - but I could not make it working. What can I do with Pitch Lock in the PC app is to manually preset pitch of the gimbal while connected to PC.
http://www.youtube.com/watch?v=CR-p38K_A7M
Also, today I found out that the board probably does not like cold weather. It was like -3 C and after a short flying - testing gimbal, the board got mad. It started with drift, so I landed, then I could not even lift off because it would flip instantly. I did reconnect the power because I thought it needs to get restarted after it got a new temperature. But it did not help. At home after about 30 minutes it works again as normal.
I have the same symptom.
Aileron trim and Elevator trim are changing more than 7 ~ 8 clicks by temperature , today I have 10 F outside in Boston area.
This is not negligible.....
eaton is offline Find More Posts by eaton
Old Jan 15, 2012, 03:41 PM
C team MOD is offline
Find More Posts by C team MOD
Flying Like Evil
C team MOD's Avatar
France, Languedoc-Roussillon, Garons
Joined Oct 2010
Hi nice Camera Mount, which one is it.......?? Is it your own build??
C team MOD is offline Find More Posts by C team MOD
Old Jan 15, 2012, 04:50 PM
eaton is offline
Boston
Joined Mar 2006
I2C ESC with FF
Attempted to use I2C ESC, but the result was not good.
Response was very slow...
There are 3 pads on the PCB, G (ground), D (Data), and C (clock), and
I2C addresses are 0x52, 54, 56 and 58.
I am not sure that FF handles other address, or not
Old Jan 15, 2012, 05:22 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
'Result was not good' ? What was the result?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 15, 2012, 06:53 PM
eaton is offline
Boston
Joined Mar 2006
The board worked fine with PWM ESCs.
Having replaced with I2C ESCs, it flies sluggish, another words,
sticks response is very slow, as if commanded by drunken pilot...
Old Jan 15, 2012, 07:03 PM
timecop is offline
Joined Dec 2010
Interesting. One would expect i2c to be faster
Old Jan 15, 2012, 09:50 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Eaton,
Did you make any PID and stick value adjustments for the I2c ESCs or just use the defaults?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jan 15, 2012, 10:57 PM
eaton is offline
Boston
Joined Mar 2006
Originally Posted by jesolins View Post
Hi Eaton,
Cheers,
Jim
Hi Jim
Good to see you here!
I used the default PID setting that worked fine with PWM ESC.
I can't believe why I2C was slower than PWM, and may need to adjust PID.
By the way, in order to adjust PID, should I upgrade to 1.24?, and
is there any issue to upgrade from 1.21 to 1.24?
Eaton
Old Jan 15, 2012, 11:47 PM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Thanks! It is home made but not by me. A guy from Thailand made it for me and I bought it from him. I posted an ad here and he contacted me.
alek3d is offline Find More Posts by alek3d
Old Jan 15, 2012, 11:57 PM
timecop is offline
Joined Dec 2010
Looks like noppita's
Old Jan 16, 2012, 12:57 AM
ferrocium is offline
Find More Posts by ferrocium
Hooked on FPV
Joined Jan 2012
Sorry, these questions may have already been answered but I don't have enough free time to go through the 50 pages of posts...
Does this new free flight card have a baro or compass?
Is there a diagram showing what each chip on the board is?
Is it really plug and play or does it take some tweaking?
Do they have the software in English yet?
ferrocium is offline Find More Posts by ferrocium
Old Jan 16, 2012, 02:50 AM
gke is offline
gke
Find More Posts by gke
gke
Australia, VIC, Ringwood
Joined Feb 2008
An ancient old UAVP PIC can still manage ~500Hz PID updates running I2C so most likely a poor bit banged I2C implementation and/or I2C timeouts which are too long. There have also been issues with Arm I2C hardware so bit banging is very common.
I may have missed it but which specific Arm is on the board?
Greg
gke is offline Find More Posts by gke
Old Jan 16, 2012, 03:16 AM
alek3d is offline
Slovakia
Joined Nov 2010
Yes, I bought it from him.
The board worked fine with PWM ESCs. Having replaced with I2C ESCs, it flies sluggish, another words,
I know you are smart, but just making sure you did not forget to swtich PWM to I2C in the PC app. Sometimes we are all forgetful...
Old Jan 16, 2012, 04:02 AM
timecop is offline
Joined Dec 2010
Greg
It's hardware I2C2 from STM32F103C8T6.
Problem (?) likely is, there's silly i2c sensors on same bus.
Old Jan 16, 2012, 05:42 AM
gke is offline
gke
gke
Joined Feb 2008
Thanks. The I2C issues were in the STM Arm hardware and probably the LPC versions as well so maybe common IP.
I assume it will be the STM32103 on the Rabbit version where the part number is scratched out?
Greg
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
