Old May 30, 2012, 12:09 AM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Originally Posted by jaccies View Post
@rcjose and other Spektrum DX?? transmitter users
Hi, a time ago you said this:
I am using V1.24 of the firmware and with my Spektrum DX6i and OrangeRX I had to reverse the throttle and aileron channels
i have also a DX6i and a HK Ra61E ( clone of AR6110E) receiver and had to reverse throttle also , what i found out today was very strange and scary,
may be you can test it also rcjose but be carefull if you test it, the best is to test it on the ground and remove the props !!!!!!!
I was flying , an other pilot asked me if this is failsave , what happens if you lose radio contact , i said lets simulate it and by switching off the DX6i , i brought the quad at higher level (because i would expect the motors would stop) and switched off the DX6i, yeah no failsafe the quad disappeared like a rocket straight up into the sky with full power, I switched on again the DX6i immediately , and could control the quad again , thanks to DX6i "quick reconnect" feature
you know with firmware 1.22 no throttle reverse, only with firmware 1.24.
Dont know if that what happened is related to a reverse throtlle??
Note: binding of receiver happens with low throttle of course.
OOPS i think about it just now : i will do a rebinding of the receiver , i cannot remember if i did this after setting the throttle to reverse
a shame if i forgot it
I had a similar issue with the quad on the ground but with my Turnigy 9X which has failsafe on. My TX LiFe battery went too low while testimg the quad and the TX turned off BUT the quad motors kept spinning. I wasn't at full throttle and the quad was still on the ground so I was safely able to disconnect the main lipo. But I can only imagine what would have happened if the quad had been hovering in the air!
rcjose is offline Find More Posts by rcjose
Old May 30, 2012, 05:25 AM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
i thought the 9X had no failsafe??
how do you set it? put stick/switches in failsafe position and bind the rx?
dutchcommando is offline Find More Posts by dutchcommando
Old May 30, 2012, 05:30 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
You're right, it does not. Only 3-channel HK receiver has FS on 1 channel. If you want FS then need to install FrSky module into T9X (like I have).
alek3d is offline Find More Posts by alek3d
Old May 30, 2012, 05:55 AM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
I see others answered Techasist that the soldering was ok, i just checked mine but is a 1.31 so it has a chip of some sort in that location between the SMT stuff.
Checked my brothers which is a 1.3 and his solder connections all seperate but they are connected electrically, as I did a con check with a DVM while looking at Techasists picture.
This was before i read the replies obviously.
On another note got the guts to try a flip or two yesterday, X400 RTF, FF 1.24 in 3D mode.
Works fine, does not drop to far but not as crisp as with Timecops port from what I see. Took a deep breath before first try though.
Will get round to flashing it with Multiwii at somepoint, may just build new one to use that though as I got a Naze32, motors and ESC's.
Del-Dredd is offline Find More Posts by Del-Dredd
Old May 30, 2012, 06:08 AM
Johnny Ace is offline
Find More Posts by Johnny Ace
Johnny Ace's Avatar
United States, TN, Bartlett
Joined Oct 2011
Another place to by FF boards
Here is another place that sells the Free Flight boards
http://www.omgfly.com/index.php?main...roducts_id=135
Sorry if it has been posted already.......just an FYI
Johnny Ace is offline Find More Posts by Johnny Ace
Old May 30, 2012, 06:20 AM
Del-Dredd's Avatar
Joined Aug 2004
Nice link, thanks.
Old May 30, 2012, 06:27 AM
techasist is offline
Find More Posts by techasist
techasist's Avatar
Australia, QLD, Flinders View
Joined Dec 2010
Success!
Thanks to all for your help.
I reflashed 1.24 and did RC and motor calibration.
Motors now spin perfectly.
As mentioned previously, servos don't work on PWM outputs 3,4,5 and 6.
techasist is offline Find More Posts by techasist
Old May 30, 2012, 06:54 AM
Del-Dredd's Avatar
Joined Aug 2004
Glad you got it sorted, now for the flying after IMU cal of course and putting in default PIDs for size..
Deyrick
Old May 30, 2012, 06:57 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
G,
Try this: Multicopter checklist for yaw issues 101
Do you get good yaw trace response in the ZN app?
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by GFTbak View Post
had the motor-problem also.
first no motor was rotating.
Then I kept on trying and all out of the blue 2 motors worked.
(I guess that was after I choose PWM on ZN-app + save settings to board.)
After that I saw that you had to take pwm-output 3-6 and not 1-4.
Then all motors worked.
Still having the eternal spinning-problem.
Can't seem to get that fixed.
Once in the air it yaw's to the right forever on and on.
jesolins is offline Find More Posts by jesolins
Old May 30, 2012, 08:03 AM
snapper1234 is offline
Find More Posts by snapper1234
snapper1234's Avatar
Germany, HB, Bremen
Joined Dec 2008
Originally Posted by timecop View Post
Yes, some guy on multiwii forum is already running baseflight on it.http://www.multiwii.com/forum/viewto...e40ffa5109e4e4
pity, he has killed the board http://www.multiwii.com/forum/viewto...tart=10#p14807
with the FF boards, it is gradually running out!
on ebay there are only still four sellers from Hongkong!
good outlook for your business
snapper1234 is offline Find More Posts by snapper1234
Old May 30, 2012, 09:01 AM
rcjose is offline
Joined Aug 2010
Sorry, forgot to mention that I have the FrSky transmitter module installed and am using a FrSky receiver.
Old May 30, 2012, 09:27 AM
Donnyv is offline
Find More Posts by Donnyv
Donnyv's Avatar
United States, MI, Traverse City
Joined Jan 2012
Originally Posted by techasist View Post
@ DonnyV:
My board won't move motors either.
Chose PWM in motor test tab and saved. Powered FF down and back on.
I tried to connect servos to the PWM 1-6 output and armed the FF board.
No success.
I give up!!! I have the worst luck with these darn boards!!
Donnyv is offline Find More Posts by Donnyv
Old May 30, 2012, 09:33 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Notice he got it fixed few posts later...
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old May 30, 2012, 09:51 AM
Donnyv is offline
Donnyv's Avatar
Joined Jan 2012
I sure did!! lol
Old May 30, 2012, 09:53 AM
Donnyv is offline
Donnyv's Avatar
Joined Jan 2012
well.... I just received my board 2 days ago!! so I'm a complete noob with this board at this moment!! I will keep trying!!
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
