Old Jan 04, 2012, 06:21 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
Originally Posted by chansen1953 View Post
ok guys, I have been playing with thsi FF board for quite a few weeks and I had a build thread posted on the Helifreak forum in the multi-rotor section..
I have bene re-writing the doco, and some of my work was re-posted in the goodluckbuy site as the "english" version of the flightcontol pdf.
I have added some further discoveries and issues and here is a re-write od some of the issue I found. it is attached as a pdf..
I am waiting on a new motor at present, and will confirm exctly how the software fine-tuning works and advise on the best way to achieve a good tunded and stable quad for both stabilised and 3d Mode.
I have not been able to get the rom flashed , as the rom flash loader seems to not recognise the usb-serial device, even though it is recognised by the Fluight Control application supplied. The usb-serial protect switch seems to do nothing, so any ideas here would be appreciated..
I am also waiting on some 9x5 tri-props to try, as opposed the the standard 10x4.5 props, with the A2122 motor.
The quad with FF board seems to fly fine, although I have not had time to try the fine tuning using the flight control app, and the low-battery warning does not seem to work,, so I am using a separate lo-lipo warning device as a safety measure.
Edit: the original pdf had some layout erros on thelast page.. so the "UPDATE_CJHV12" is the better version !!
Thanks a lot. I love the internet and forums like these!
Bmr4life is offline Find More Posts by Bmr4life
Old Jan 04, 2012, 06:45 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Thanks Chris! Finally some decent documents! You must be the "Chris" that they credit on the site. Unfortunately all their other "English" documents are a mess.
You mention that the device will in some cases remain unusable until calibrated. Some people here have had their boards become unsable after reprogramming. I'm thinking that reprogramming them erases/corrupts the eeprom with saved data and then they require calibration to continue.
HappySundays is offline Find More Posts by HappySundays
Old Jan 04, 2012, 06:48 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
There's no eeprom on stm32, and reflashing should only erase pages related to code, however that gives an idea, people with trashed boards, try doing a chip erase (all pages) instead of just code pages, if they're using last page as eeprom emulation and settings format changed between 1.x and 1.22 it probably reads them and fails.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 04, 2012, 07:36 PM
Quadframes is offline
Find More Posts by Quadframes
Quadframes's Avatar
Joined Jun 2011
anyone see this
http://u.youku.com/FlyFright
http://item.taobao.com/item.htm?id=13327534337
Quadframes is offline Find More Posts by Quadframes
Old Jan 04, 2012, 07:41 PM
C team MOD is offline
Find More Posts by C team MOD
Flying Like Evil
C team MOD's Avatar
France, Languedoc-Roussillon, Garons
Joined Oct 2010
Sorry for all the mess I've done on this English doc.... I ll try my best next time .....Chris
C team MOD is offline Find More Posts by C team MOD
Old Jan 04, 2012, 07:44 PM
timecop is offline
Joined Dec 2010
Originally Posted by Quadframes View Post
Have you added anything to the thread which hasn't been here before/
Old Jan 05, 2012, 01:26 AM
(Jo)Hannes is online now
Find More Posts by (Jo)Hannes
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
Originally Posted by whiteturbo View Post
Hehe, If JUERGEN says its crap then i buy.
made my day - Ray!
(Jo)Hannes is online now Find More Posts by (Jo)Hannes
Old Jan 05, 2012, 01:50 AM
anfarol is offline
Find More Posts by anfarol
anfarol's Avatar
Forli, Italy
Joined Dec 2001
Originally Posted by IceWind View Post
I'll get a rabbit board if I Can do this with the leds! =)
http://www.youtube.com/watch?feature...i3udOjKc#t=33s
You don't need the rabbit board to do this A little 8 bit PIC or Atmel micro can do that adding few components.
anfarol is offline Find More Posts by anfarol
Old Jan 05, 2012, 01:54 AM
timecop is offline
Joined Dec 2010
I could do that without rabbit board months ago
STM8S rainbow now with more brightness (0 min 20 sec)
Old Jan 05, 2012, 02:01 AM
anfarol is offline
anfarol's Avatar
Forli, Italy
Joined Dec 2001
http://www.youtube.com/watch?v=YgNSv0PYDNM
Yes, that's what I say
Old Jan 05, 2012, 02:37 AM
igalr is offline
Find More Posts by igalr
Joined Sep 2004
I have connected the FF to my quad frame (+) configuration and found out the motor numbers in the manual are not the same as channel numbers on the board.
The motors worked only when connected to channel marked 6,5,4,3
I am not sure if CW, CCW will work.
Is there any problem with my version ?
igalr is offline Find More Posts by igalr
Old Jan 05, 2012, 03:01 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
nice job, but the picture on the last page is not correct ...CW=ClockWise..CCW=Counter ClockWise
use the corrected picture in my post 414
which shows also the + and X mode
jaccies is offline Find More Posts by jaccies
Old Jan 05, 2012, 03:12 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
@HappySundays & Timecop
I read Chris's guides, but they don't really help much
I knew about the Calibration stage, but if I remember correctly, the Red LED had stopped flashing and the board was responding to Tx stick movements.
Also, the blue LED on the USB board was always flickering (sending data maybe?), but currently it's lit solid.
I realise that eeProm data is held in the program flash, so surely if you save the hex file from a board, it contains the updated 'eeProm data' - this is obviously different to say ATmega's.
I have tried the following (see pic)
Erase:All
Download to Device with Global erase
I would try knocking up a simple program to say flash an LED, but my 2 development setups are:
Atollic TruStudio Lite - so no hex files created ....
Rowley CrossWorks which the 1 month trial has expired ....
Mike Barton is offline Find More Posts by Mike Barton
Old Jan 05, 2012, 03:31 AM
timecop is offline
Joined Dec 2010
You can always try ghettoing it up with Eclipse+CDT and/or maybe Yagarto.. I dunno if they support STM32Fx series yet. I'm not sure if flash readback would include the flash-as-eeprom area... Does it? I never tried. In the file you saved, do you get all the pages?
Old Jan 05, 2012, 04:01 AM
Quadframes's Avatar
Joined Jun 2011
Yes these 2 links
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
