Old Jan 13, 2012, 04:05 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Guys, I made a short video about my Yaw problem. I left alone PID settings for pitch and roll as they seem to be quite good. But Yaw is a nightmare. The quad spins to the left a bit just by itself. Left rudder works a bit, right rudder almost no effect, maybe it stops slow left self spin.
I tried to increase and decrease Yaw_Stick value from 10 to 14, then to 4 and it did not make any noticeable difference. I did the same with Yaw P and D value, increase nor decrease does not make any difference. I might try extreme value, my defaults were 100 and 120, but I am not sure if I should enter 200+ or so.
I will try to change the props to 11x4.7 for test.
I am lost now and I am not sure if its my setup or something but considering roll and pitch work well I would not think it is motor/ESC/prop problem.
http://www.youtube.com/watch?v=vrlJn...ature=youtu.be
alek3d is offline Find More Posts by alek3d
Old Jan 13, 2012, 04:24 AM
Nosepo is offline
Find More Posts by Nosepo
Spain.
Joined Jul 2009
Originally Posted by Mike Barton View Post
The orientation is correct in the pictures (and is shown wrong in some of the manuals!)
The way to easily work it out is that the buzzer is always orientated to the back (tail motor for + config) of the copter
HTH
Originally Posted by jaccies View Post
yes this is the right picture, both arrows showing front direction of the frame.
Thanks to bothˇˇˇˇˇˇ
Nosepo is offline Find More Posts by Nosepo
Old Jan 13, 2012, 04:25 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
alek3d - I have tried out QUAD+ with V1.22
My TxRoll&Pitch stick is nowhere near as strong as yours in your video, but my Yaw works fine - similar effectiveness as Roll&Pitch
I'm using Turnigy 9X + FrSky and using default software with default end-points (100%)
Your TxYaw works fine in GUI, so that is OK.
Others are using same firmware as yours, so that is not the problem.
I can only think it is a problem with the Gyro:Yaw
Mike Barton is offline Find More Posts by Mike Barton
Old Jan 13, 2012, 04:35 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Its a 3 axis gyro, unless one axis is dead?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 13, 2012, 04:46 AM
alek3d is offline
Slovakia
Joined Nov 2010
Well, it nicely shows angles on all three axis in the PC.
Old Jan 13, 2012, 04:49 AM
United Kingdom
Joined Nov 2008
I agree, very unusual for just 1 axis to have a problem, just I can't think of any other possibilities.
Maybe it got partially damaged when soldered ?
dunno ...
Old Jan 13, 2012, 05:18 AM
alek3d is offline
Slovakia
Joined Nov 2010
Even if gyro is dead, when applying control by stick, shouldn't be gyro&acc omitted? It should do what I command, right? When stick released then it should lock the position using gyro, is it not like that?
Old Jan 13, 2012, 05:21 AM
United Kingdom
Joined Nov 2008
Sort of: the gyro will resist the stick movement to some extent, so this is why I considered it to maybe be the problem...
So maybe it is resisting far too much (?)
Old Jan 13, 2012, 05:48 AM
alek3d is offline
Slovakia
Joined Nov 2010
I wrote email to GLB, I wonder if they respond. I might return the board, I would not like to change the FW, maybe it's faulty....
Old Jan 13, 2012, 06:24 AM
eaton is offline
Find More Posts by eaton
Boston
Joined Mar 2006
PID setting
Originally Posted by snapper1234 View Post
PID Debug for v1.24 with english Button´s
Hi Snapper,
My firmware is 1.21 and working fine.
In order to use PID setting program you attached, should I upgrade the firmware to 1.24 ?
Eaton
eaton is offline Find More Posts by eaton
Old Jan 13, 2012, 07:49 AM
alek3d is offline
Slovakia
Joined Nov 2010
dunno ...
I will still try to play more with PID. In MultiWii roll and pitch PIDs are similar, but Yaw were different. I and D values were zero and then the response we ok, otherwise lazy. I will go to extremes and will set Yaw D value to 0 and see what happens. If only I know what ranges are for PID values, like in MWC 50 was max. D was in fact negative value etc. Here, I miss all that information.
My board actually tries to do something, it does left rudder a bit and right rudder too but very very weak. Maybe it just needs correct settings for my setup. I've noticed most of quads here are higher kv motors, mine are 980 kv, not particularly low but much less than those small quads with 1200 kv motors...
Anyone flying 1000 kv or less with this board?
Old Jan 13, 2012, 07:58 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Alek,
Mine is setup with my standard build of well balanced 750Kv motors, APC1047 props, RCTimer SimonK fast PWM ESCs and 55cm diameter and 1.2Kg AUW. The defaults are used for FF v1.22 and the yaw response is good. It holds heading nicely. I did add some rate in my Futaba 9c Tx to 120% on the yaw dual rate to make it faster. I used -40 expo on pitch and roll and 70% dual rates.
Did you take care to check you motor tilts? Are your motor/prop vibrations low at hover speeds and your shafts running true and straight?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jan 13, 2012, 08:08 AM
alek3d is offline
Slovakia
Joined Nov 2010
Originally Posted by jesolins View Post
Alek,
Cheers,
Jim
Well, the frame looks ok, I used square 10x10mm oak (so quite stiff) and motor mounts made from plywood, should be straight when screwed to square, no reason to be out of right angle. I check them from sides and they look ok. Motors are brand new SunnySky 2212 980 kv, I do not hear noticable vibrations. Props are crappy 10x6 from HK, but I balanced each with my magnetic balancer so should be quite ok.
If nothing works tomorrow I will take HK board from my tricopter, reflash it to quad + and try in this frame to make sure it's not my setup.
Old Jan 13, 2012, 08:41 AM
jesolins is offline
Joined Feb 2007
Multicopter Mechanical Dynamic Neutral Stability setup 101
Alek,
Check your frame for neutral stability. Do this: Set your Tx trims to zero in yaw. Check that yaw trim is zero in the ZN setup. Use the PID setup application and set "1" in the yaw P. Do several one second barely hover "hops" and see if it always tries to yaw in one direction. If it does your motor tilt needs to be adjusted to negate this dynamic yaw and get to neutral stability. Sometimes it is only a hair of a change in tilt in the proper directions on the motor axis' that speed up to yaw in the weak yaw direction. It is a setup procedure that should be accomplished correctly and periodically checked especially after a "hard-landing" in order to get the best heading hold and yaw performance out of multicopters. Be sure to reset the yaw "P" value when you are finished. An indicator of bad mechanical dynamic neutral stability is weak yaw response in one direction and both motors on one axis being hotter than the other axis.
Also see Project Quads/Hexas/Octos TIP 7in the Quadrocopter and Tricopter Info Mega Link Index.
Cheers,
Jim
timecop is offline
Joined Dec 2010
so jim, what are you doing with this board. you're posting a lot in here, more than in uavp thread.
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
