Old Dec 01, 2011, 12:57 PM
Flying Like Evil
C team MOD's Avatar
France, Languedoc-Roussillon, Garons
Joined Oct 2010
Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter
Hello
Does anyone know something about this Board.
Description:
- 100% brand new four axis Free Flight FF Auto Balance Controller,it can be used without debugging.
- Support 8 channel PWM input and Six channel PWM output
- Adopts three axis digital gyroscope and three axis digital accerleration sensor.
- Auto-balance,quadcopter X or+mode
- Support commercial ESC and I2C ESC
- Support aerial photography and Dual axle stabilization PTZ
- with beep function when voltage is lower than 10.8V
- recommend work with GWS 3-blade paddles or other high performance balance paddles
Wire Connection:
- Input CH: 1, Aileron/ flap 2 Lift and down 3,accelerograph 4,Heading Direction 5,Remote control calibration( Switch channel) 6,PTZ pitch angle 7, PTZ pitch angle trimming(ratio CH input)
- Output CH(PWN): 1, PTZ Pitch angle servo 2, PTZ roll servo, 3, No.1 motor input 4,No.2 motor input 5, No.3 motor input 6,No.4 motor input
Dual axis PTZ:
- It maintains verticality mode under 6CH Auto-mode.It can be trimming by button 7 to adjust angle.
http://www.goodluckbuy.com/free-flig...on-sensor.html
UPDATE HARDWARE
THREAD UPDATE 03/01/2012
YOU MAY BE INFORM THAT THERE IS A DANGER TO UPDATE FIRMWARE.
Firmware :
111
120
122c
124
Upper Machine :
Version 1.0.5
Version 1.0.7
Flash Loader :
Version 2.2
Version 2.4
Flash loader GUIDE FR
Manual
English UPDATE 05/04/2012
French
Chinese
Driver
XP
Schema
Free Flight schema
Pid&Tricks
FF PID v1.22
FF PID v1.24
FF PID Adjustments 101
FF yaw issues and mechanical neutral stability setup 101
Multicopter Mechanical Dynamic Neutral Stability setup 101
BE INFORM
Some people report to be aware about reseller : find below message that I ve received
Can you place a sticky note for the thread titled "Do Not Buy FF Board From These Ebay Sellers" and place this message?
An Ebay Seller "Vocanlo" is selling what is supposed to be an original FF board on ebay for $65.00 US dollars. The board is not the original FF board but the newer version and several buyers have reported that the boards are DOA. In adddition, the newer FF board can be purchased for less via other sellers. Please avoid purchasing from this seller.
C team MOD is offline Find More Posts by C team MOD
Old Dec 01, 2011, 01:13 PM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Huh, I would like to know more too. That looks very interesting. 50 bucks for something with auto-leveling and a LiPO alarm? I want that.
WiseDuck is offline Find More Posts by WiseDuck
Old Dec 01, 2011, 02:36 PM
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
what software does it run?
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Dec 01, 2011, 02:54 PM
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
- the new year means STM32 -
ARM 32-bit Cortex™-M3 CPU Core
– 72 MHz maximum frequency,
1.25 DMIPS/MHz (Dhrystone 2.1)
performance at 0 wait state memory
access
– Single-cycle multiplication and hardware
division
■ Memories
– 64 Kbytes of Flash memory
– 20 Kbytes of SRAM
GYRO;
very good MPU3050
ACC;
ADCL345
Plug_and_Fly
- > http://www.goodluckbuy.com/images/de...shGuideGLB.pdf
and to understand the configuration / calibration, it does not speak Chinese.
- > http://v.youku.com/v_show/id_XMzIxMzA4MDky.html
very nice,
why more use a ITG3200,
if you can have one MPU 3050.
LSB/°/sec ---- 65,5
dps/√Hz ------- 0,01
better schema, without lettering taobao;
-> http://www.rcgroups.com/forums/showa...5&d=1325634822
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Dec 01, 2011, 03:17 PM
Flying Like Evil
C team MOD's Avatar
Joined Oct 2010
It looks as a PLUG AND PLAY, but "wierdly" I can't find any information about this board.
If the description is true, could be great
Old Dec 01, 2011, 06:25 PM
I'm new here
timecop's Avatar
Joined Dec 2010
Looks like STM32 processor, ADXL345 accel, and maybe some I2C gyro, IDG3200 or so.
onboard switching regulator for power, so nothing should heat up. The price is definitely right. Nice to see China going with proper technology. Maybe AVRTurds will follow soon.
Who's gonna buy one?
timecop is offline Find More Posts by timecop
Old Dec 01, 2011, 06:40 PM
Joined Jun 2006
maybe it s an aq50d pro copy...(same hardware..)
titeuf007 is offline Find More Posts by titeuf007
Old Dec 01, 2011, 07:06 PM
I'm new here
timecop's Avatar
Joined Dec 2010
It isn't. I'd be flattered if they used my multiwii port to STM for this, but that's unlikely. Maybe its a DJI NAZA clone, lols.
Old Dec 01, 2011, 07:15 PM
Joined Jun 2006
it will be great
Old Dec 02, 2011, 02:03 AM
Fingrene i maskinen
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Is that BMP085 pads?
SebastianJ is offline Find More Posts by SebastianJ
Old Dec 02, 2011, 02:07 AM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
They seriously need some documentation for that thing. Distance between holes, what kind of voltage does it run on, how do you change from X to +, how is it mounted (I see no arrow for the flight direction) and so on. I might order props from that website soon and I want to add this thing to the order since every other similar FC (Miniwii, Openpilot etc) is constantly out of stock. Grrr.
Old Dec 02, 2011, 02:46 AM
manuLRK
Belgium
Joined Sep 2004
FreeFlight
alll is offline Find More Posts by alll
Old Dec 02, 2011, 03:09 AM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Originally Posted by alll View Post
Broken image/attachment.
Old Dec 02, 2011, 03:30 AM
Flying Like Evil
C team MOD's Avatar
Joined Oct 2010
I suppose blue arrow show front board
Description:
Old Dec 02, 2011, 04:12 AM
Joined Feb 2007
i might if you do
Sold Complete MultiWii Quadcopter Flight Controller madushan2008 Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2011 08:25 AM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
Sold Multi Wii flight controller with auto level ver 1.7 tc3wins Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2011 01:02 AM
Video Trex SE...3d flight with auto Nick Maxwell Electric Heli Talk 10 Dec 18, 2006 09:23 PM
