Old Feb 23, 2012, 06:39 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
OK, just checked 0219 code on my freeflight with default buzzer and powering it by 5V from a BEC. It works as expected - if you get continous tone, something on your hardware is broken.
Buzzer on afroflight32 only works when powered by ESC - it will NOT beep with only USB power. This is by design.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Feb 23, 2012, 07:04 PM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
My afroflight32 is perfect and works exactly as it should, looking at it ,its hard to believe its in anyway related to the Freeflight FF.
Ive soldered two pinheaders where the buzzer used to be on the FF, so tomorrow i will revert it back to a freeflight and test it, if i cant find anything wrong, then i will redo what after all is a very simple mod. Its not really important,but it just bugs me, i hate unexplained faults.
Ray
whiteturbo is offline Find More Posts by whiteturbo
Old Feb 23, 2012, 07:09 PM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
Could somebody post their experience flying the FF with original firmware and doing it with the multiwii port?
Im very curious to know how a properly seted multiwii code on the FF compares to the standard firmware.
apejovic is offline Find More Posts by apejovic
Old Feb 23, 2012, 07:17 PM
timecop is offline
Joined Dec 2010
It doesn't hurt anything to switch back and forth. You're welcome to try
Motor numbering becomes proper (1..6)
and motor order for QuadX is in this manual > http://www.abusemark.com/downloads/naze32_rev1.pdf
Latest firmware downloads are at
http://code.google.com/p/afrodevices/downloads/list (look for "baseflight" stuff)
Old Feb 23, 2012, 07:36 PM
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
Hiya,
Sorry to keep banging on but i have reverted my FF to run on the JST/Lipo again and the buzzer now works as expected, infact everything works as expected so maybe i have to disable the regulator as well, this is all too much for a poor humble retired carpenter to get to grips with, but by the dogs dangly bits i wont let it beat me.
@apejovic
Greetings(does the spock four finger salute) In my humble opinion the freeflight FF with the firmware it comes with, or updates too, is incomplete. The stable setting works as long as there is very little wind and the 3D mode is terrible, its half stable and half unstable, in 3d mode the accelerator should not be working at all so that you can do stunts without fighting it. Maybe the chinese developers will correct that in the next update, but im not going to hold my breath waiting.
With timecops port you have a multiwii that is blisteringly fast with absolutely no I2C bugs, the only fault i can find with it is it hasnt got a barometer or magnetometer onboard,(ask timecop and he can sort that for you ) the gyro's are accurate and the acc works fine. If you gave it to Warthox he would be able to throw it all over the sky. He would think you were taking the mick if you gave him a standard Freeflight FF
Ray
Old Feb 23, 2012, 08:16 PM
snapper1234 is offline
Find More Posts by snapper1234
snapper1234's Avatar
Germany, HB, Bremen
Joined Dec 2008
Originally Posted by jesolins View Post
Gents,
I modified my diagram to help clarifly prop nomenclature. Does this work for you?
Also FYI APC just adds a (P) for pusher prop.
why work with names that no other understands?
snapper1234 is offline Find More Posts by snapper1234
Old Feb 23, 2012, 08:56 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
S,
Do you mean non English speaking individuals who have never seen an analog clock?
OK...I'll put arrows on the diagram
Something for everyone Done.
Thanks and Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Feb 24, 2012, 12:40 AM
X--ALIEN--X is offline
Find More Posts by X--ALIEN--X
One with the machine
X--ALIEN--X's Avatar
Antarctica
Joined Jul 2010
S,
Thanks and Cheers,
Jim
How can this be challenging for anyone?
X--ALIEN--X is offline Find More Posts by X--ALIEN--X
Old Feb 24, 2012, 02:41 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
S,
Thanks and Cheers,
Jim
Jesolins, the confusion did not start for not undestanding what is CW or CCW - at least not for me. I know what is clockwise and counter clockwise. The problem was that motor was marked spinning clockwise, so use counter clockwise prop. Now go figure.... is it not silly?
alek3d is offline Find More Posts by alek3d
Old Feb 24, 2012, 03:10 AM
jesolins is offline
Joined Feb 2007
Hi Alek,
Semantics can be silly and confusing for anyone. Snapper is correct that the arrows should tell the tale on how the props should rotate and that is the simplest which is normally the best. Hopefully the diagram will now answer everyone's questions on this without causing confusion. If not then let me know. I'm only trying to help interested Gents understand multicopters and their proper setup
Cheers,
Jim
Old Feb 24, 2012, 06:12 AM
lebrett is offline
Find More Posts by lebrett
France
Joined Nov 2008
Hi Timecop,
With this firmware uploaded with Fdti, we can run the Free Flight with Multiwii code ?
I'm a bit lost with all the post around there in this thread
lebrett is offline Find More Posts by lebrett
Old Feb 24, 2012, 06:28 AM
timecop is offline
Joined Dec 2010
I wish the guys who keep posting this propeller rotation crap would get their own thread, too
Originally Posted by lebrett View Post
Hi Timecop,
Yes, kind of like running FreeFlight with MultiWIi code.
You upload this firmware using same instructions as you use for FreeFlight firmware. Then it becomes multiwii-compatible. However must use latest WinGUI or MultiWiiConf-20120219 to configure it. And use can use standard or CPPM receiver.
Old Feb 24, 2012, 06:43 AM
lebrett is offline
France
Joined Nov 2008
That's clear, thank you.
Do You mean PWM or CPPM receiver in the last sentence , I think.
Old Feb 24, 2012, 06:46 AM
timecop is offline
Joined Dec 2010
Correct. I prefer CPPM since it only takes one wire.
Old Feb 24, 2012, 07:00 AM
lebrett is offline
France
Joined Nov 2008
I agree with you Frsky rules ...
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
