This thread is privately moderated by Greg Gimlick, who may elect to delete unwanted replies.
Old Nov 30, 2011, 01:02 PM
Greg Gimlick is offline
Find More Posts by Greg Gimlick
Trader Rating: 25
Greg Gimlick's Avatar
Fuquay Varina, NC
Joined Dec 2000
Trader Rating: 25
Sold
Graupner IFS MX-16 Tx & XPS 8ch Rx
I'm selling my MX-16 so I can get the new XPS radio when it's finally released. I'm including one full range 8 ch receiver with this set. There is no charger with it, but it uses the same polarity as a JR wall wart. The radio is like new and fully functional. All manuals are included with the original box.
Asking $160 plus shipping to the US
maelectrics@gimlick.com
MX-16
8 Channel Computer Radio System
This computer radio control system features twelve model memories, the most advanced (yet simple to use) programming technology, a high-contrast graphic LCD screen, removable antenna, stylish case, rotary function wheel, buttons and knobs for all popular control functions, and more! Fully compatible with ALL existing XtremeLink and iFS receivers. Retail price is $299!
System Includes:
(1) MX-16 8 channel 2.4GHz transmitter with 1700mAh (or larger) NiMH transmitter battery
(1) XPS 8 ch full range rx
Transmitter Specifications:
Frequency band: 2.400GHz to 2.4835GHz
Control functions: 8 functions
Servo resolution: 65,536 steps (16-bit)
Temperature range: -25C to +125C
Operating voltage: 9.6 to 12.4 V
Current drain approx. 185 mA
Dimensions approx. 195 x 190 x 85 mm
Weight approx. 850 g including transmitter battery
Detailed Information:
Microcomputer radio control system. High speed microprocessor using the latest 2.4GHz RF technology created by Xtreme Power Systems.
Bi-directional communication. The best link is one where the transmitter knows if the receiver got its data! If the receiver does not acknowledge
that it got its data, the transmitter will it is immediately resend the data (over and over if necessary) until the receiver
responds. Telemetry support also possible with bi-directional communications.
No crystals, no frequency conflicts. Simultaneous use of up to 120 Graupner transmitters possible without interference. Not affected by other 2.4GHz
radio systems.
Ultra-fast transmission rate. 250Kbps over-air data rate gives the fastest possible response.
Rejects interference. Completely immune to EMI and other electrical noise caused by electric motors, servos and metal-to-metal contact.
Stubby antenna. Folding and removable allows for easy storage, and prevents broken antennas.
Transmitter operation and programming. The most advanced programming technology available. Based on the proven concepts of the highly
successful Graupner MC-19 to MC-24 radios used by the top European pilots.
Multiple model types. Airplane, helicopter, sailplane. Each with multiple servo configurations.
High-contrast graphic LCD screen. Large and easy to read, the display insures perfect monitoring of set-up parameters, operational states, and timers.
Eight control functions. With simplified method of assigning transmitter controls to auxiliary functions.
Free assignment of all switches and knobs. Simply move the desired switch to assign it a new function!
Twelve model memories. Using the latest form of back-up memory which requires no Lithium battery.
Multiple controls. One three-position switch, one momentary button, one analogue control, two digital controls installed as standard. All individually programmable.
Function encoder. Rotary roller and three momentary buttons for simplified programming and accurate set-up.
Multiple stick mode support. Easily switch between stick modes 1 - 4.
Graphic servo display. Detailed display provides a fast, simple overview for checking servo travels.
Comprehensive fixed-wing and helicopter menus. Fast setup with a simple overview for checking servo travels.
Servo travel adjustment. Adjustments for all servo channels, separately variable for each end-point.
Sub-trim. Designed for setting the neutral position of all servos.
Two-stage Expo / Dual-Rate system. Individually variable, switchable in flight
Mixer functions
Programmable Fail-Safe function. HOLD or USER DEFINED, individually variable for each separate servo channel.
Stopwatch / count-down timer. Each with alarm function.
Model copy/delete function. Easily manage model memories.
Greg Gimlick is offline Find More Posts by Greg Gimlick
Old Nov 30, 2011, 10:45 PM
crosby is offline
Find More Posts by crosby
Trader Rating: 242
GOD loves you!!!
crosby's Avatar
United States, SC, Honea Path
Joined Aug 2010
Trader Rating: 242
how old is it??? Do you have the manual and what mode does it default to 1 or 2...I know it will do all four; but which one does it default to when setting up a new model???
crosby is offline Find More Posts by crosby
Old Dec 01, 2011, 03:06 AM
Trader Rating: 25
Fuquay Varina, NC
Joined Dec 2000
Trader Rating: 25
I've had it since they first came out...2 or 3 years I guess. It defaults to mode 2 and will do all four.
Old Dec 01, 2011, 09:21 AM
crosby is offline
Trader Rating: 242
GOD loves you!!!
crosby's Avatar
Joined Aug 2010
Trader Rating: 242
Thanks!!
Old Dec 01, 2011, 02:17 PM
Trader Rating: 25
Fuquay Varina, NC
Joined Dec 2000
Trader Rating: 25
Sold pending funds.
Help! Graupner MX-16 or MX-20 HoTT urgent question!! bikertje888 Radios 2 Jan 24, 2012 07:50 AM
Discussion GRAUPNER iFS MX-16 RADIO SYSTEM jh2rc97 Xtreme Power Systems 73 Jun 07, 2010 08:13 AM
Discussion Graupner iFS MX-16 1-26 Flyer Radios 6 May 15, 2009 05:06 PM
For Sale XPS Xtremelink Hitec/Futaba TX module and 8ch RX Combo Talontsi96 Aircraft - General - Radio Equipment (FS/W) 3 Sep 18, 2008 12:12 AM
For Sale XPS TX MODUEL & 8ch. rx mid-air Aircraft - General - Radio Equipment (FS/W) 1 Jun 25, 2008 05:17 PM
