United States, TX, Richmond
Joined Aug 2010
Here is one on the US ebay site: http://www.ebay.com/itm/USB-To-RS232...item519f80b8da |
down and away arms on mine and down and towards disarms . have fun . ![]() if its cold out let the board adjust to temperature a bit before flying .my board doesnt like to go from a warm house to the cold and fly right away . let me know how yours does. |
Joined Oct 2012
I did have a problem with it not being level (basically unflyable) but thankfully the manual I downloaded from here detailed how to recalibrate the leveling via the transmitter. So much to learn. This thing was listed as RTF. Not even close for a noob!
![]() ![]() -> http://abusemark.com/store/index.php...products_id=38 Ready to plug in and for 20€ because the Chinese can hide. ![]()
those big 400 size heli blades whipping around can surely put a scare in ya . i went thru all the small helis ,then medium ones,worked my way up to the blade 400 and then sold out !..lol...... then i got hooked on these quads .even crashing them costs way less than a heli crash .a couple quad crashes didnt cost me anything..lol.others , a prop here and there .thats all. have fun |
Problems with FF C10
Hello to All
I had with FF C10 Firmware 1.30, same problem your lateral movement and forward. All tests are made in FPV. First test done only with TX calibration and IMU Calibration: result very moving. According to tests done in Quad level + IMU Calibration + (PID 1.24 -Snapper1234) Result very good, stop moving, Only small trim, TX. Thanks Snapper For now it's fine. |
i think i will start a free flight issues thread and see just how many are having this very same issue . |
Yes, I had the same problem, but as I wrote in my Post Now it looks like I solved the problem. Also try these changes. |
My point being that if his boards don't have an issue then it's not those components causing the apparent temp sensitivity... (I've not noticed anything like this with my FF yet though). Martin |
i have a kk2.0 coming soon so i will soon know for sure if its the board or something else going on . |
Joined Feb 2007
Hi H,
A 50F temp should not be an issue unless it comes from a room temp of 80F and not given any time to acclimate to the outside flying temps. http://www.rcgroups.com/forums/showp...postcount=5550 If you followed the info in that post and are still having issues it is very likely your gyro or accelerometer has poor solder that requires a re-flow to fix. So the contraction of the joints in cold temps is likely causing your flight performance issues. I flew my FF in 30F temps last winter and had no problems at all. Cheers, Jim Quadrocopter and Tricopter Info Mega Link Index |
but yes ever since the cooler weather has hit i have had many issues with the board .when its warm out i have no issues .it has been crashed but the board does not appear to have been compromised at all . thanks for your input . |
Joined Feb 2007
H,
Multicopter flight controllers can appear to look fine after a hard crash, but if the board was flexed even a tiny bit it, or sustained a high G shock it could compromise the solder under the MEMs devices. For those reasons to get higher flight controller survivability, the FCBs need to be protected by a roll cage and not secured directly to the arm points on a frame that can flex in a crash. To do further troubleshooting, look at the sensor traces and blow hot or cold air and press on the gyros/accelerometer to see if the traces go abnormal. Cheers, Jim Quadrocopter and Tricopter Info Mega Link Index Quote:
| Thread Tools | |
| Sold Complete MultiWii Quadcopter Flight Controller | madushan2008 | Aircraft - Electric - Multirotor (FS/W) | 3 | Aug 11, 2011 08:25 AM |
| Sold FY90Q Flight Controller for Quadcopter - $70 shipped | jpsabo | Aircraft - Electric - Multirotor (FS/W) | 1 | Jul 29, 2011 10:21 AM |
| For Sale Complete MultiWii Quadcopter Flight Controller Kit | madushan2008 | Aircraft - Electric - Multirotor (FS/W) | 7 | Jul 26, 2011 08:58 AM |
| Sold Multi Wii flight controller with auto level ver 1.7 | tc3wins | Aircraft - Electric - Multirotor (FS/W) | 1 | May 08, 2011 01:02 AM |
| Video Trex SE...3d flight with auto | Nick Maxwell | Electric Heli Talk | 10 | Dec 18, 2006 09:23 PM |
