Old Jan 14, 2012, 06:51 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi J,
--Are you disconnecting the ch5 before flight?
--The ESC should be set per Mega Index ESC section --TIP 4: Set the standard ESCs for brake and governor mode off, LVC off if available, start = normal, soft cut-off, NiMh, low voltage. The throttle calibration should be done as well. The ESC settings are accomplished by connecting the ESCs individually to the throttle channel on your Rx. You then need to use the ESC instructions for your particular ESCs to move the throttle stick up and down to set with the beeps you hear. Some ESCs use a card to do this too which is much easier and quicker.
Don't use any endpoint or other settings you used for your Gaui. Leave them alone after you have done the Tc/Rx calibration with the default settings.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Originally Posted by Julkabas View Post
redid calibration via switch on CH5 and "swing the sticks" in all directions; ending with full throttle. result:no difference
tried later with RC CAL button in app.
result: no difference.
sorry but what do you mean by" brake off" ? can find no brake settings in the app or in my spektrum dx6i. Maybe i overlooked something?
jesolins is offline Find More Posts by jesolins
Old Jan 14, 2012, 06:52 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
throttle calibration on *ESC* and brake setting on *ESC*.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 14, 2012, 06:57 PM
willi_m is offline
Find More Posts by willi_m
Calgary, Alberta
Joined Mar 2007
willi_m is offline Find More Posts by willi_m
Old Jan 14, 2012, 07:04 PM
Julkabas is offline
Find More Posts by Julkabas
Belgium
Joined Dec 2010
those Chinese guy's are funny....
i downloaded the English manual http://www.goodluckbuy.com/upload/up...ser-Manual.pdf
it says: Firstly turn on the remote control power supply and adjust the joysticks to
intermediate positions, turn the power on and then switch the 5th channel on,
at this time the green light on the fly control board is normally on(that means it
is loading to calibration mode). Swing the joystick to all direction (getting
joystick range), lastly adjust the 3th channel(Throttle) to the maximum position( Note: It is the only way the processor can record the maximum andminimum positions for each joystick, and calibration is valid).
Then i found another manual:
http://www.goodluckbuy.com/images/de...shGuideGLB.pdf
it says:
3.Calibration sticks radio
Make sure you have propellers out.
Switch on channel 5. The green led on Free flight board turn on and remains
lit, this indicates that board got into 'calibration' mode. Operate the sticks in all
directions and finish the calibration by placing the stick throttle to bottom
(note: this is the only way to get board stores position of max and min sticks),
it is now 2 'o clock at night here .. the quad's battery is flat (and my battery too).
i will sleep over it & try again tomorrow.
thx.
Julkabas is offline Find More Posts by Julkabas
Old Jan 14, 2012, 07:20 PM
Julkabas is offline
Belgium
Joined Dec 2010
Originally Posted by jesolins View Post
Hi J,
Cheers,
Jim
oops again.. i did not disconnected physically the CH5. Just flipped the CH5 switch off. i'll try to disconnect it...
The quad came ARTF from GLB and was "prewired" with the 20A esc's and motors connected to a power distri board, so i assumed the esc's where set.
Flat battery now, so i can not test before it's charged
i try your suggested esc setting tomorrow.
that megaindex is a goldmine! never took the time to scroll to the first post on page 4 ; there is all the info!! (stupid me)
have to go to bed now.
thx a lot guy's
Old Jan 14, 2012, 07:53 PM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
Hi J,
Jesolins, why should he disconnect ch5 before flying?
Im flying with both ch5 and 6 (3d) connected and everything is fine.
apejovic is offline Find More Posts by apejovic
Old Jan 14, 2012, 07:58 PM
jesolins is offline
Joined Feb 2007
J,
OK. Make sure you have a Tx channel on the FF ch 6 to set the 3d mode/self-leveling on and off. However if it is left off it does the self-leveling.
Cheers,
Jim
thx a lot guy's
Old Jan 14, 2012, 08:01 PM
jesolins is offline
Joined Feb 2007
A,
Wellll....Only because it tells you to remove it in the manual It might have no effect on performance, but it would be definitely be bad ju-ju to accidentally put it in calibration mode while it is in flight.
Cheers,
Jim
Old Jan 14, 2012, 08:03 PM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
Do you have to re-calibrate the radio and IMU before each flight?
Plane Insane RC is offline Find More Posts by Plane Insane RC
Old Jan 14, 2012, 08:09 PM
jesolins is offline
Joined Feb 2007
PI,
No. Once is fine if you did it correctly in the first place. If you have excessive drift then maybe your model's level was not quite correct the first time it was calibrated and you could try re-doing the IMU calibration.
Cheers,
Jim
Old Jan 15, 2012, 07:51 AM
snapper1234 is offline
Find More Posts by snapper1234
snapper1234's Avatar
Germany, HB, Bremen
Joined Dec 2008
Originally Posted by tc3wins View Post
where did you find this? (GPS) and how much if ya now
http://item.taobao.com/item.htm?id=13657714895
Great bargain for bare pcb !
snapper1234 is offline Find More Posts by snapper1234
Old Jan 15, 2012, 09:20 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Hi Alek,
Very good. Not sure how high the yaw stick can be set in the PID, but you should try setting it higher to see if you get the yaw response you are looking for. You could also add dual rate to the yaw channel too to increase the speed.
Cheers,
Jim
Thanks! Again, you hit the bull's eye! Changing Yaw_Stick to some insane value like 30 makes the yaw responding as I like it. You know, seeing roll and pitch at 1 or 2 I would not expect Yaw to be as high as 30 to be ok.
New thing: I installed gimbal and it works nicely. I am not sure what Pitch Lock (in PC app in PTZ settings tab) is doing. Also, I thought that channel 7 input on the FC board has something to do with manual gimbal adjustments. I hooked one knob on my TX to CH6 and connected to CH7 on the FC board. But changing value of that knob does nothing. Any ideas how is this supposed to work?
Thanks!
alek3d is offline Find More Posts by alek3d
Old Jan 15, 2012, 11:55 AM
BUZZ KILL
Utah
Joined Aug 2010
Man Alek3d, your asking all my questions for me! I hope someone answers you.
Yesterday I posted that I had crazy oscillation in the + mode. I now know why. I did just as the instructions said, if you fly in + you have to turn the board 90 degrees. Well that is not the case (thanks Jac Engel for clearing that up). The board is positioned the same for + or x. And to think I went through all the trouble of mounting the board as per the instructions when I didn't need too!
I do have a couple of questions, is there a way to turn down the sensitivity (sorry if this has already been answered) and my quad seems to drift up a down quite a bit. Is that normal? The other quads I fly with HK boards don't seem to have this problem.
Ryan
Old Jan 15, 2012, 12:10 PM
jesolins is offline
Joined Feb 2007
PI,
And you were answered too. Please take the time to read the info Chris puts in the first post of this thread which points out the proper board orientations for + and x modes. That diagram was wrong in an early version of the manual and was noted several times already in this thread.
Have fun and fly safe!
Cheers,
Jim
Ryan
Old Jan 15, 2012, 02:44 PM
alek3d is offline
Slovakia
Joined Nov 2010
This is my 2-axis camera mount. I still have not figured out how can I use CH7 on the FC to control something. In GLB product description it reads "PTZ pitch angle 7, PTZ pitch angle trimming(ratio CH input)" - but I could not make it working. What can I do with Pitch Lock in the PC app is to manually preset pitch of the gimbal while connected to PC.
http://www.youtube.com/watch?v=CR-p38K_A7M
Also, today I found out that the board probably does not like cold weather. It was like -3 C and after a short flying - testing gimbal, the board got mad. It started with drift, so I landed, then I could not even lift off because it would flip instantly. I did reconnect the power because I thought it needs to get restarted after it got a new temperature. But it did not help. At home after about 30 minutes it works again as normal.
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
