It looks like mine need a LOT of work to get them to balance vertically.. I have the HK magnetic balancer. |
United States, TX, Richmond
Joined Aug 2010
I follow this video from the guys at flitetest: http://flitetest.com/articles/ways-t...ce-your-props/ |
Hiya
,Just done this with my Free flight FF because i dont like my board getting fed with 12v only problem the buzzer is on constantly. I aught to mention that i have flashed it with timecops 0219 code. Should i just remove the buzzer or is it indicative of something else Ray ![]() ![]()
Joined Feb 2007
WT,
Since you have TC's code loaded, does the the multiwii setup utility connect work? You can certainly disconnect the buzzer and then wire it off-board later ![]() Cheers, Jim Quadrocopter and Tricopter Info Mega Link Index Quote:
Hi J, Everything works OK in the multiwii GUI except the buzzer is showing up as movement on the gyro and acc. I have infact just removed the buzzer anyway as i never did like an electromagnetic force so close to sensors, now everything in the multiwii GUI and the new WinGUI works as it should , my only concern is i have only removed the noise and interference not the actual cause of the buzzer being activated, i would like to connect the buzzer as its nice for confirming changes etc, i wonder if its just telling me low voltage as its now only getting 5v instead of 12v. Can anybody who has actually done the mod to remove the JST feed got any comment ![]() Ray ![]() ![]()
Joined Dec 2010
The buzzer on free flight should be same connection as on Afro. And I know it works there.
Does it always just beep without any changes or does it make some attempt to stop beeping in beginning.. Low battery alarm isn't implemented yet... I think? So it shouldn't be that. Battery is measured but divider is not properly set, so voltages would be wrong. |
@HappySundays, oops yes i missed that, that was my thought too but i think timecop thinks different.Did your buzzer have to be removed?
@timecop, the buzzer was on constant from the time i plugged the BEC in, all i did was solder a line between motor live and RX live and everything else checks out OK, Who needs a frigging buzzer anyway LOL |
Joined Dec 2010
Hm, that doesn't sound right, my freeflight I also bypassed (well, totally desoldered) the switching regulator and power from 5V, but buzzer is on as normal. You sure you didn't short something? Old version of code had buzzer inverted, so when it was off in software, it would be on, but in that case you could hear the startup beeping and calibration beep etc. If it's solidly on I'm guessing either something is shorted or maybe you shot that gpio pin that it's connected to somehow.
![]() @timecop, i dont see how even i could be that incompetent, after all it was only soldering two joints and one little wire and ive even checked them under the magnifying glass to make sure, and i didnt remove the buzzer until after, to stop it buzzing. Oh well just have to go buzzerless on the FF
| Thread Tools | |
| Sold Complete MultiWii Quadcopter Flight Controller | madushan2008 | Aircraft - Electric - Multirotor (FS/W) | 3 | Aug 11, 2011 08:25 AM |
| Sold FY90Q Flight Controller for Quadcopter - $70 shipped | jpsabo | Aircraft - Electric - Multirotor (FS/W) | 1 | Jul 29, 2011 10:21 AM |
| For Sale Complete MultiWii Quadcopter Flight Controller Kit | madushan2008 | Aircraft - Electric - Multirotor (FS/W) | 7 | Jul 26, 2011 08:58 AM |
| Sold Multi Wii flight controller with auto level ver 1.7 | tc3wins | Aircraft - Electric - Multirotor (FS/W) | 1 | May 08, 2011 01:02 AM |
| Video Trex SE...3d flight with auto | Nick Maxwell | Electric Heli Talk | 10 | Dec 18, 2006 09:23 PM |
