Old May 14, 2012, 12:04 AM
windfou is offline
Find More Posts by windfou
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
i plan to use my ff board on a 25inch quad 620mm motor to motor so do i need to use the pid ajustement in the software or just do the rc calibration ? thanks
windfou is offline Find More Posts by windfou
Old May 14, 2012, 01:27 AM
DerRose is offline
Find More Posts by DerRose
Germany
Joined Oct 2010
Hey Jim
Try increasing your yaw P and D a few points at a time to get a tighter yaw response. First make sure your motor tilt is correct by doing a dynamic neutral stability setup and test.
I'll try it. But when I want to run the PID Parameter v1.24(2012-2-10) I got the mscomm32.osx error message. I'm running Win 7 68 bit, can someone support?
But as QIW wrote
well ... the quad flies very well with the KK board
MY Quad was fine with the KK. Here is an old picture of my FPV Quad.
BR
Michael
DerRose is offline Find More Posts by DerRose
Old May 14, 2012, 01:28 AM
andygilbert23 is offline
Find More Posts by andygilbert23
United Kingdom, England, Matlock
Joined Jun 2010
My guess is you will have to load in the default pid settings the nearest size, so 500mm and adjust from there which is what I'm doing for my 600mm quad.
But to which software you start with at the moment is anyone's guess as there is two pid software's both with very different default values.
Andy
andygilbert23 is offline Find More Posts by andygilbert23
Old May 14, 2012, 01:30 AM
Joined Jun 2010
@derose right click the software and select to run as administrator and make sure you have the OSX file in the same folder as the software exe.
Andy
Old May 14, 2012, 02:14 AM
DerRose is offline
Germany
Joined Oct 2010
Andy
Thanks Andy! That was quit easy
Old May 14, 2012, 02:57 AM
Joined Jun 2010
@DerRose
No Probs
Does anyone know if the PID accepts floating values? (decimal values)
Andy
Old May 14, 2012, 03:55 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I think PID stuff came from MK, so no
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old May 14, 2012, 07:15 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Q,
You certainly should have seen a huge difference when changing the P value that much. Did you send the settings?
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
i just swapped over the FF into this frame and electronics .. did the radio and ESC calibrations using the ZN software .. self leveling is not aggressive (i like that)
its just the yaw overshooting and extremely soft control/hold problem ..
maybe i will just play around with the PID settings (somehow i feel whatever figures i throw it does not get written into the FF)
changed yaw P & D values ranging from 50 - 150 does not seem to have any effect .. or should i be playing with the ROL values ?
jesolins is offline Find More Posts by jesolins
Old May 14, 2012, 07:28 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
Originally Posted by jesolins View Post
Q,
Cheers,
Jim
sent .. and saved as well (after sending)
the chinese characters says "values successfully uploaded" ..
stick controls and sensors all working perfectly in the ZN software ..
QiW is offline Find More Posts by QiW
Old May 14, 2012, 07:35 AM
jesolins is offline
Joined Feb 2007
Hi Q,
OK good. Is that with the slider PID utility version? I've only been using the PID v1.24 linked on the first page, so those defaults seem to be OK. I was able to increase the P by 7 points on my build. Yaw is default for me and responds well. Setting up dynamic neutral stability is key to success there.
Cheers,
Jim
Old May 14, 2012, 07:38 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
i am running firmware 1.22C currently (or so it says on the ZN software)
so i am using the PID utility for 1.22 that has no slider ... maybe i should try the one with the slider
will try and do that and see what happens
Old May 14, 2012, 07:46 AM
Papiti is offline
Find More Posts by Papiti
Belgium, Walloon Region, Beauvechain
Joined Mar 2012
Andy
Hi Andy, hi TC,
I put both OSX file and PID 1.24.exe in a PID directory in c:Windows/System32, but I still get the error message when I follow your procedure.
TC, you recommended to "open (elevated on vista/7) command prompt, cd to \windows\system32, and type 'regsvr32 mscomm32.ocx", but my poor English doesn't allow me to exactly understand what to do.
Could you please explain it to me in very simple words?
Papiti is offline Find More Posts by Papiti
Old May 14, 2012, 07:50 AM
jesolins is offline
Joined Feb 2007
Q,
I recommend that you upgrade to FF V1.24 first.
Cheers,
Jim
Old May 14, 2012, 10:30 AM
windfou is offline
windfou's Avatar
Joined Dec 2008
for Jesolins
Old May 14, 2012, 12:00 PM
windfou is offline
windfou's Avatar
Joined Dec 2008
i just downgrade to 1.24 and the download with the bootloader was succesful but now my board flashing a red ligth and can't see any activity in the set up software
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
