Old Jan 14, 2012, 09:13 AM
snapper1234 is offline
Find More Posts by snapper1234
snapper1234's Avatar
Germany, HB, Bremen
Joined Dec 2008
"beautiful green color"
with a board that is still in development but rather a minor role, right?
snapper1234 is offline Find More Posts by snapper1234
Old Jan 14, 2012, 09:14 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I think JUERGEN_ just likes green.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 14, 2012, 09:26 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Alek,
Very good. Not sure how high the yaw stick can be set in the PID, but you should try setting it higher to see if you get the yaw response you are looking for. You could also add dual rate to the yaw channel too to increase the speed.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Originally Posted by alek3d View Post
Hey, it worked!!! The rudder is not as aggressive as I am used from KK boards but at least I can fly now. I used PID for 500 mm quad and I changed P Yaw to 50 and D to 0, Stick to 20. Maybe future FW versions could have more aggressive rudder, for me this is lazy.
This quad is good for slow flying for AP/AV. Overall, it's very stable. I tried acro mode and when I was messing around it and it suddenly fell out of the sky. Fortunatelly only props broken, but I would not try acro mode again.
The video is shot today and it was just before the snow storm, there was a very strong wind.
http://www.youtube.com/watch?v=BLnE289DYbM
Now, I am going to mount my DIY 2-axis gimbal and try how it works with this board.
jesolins is offline Find More Posts by jesolins
Old Jan 14, 2012, 09:50 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
YES,
Black is death.
is better than a FF?
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jan 14, 2012, 10:10 AM
Germany, HB, Bremen
Joined Dec 2008
STM8S105 CPU (8bit CISC, 16MHz)
back to the roots ?
Old Jan 14, 2012, 10:22 AM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
back to the roots ?
at least as early STM.
the still growing.
Old Jan 14, 2012, 01:20 PM
igalr is offline
Find More Posts by igalr
Joined Sep 2004
This is my video from today :
Snow in israel - Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter (2 min 36 sec)
igalr is offline Find More Posts by igalr
Old Jan 14, 2012, 05:28 PM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
Got a board the other day. I hooked it up in a small quad in the x config and it worked great so I put it in my camera rig which is a + config and now I'm getting tons of oscillation. I'm using firmware 1.24. Does it not do + config?
Thanks for any help.
Ryan
Plane Insane RC is offline Find More Posts by Plane Insane RC
Old Jan 14, 2012, 05:43 PM
Julkabas is offline
Find More Posts by Julkabas
Belgium
Joined Dec 2010
ARTF DJI + FF from GLB
Hi Guy's
my Christmas present arrived !!!
i assembled the GLB FF controller+ DJI frame + sunny sky motors.
did all the calibration (sticks + imu) stuff. so far so good.
tried it outside and had some strange behavior with this bird.
the first 3-4 seconds it hovers nicely stable in the air.the sticks are reacting as they should (pitch/roll yaw).
Then it starts to drift ; at first i thought it was the trims, but as long as i keep the quad in the air, the drift becomes worse & worse,until i have to give full left stick to correct it and the yaw barely reacts.
When i put it back on the ground(set the trim back to neutral) and wait for about 3 seconds, it starts again with a perfect hover and 3 sec later...
I checked with the program via USB and i see no strange behavior.
i move the usb connected quad in all directions & the pitch/ roll/yaw shows a perfect flat line.
any idea's someone?
Julkabas is offline Find More Posts by Julkabas
Old Jan 14, 2012, 05:55 PM
jesolins is offline
Joined Feb 2007
Hi J,
--Are your neutral settings for pitch roll and yaw at zero in the ZN FF setup application after you do the Tx/Rx setup?
--Are you doing the setup with zero trims and subtrims and no mixing and ACRO set in your Tx?
--Are you going from a warm to a cold outside temperature to fly without first letting the model acclimate to the temperature change for 10-15 minutes before a flight?
--Did you do the ESC throttle calibrations?
Cheers,
Jim
Originally Posted by Julkabas View Post
Hi Guy's
any idea's someone?
Old Jan 14, 2012, 06:00 PM
willi_m is offline
Find More Posts by willi_m
Calgary, Alberta
Joined Mar 2007
The board is flying well after some PID's tuning. LiPo alarm was setup for 10.9 V but never get buzzed. The battery at the end of flight was 8.9 V.
BTW is there is any way to see the current PID's values loaded in device?
willi_m is offline Find More Posts by willi_m
Old Jan 14, 2012, 06:11 PM
Julkabas is offline
Belgium
Joined Dec 2010
Originally Posted by jesolins View Post
Hi J,
--Are your neutral settings for pitch roll and yaw at zero in the ZN FF setup application after you do the Tx/Rx setup? checked: yes
--Are you doing the setup with zero trims and subtrims and no mixing and ACRO set in your Tx? checked: yes (i copied the settings from my gaui 330; just changed the reverse to all normal )
--Are you going from a warm to a cold outside temperature to fly without first letting the model acclimate to the temperature change for 10-15 minutes before a flight? Ooops.. never had any temperature problem with the gaui, but yes it is a lot colder outside
--Did you do the ESC throttle calibrations? Checked : yes
Cheers,
Jim
conclusion: maybe a temperature problem.
but wait.. stupid me.. i try it inside.. ill be back!
Old Jan 14, 2012, 06:25 PM
Julkabas is offline
Belgium
Joined Dec 2010
same problem.... starts nice, then drifts. we had some chilli con carne, but there is no wind inside our home
some other thing i remarked:
if the quad is armed, i can spin the props by hand, they make a few spins.
if i disarm & disconnect the battery, the props are kind of "magnetized" ; i can spin but there is a resistance. After a while(10 minutes i guess) they can spin freely again.
Maybe that has something to with my problem?
cheers.
Old Jan 14, 2012, 06:33 PM
timecop is offline
Joined Dec 2010
Throttle cal on all esc done? Brake off?
Old Jan 14, 2012, 06:43 PM
Julkabas is offline
Belgium
Joined Dec 2010
redid calibration via switch on CH5 and "swing the sticks" in all directions; ending with full throttle. result:no difference
tried later with RC CAL button in app.
result: no difference.
sorry but what do you mean by" brake off" ? can find no brake settings in the app or in my spektrum dx6i. Maybe i overlooked something?
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
