Old Jan 11, 2012, 05:11 AM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
FF with BMP085
I soldered the BMP085 and the baro was detected and the measurement values were shown in the GUI.
I aktivated the check buttons for 3d and high lock control and made some test flights.
No change with channel 6 = on/off or channel 7 = on/off
It looks as if the values from the baro are fetched but not evaluated - what a pity.
(Or I was not able to detect any different )
quax is offline Find More Posts by quax
Old Jan 11, 2012, 05:52 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Originally Posted by foxlfoda View Post
Hello Team
can be used Lipo 4S With my board FF
Yes
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 11, 2012, 05:55 AM
alek3d is online now
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Originally Posted by timecop View Post
Yes
Are you sure? Manual mentions only 3S LiPo.
alek3d is online now Find More Posts by alek3d
timecop is offline
Joined Dec 2010
Yes, the switching regulator can definitely handle 4S and almost 5S, so are the caps. The low voltage alarm will probably not go off on 4S though, so youll need external one.
Old Jan 11, 2012, 06:14 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Actually, the LVA voltage can be set in the software - appears to go up to 16.8V, so should be fine for 4S.
Mike Barton is offline Find More Posts by Mike Barton
Old Jan 11, 2012, 06:16 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
My STM32 port of multiwii to CopterControl is progressing nicely.
I got virtual com port running over its USB connector, and multiwii-gui talking directly to it.
Note that's cycle time without sensor readings - just main loop with gyro/acc/mag. It won't be much worse for sensors onboard CC - accel can be read at 20mhz and ADC/analog gyro readings should also be fast. With I2C sensors its another story, but I'll get there when I get there.
Anyhow, why am I posting this in THIS thread is that if for some reason people will want to run multiwii on all these recent STM32 boards, it should be fairly painless to do so.
When was the now MultiWii
for the FF?
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jan 11, 2012, 06:18 AM
timecop is offline
Joined Dec 2010
Still don't have the board. Why don't you start coding? The source is open -> http://code.google.com/p/afrodevices/source/browse/
Old Jan 11, 2012, 06:37 AM
snapper1234 is offline
Find More Posts by snapper1234
snapper1234's Avatar
Germany, HB, Bremen
Joined Dec 2008
for the brave, v 1.24 available !
snapper1234 is offline Find More Posts by snapper1234
Old Jan 11, 2012, 06:39 AM
Slovakia
Joined Nov 2010
Any information about change logs? What is better comparing to 1.11 and/or 1.22?
Old Jan 11, 2012, 06:43 AM
Germany, HB, Bremen
Joined Dec 2008
sry, no information available, find out for yourself!
and pls report here !
Old Jan 11, 2012, 07:17 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Berhard
Did you try to use the SN v1.05? It has a slide control for height control adjustment influence.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jan 11, 2012, 08:37 AM
quax is offline
quax's Avatar
NRW, Germany
Joined Apr 2004
Originally Posted by jesolins View Post
Hi Berhard
Cheers,
Jim
No, I started with 1.21 and updated to 1.22c and I don't want to go back in versions. This GUI has only a radio button and no slide control.
But I want to test the BMP085 in my MultiWiiCopter. When the BMP085 is supported in a newer version, I can add the baro to the FF again.
Regards,
Bernhard
Old Jan 11, 2012, 08:44 AM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
Regards,
Bernhard
Maybe you could try 1.23 or the 1.24 snapper has posted today.
apejovic is offline Find More Posts by apejovic
Old Jan 11, 2012, 08:47 AM
apejovic is offline
Spain, CN
Joined Dec 2011
Is there anything about a newer ZNS versions?
I was searching in qq.com but could not find the FF thread (normally I read bbs.5imx.com). Could you please post the qq.com web where they are posting the updates?
Old Jan 11, 2012, 09:08 AM
jesolins is offline
Joined Feb 2007
Hi Bernhard,
You can load the SN v1.05 which has a slide control on your PC for any FF firmware. maybe the code hooks are still there If you need the older SN v1.05 setup application it is linked on the first page of this thread: http://www.cteammod.com/wp-content/u...S1002.msi_.zip.
Cheers,
Jim
Regards,
Bernhard
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
