Old Nov 16, 2012, 10:53 AM
voloelettrico is offline
Find More Posts by voloelettrico
voloelettrico's Avatar
Italia, Lombardia, Milano
Joined Oct 2010
Hello alek3d
I saw in the Frame ecilop network, are very beautiful and professional video to make important I think it is a good choice.
For now I have no problem to make professional videos, only at amateur level
however memorize in case of need.
thanks
voloelettrico is offline Find More Posts by voloelettrico
Old Nov 16, 2012, 01:05 PM
shuricus is offline
Find More Posts by shuricus
Moscow
shuricus's Avatar
Joined Feb 2012
Hi!
Can you please help me where to connect signals from Bluetooth RF Transceiver Module RS232 to FF white board to use with TC firmware?
- TXD:
- RXD:
- V
shuricus is offline Find More Posts by shuricus
Old Nov 20, 2012, 01:10 PM
Joined Oct 2010
FF Flight
Hello Rcjose
I did a flight with FPV quadricopter FF flight.
I have tried to do better with FF Flight
Here's the video
FPV_Con_Quadricottero_Nel Parco (3 min 32 sec)
Old Nov 20, 2012, 02:23 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Originally Posted by voloelettrico View Post
Hello Rcjose
Here's the video
http://www.youtube.com/watch?v=Wl6miCvfQU4&feature=plcp
Good work. The quad looks stable at higher altitude. Flying low to the ground always causing prop wash which makes the quad drift around. What camera are you using for FPV and recording video?
rcjose is offline Find More Posts by rcjose
Old Nov 20, 2012, 02:45 PM
Joined Oct 2010
Hello
The Cam is numbered WING2 HobbyKing
for me it is a good alternative to the GoPro etc. ... etc. ...
Old Nov 20, 2012, 03:44 PM
rcjose is offline
Joined Aug 2010
Hello
So I can assume that you are just recording video and flying it line of sight (looking at it). If so, that's not FPV. That's just recording your flight. FPV is where you are flying/controlling it by viewing what the camera views live.
Old Nov 20, 2012, 04:07 PM
Joined Oct 2010
Hello
I do not know if I understand you correctly? I try to explain.
I use 2 Cam (1 to drive FPV) (2 WING2 for registration FPV)
Old Nov 20, 2012, 04:41 PM
rcjose is offline
Joined Aug 2010
Hello
Ok, that makes sense. Yes, you are truly flying FPV then.
Old Nov 21, 2012, 02:22 PM
MrDusanmandic is offline
Find More Posts by MrDusanmandic
Closed Account
Joined May 2011
I just flashed my Free Flight FC with the Base Flight firmware but have a few questions / issues.
First, does anybody have a diagram on how the ESC's are connected and in which order, along with the receiver connections?
Second, I can arm the FC by pushing the throttle stick to the right, but I can't disarm when pushing to left.
Third, how do I make changes to the multiwii code that's on the FF board? I don't want the motors to spin upon arming it.
Any help is greatly appreciated.
MrDusanmandic is offline Find More Posts by MrDusanmandic
Old Nov 21, 2012, 06:12 PM
helizrnew2me is offline
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
set the travel on the rudder to 125 in both directions using the travel adjustment within the tx .that should allow you to arm/disarm
for motor stop you need to go into arduino sketch ,load up the sketch ,then define motor stop .
this video should help you
MultiWii Arduino Sketch mod and Upload (2 min 22 sec)
i had to learn this myself and once you figure it out its easy .i can make changes in seconds ,takes longer to upload the changes then it does to make them .be sure to save your sketch once done compiling it .
what version software are you using?
helizrnew2me is offline Find More Posts by helizrnew2me
Old Nov 21, 2012, 08:50 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Try the naze32 manual here: manual
I'm using my gear switch instead of just the sticks because of this.
Try using putty or Hercules to connect to the board directly and change the settings that way or use the interface provided by nicodh http://www.rcgroups.com/forums/showthread.php?t=1667516
thwaitm is offline Find More Posts by thwaitm
Old Nov 22, 2012, 10:01 AM
Closed Account
Joined May 2011
One of the confusing parts is, where is the baseflight "sketch" for me to modify and then upload to the FreeFlight board?
Also, in the Arduino IDE app, which board do I pick before I hit upload to update the sketch on the board?
Old Nov 22, 2012, 04:12 PM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
You don't need to alter sketches with baseflight32, settings are changed through CLI. Read the manual in the link thwaitm provided..
Might be worthwhile reading up here and here.
danger_mouse is offline Find More Posts by danger_mouse
Old Nov 22, 2012, 10:14 PM
Closed Account
Joined May 2011
Last question, why do all of the manuals for these boards say it can't be used on DJI frames?
Old Nov 22, 2012, 10:24 PM
Joined Sep 2010
vibration
if it wasnt for the low pass filters in multiwii my dji450 wouldnt be flying .tried it with no filter and it was bad . jitter-ed like mad.
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
