Old Nov 30, 2011, 08:05 PM
whosthebaddest is offline
Find More Posts by whosthebaddest
Joined Nov 2010
LRS UHF TX antenna Choices? REcommendations?
Can people please recommend specific antenna's for UHF output TX LRS to increase range/higher dbi
I would like something to attach to the unit itself. Or perhaps especially a magnetic antenna for on top of the car.
Looking for a long range antenna to increase the range of the LRS UHF device to maximize its capabilities.
I prefer to order a antenna in the US and not from China, because of shipping times mainly.
Got any specific recommendations?
What do you guys like? Should be around 436mhz from what I've read.
or I guess a 433mhz antenna also is fine? The antenna part is confusing me.
Also what about these Scanner antennas they have at Radio Shack? (only because its the only antenna store in the area)
the antenna from RS is rated from 25-1000mhz but I figure its probably horrible for this application? Thanks again!!
Maybe you could recommend something specific even if in China?
Thank you VERY much!!!
whosthebaddest is offline Find More Posts by whosthebaddest
Old Nov 30, 2011, 08:23 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
http://www.l-com.com/familylist.aspx?id=3218
gundamnitpete is offline Find More Posts by gundamnitpete
Old Nov 30, 2011, 09:07 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
This is the one I was thinking about.
http://www.universal-radio.com/catal...antm/3243.html
How far do you want to go? I have been out 7 miles with similar antenna without base just fixed to TX.
vertcnc is offline Find More Posts by vertcnc
Old Nov 30, 2011, 10:33 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
When i purchased my EZuhf, Sander recommended a Diamond SRH771.
Kev.au is offline Find More Posts by Kev.au
Joined Nov 2010
Gundamnitpete Thanks bro. Its funny I was looking at that website at that line of antennas also.
Vertcnc: Cool dude, sorry about yesterday.
Do you mind me asking what type of video TX and what type of antenna you use on the receiver end of the Video? Yagi?
I only want to go a few miles maybe 3 for starters.
You must get a lot more range in the air then you would leaving a plane on the ground and driving away and testing range from one flat point on the ground to another. seems like a lot less interference up there
Thanks everyone
Old Dec 01, 2011, 08:09 AM
vertcnc is offline
Illinois, USA
Joined Aug 2009
whosthebaddest,
I normally use 1 watt 1.3 GHZ Lawmate TX with Lawmate RX. Homemade Vee Antenna or dipole on TX and $12.00 ebay Yagi on RX.
I have also used 2.4 Ghz video with similar results. I haven't ran out of video range yet, batteries (flying time) is limiting my range right know. I also adding a tracking device, not fun walking through 7' tall corn looking for a toy.
Old Dec 01, 2011, 08:16 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
This antenna is a pole mount, and is so large and directional, I do not think it will work very well. It will loose a lot of performance a few degrees above the horizon. The antenna I shipped with your unit has very good perofrmance, aside from that I would use a magnetic car mount antenna if you want an external antenna. You are correct, the wide band antenna from Radio shack is great for a scanner, but would be horrible for a Dragon Link. My question is, how far do you want to go ??? The antenna you have will probably outperform your video system and plane already.
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Dec 01, 2011, 09:40 AM
vertcnc is offline
Illinois, USA
Joined Aug 2009
I currently use stock 1/2 wave antenna with the DL. I aslo have a magnetic sma base so when flying from within vehicle or under tailgate hatch I move the stock antenna from the TX to the base.
New Product Turnstile UHF RX antenna for your LRS IBCrazy FPV Equipment 249 Jan 21, 2016 10:13 PM
Discussion Range testing Scherrer UHF without the TX antenna? whosthebaddest FPV Talk 3 Nov 18, 2011 08:08 AM
Discussion 1/2 Wave UHF TX antenna pc_pilot FPV Talk 16 Nov 17, 2011 11:26 AM
For Sale Thomas Scherer UHF LRS TX+RX firefly_joe Aircraft - General - Radio Equipment (FS/W) 0 Jul 08, 2011 01:37 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
