Old Nov 30, 2011, 08:49 PM
brandonmoon is offline
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
Would love to try them ...currently need a good 4s for the A-1 sky raider on stock set up you sent me.
Currently has:
80A esc
500kv out-runner
Have been using an old fullymax 25c 3700 mah 4s battery. Seems to be ok.
Using my Futaba 12fg radio...with an HK orange futaba 2.4ghz rx
The rest...is bone stock....straight from you as you sent it. :-)
So would be nice to try something 4000mah and 30c+ for more flight time and power
Also would like to see 3000mah 30c + in 4s and 3s to use on my airfield war birds and my custom LX Mig-29
The Mig is using 2x CC ice lite 100a esc's and HET 2w-25 EDF motors in Wemotec mini fan pro's. Currently have been using Turnigy Nano-tech 5000mah 45-90c lipos in a 2x3s config. But would love to try and compare your battering in the same or greater c rating and mah capacities
brandonmoon is offline Find More Posts by brandonmoon
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
JUST A LITTLE MODIFIED
2200kv Grayson Microjet V3 motor with 6x4 prop with 30A ESC
REQUIRES 20 Amps. So between 1800mAh and 3300mAh is fine
1800mAh 15C 3S (11.1v)(stock manufacturer spec)
The specs below will be sufficient.
2200mAh 25C
2500mAh 25C
2650mAh 25C
3000mAh 25C
3300mAh 25C
I currently use 2500mAh 25C 3S (11.1v) for FPV for good measure.
You should let me show how Genesis Power provides guaranteed, longer lasting & plentiful FPV flights
chatch15117 is offline Find More Posts by chatch15117
Old Nov 30, 2011, 08:53 PM
stwaller12 is online now
Find More Posts by stwaller12
stwaller12's Avatar
United States, MI, Brighton
Joined Jun 2010
I was hoping to try a 2200 mAh 4 cell on my new Pitts model 12. It had an Eflite Power 15 With a 40 Amp Esc.
stwaller12 is online now Find More Posts by stwaller12
kwj48 is offline
Find More Posts by kwj48
probro 2567
kwj48's Avatar
Midlothian,VA
Joined Jan 2006
Here is my kit built Sbach 35. Distributed by The Balsa Store, and designed by Ron Wilson. I would love to try a 4s 2200 mah.
Torque 2814t/820
CC Ice 75
hitech 85mg's servos
JFX 13x6e prop
4s 2200 battery
kwj48 is offline Find More Posts by kwj48
Old Nov 30, 2011, 08:59 PM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
Gens 6c 25c 2600mah and gens 6cells 25c 3300mah
Extreme flight Edge 540 60 inch exp Rocks! BTW
Torque motor 500kv
airboss 80amps
prop 15x6
Flazo is offline Find More Posts by Flazo
Old Nov 30, 2011, 09:00 PM
Vitter is offline
Find More Posts by Vitter
Gas Monkey Vic
Vitter's Avatar
Snohomish, WA
Joined Jan 2005
The airframe:
85" 50cc Yak by KMC Tech
Wing Span: 85"
Wing Area: 1410sq in
Fuselage Length: 81"
Dry weight: 18lbs
My set up:
Motor: Hacker A60-18L 149KV 3500W Brushless Outrunner in a Mad Dog Mount.
ESC: Castle Creations Phoenix HV 110A.
BEC: Castle Creations BEC Pro powered by a 3-Cell 1320 pack.
Prop: Xoar 24x12E.
RX: R617FS.
5 x Hitec HS-7954SH Servos.
Battery: 2x Zippy 25c 6-Cell 5000mAh for 12S flight pack with Deans connector plug.
I would love to try out your new line of Genesis lithium polymer batteries! A 6-Cell 5000mah or two would be awesome.
Vitter
Vitter is offline Find More Posts by Vitter
Old Nov 30, 2011, 09:15 PM
XXLBMXER is offline
Find More Posts by XXLBMXER
Team 3DHS
XXLBMXER's Avatar
Los Alamos CA .
Joined Jan 2009
This is my 74'' 3DHS Edge 540
Hacker A50-12L 348 kv
Castle Creations Ice 100 amp ESC
8s 2 Sky Lipo 4s 4000s 40c Deans Connectors
Xoar 18x8
JR 9303 with an AR 7000Rx
XXLBMXER is offline Find More Posts by XXLBMXER
Old Nov 30, 2011, 09:21 PM
banana hobby is offline
Find More Posts by banana hobby
banana hobby's Avatar
United States, CA
Joined May 2008
Awesome Everyone!
Amazing pilots! Thank you all for all the entries so far! I love the wide vast of varieties! LOVE all the 3DHS planes and some classy warbirds! Nice helis so far as well! There are a few BRUT EDF's there! Stay tuned to see who will receive the Genesis Lipo! FYI, when the threads reach 50 in entries, the thread will be closed for review and then opened back up if we have any further entries to meet 50! Thanks Pilots!
Regards,
Pete
banana hobby is offline Find More Posts by banana hobby
Site Sponsor
Old Nov 30, 2011, 09:24 PM
tomme21 is offline
Find More Posts by tomme21
tom
tomme21's Avatar
USA, LA, Natchitoches
Joined Apr 2004
for contest
5cell, 18.5v, 4000mah 40 c
for this mirage.
just checked your site and these are on par with hobbyking batteries which i use. but, these have DEANS already on them, really nice, i hope these hold up, will be looking forward to the testing the winners will do on these batteries.
thanks for this contest, pete., nice thought.
tomme21 is offline Find More Posts by tomme21
Old Nov 30, 2011, 09:30 PM
The Don is online now
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
Model: 50mm Bitzrcworks/Jpower F18 EDF
Motor: DonsRC Wicked 6000KV
Fan: Wemotec Microfan
ESC: Hobbywing Pentium 40 amp
Rx: Assan 4 channel
Transmitter: Hitec Aurora 9 modified for dual system (Assan and Hitec)
Servos: 2 x Emax 8 gram ES08A
Battery: 3S 1800 30C Sky Lipo
Amp draw: ~32 amps
Battery connector: Deans plug
The Don is online now Find More Posts by The Don
Old Nov 30, 2011, 09:52 PM
V2rider is online now
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Kyosho 50 size FW-190. No real stock motor for this one. I am running it on a Himax 5030-390 Kv motor, turning a 14x9x3 MAs prop controlled by a CC ICE 75 esc. Current packs are 6s 30C 5000ma.
V2rider is online now Find More Posts by V2rider
Old Nov 30, 2011, 10:05 PM
inspector5419 is offline
Find More Posts by inspector5419
inspector5419's Avatar
USA, TX, Van Alstyne
Joined Nov 2010
Airfield 800mm P 47
My fantasy P 47 sq.
Little Texan
Sq letters are for my home town
Tail numbers are my kids b-dates
Optima 370 motor
30 amp ESC
3s 800mah 30 battery
inspector5419 is offline Find More Posts by inspector5419
Old Nov 30, 2011, 10:09 PM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
mig 15
I will love a set of 2 4S 5000 mah battery for my Mig 15. Very nice and fast, power with a Tj 100 fan ESC is Castle Creation 110 HV. Retract etc...
bidule is offline Find More Posts by bidule
Old Nov 30, 2011, 10:22 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Heres My scatch built Tricopter . Running a KK blue board and 3 2212 motors . It currently Flys on 1 3s 2200 mah battery but would love to bump that up to a 3s 3300mah range .It has 2 rctimer 20amp esc's into 1 Dean connector . 8X4 props with the left hand one of the counter rotating variety . The Yaw servo at this point is a $3 cheapy with a metal geared one waiting on a failure .
Wilfor is offline Find More Posts by Wilfor
Old Nov 30, 2011, 10:34 PM
maiden-crash is offline
Find More Posts by maiden-crash
R/C Airplane Executioner
Melbourne, Australia
Joined May 2006
My new Multiplex Funjet. Running 650 watts with my Hyperion G3 3S 2100, would like to see how it could compare with a 3S 2100 up to 2500 3S. Motor: Himax 3514-2900. ESC: Multiplex 70 AMP. Thank you
maiden-crash is offline Find More Posts by maiden-crash
New Product GEnesis Power Lipos By Banana Hobby pavcon Banana Hobby 2 Nov 15, 2011 01:31 AM
New Product Genesis Power Lipos from Banana Hobby FieldofDreamsFlyer Batteries and Chargers 4 Nov 10, 2011 07:04 PM
Alert Banana Hobby/J-Power 50mm A-10 EDF Failures Ducati0749 Foamy EDFs 5 Oct 27, 2011 06:25 PM
Discussion Banana Hobby Thunder Cat battery problem... Duane Batteries and Chargers 1 Jun 03, 2011 05:32 PM
