Old Nov 30, 2011, 06:18 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
my 90mm EDF Het F18
running 10s 2 x nanotech 35c 4500 5s with 6.5mm bullet connectors feeding an 90mm Extreme alloy wemo fan with an ARC 3655-2 1400kv with a Castle ice2 120amp esc it draws 100amps peak. using a Futaba 12fga radio, AUW is 8.25lbs and does 140mph
I would love to try out some new 40 or 55c batteries two of the 55c 5s 5000 would be great or two of the 40c 4500 4s packs as I do fly it on 8s as well
two of these http://www.bananahobby.com/gp4045004s.html
or two of these PREFERRED http://www.bananahobby.com/gp5550005s.html
jcdfrd is offline Find More Posts by jcdfrd
Old Nov 30, 2011, 06:21 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
I have a Great Planes Escapade that would love a 5000mAh 18.5v pack, either 40C or 55C.
I push the Rimfire .46 motor hard on this plane with an 80A ESC and a 12x8 prop. It definitely taxes the battery and could use a good, quality pack.
Larry
Lardog is offline Find More Posts by Lardog
Old Nov 30, 2011, 06:22 PM
raypadro is offline
Find More Posts by raypadro
Orange Park,FL.
Joined Aug 2007
Count me in
I can use one of your batteries in any of this two:
First a stock Trex 500 with stock motor and esc can use a 6s From 2600mah to 3000mah.
Second is my Starfire 90mm ducted fan with Scorpion motor Castle creation ESC using a 6s 5000mah
raypadro is offline Find More Posts by raypadro
Old Nov 30, 2011, 06:24 PM
Flip Flop is offline
Find More Posts by Flip Flop
Flip Flop's Avatar
United States, UT, Syracuse
Joined Oct 2009
Heres my FlyFly Mirage with the Change Sun 90mm fan and a 1900kv motor.
Running with a Turnigy 85amp esc and a deans connector.
Usually gets 1600watts on a 6s 5000 lipo.
Flip Flop is offline Find More Posts by Flip Flop
Old Nov 30, 2011, 06:40 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Heres my airplane
Top Flite Corsair
Monster Power 60 motor
80amp ESc
APC 4 blade 15in prop
5s 5000 lipo
Deans plugs
DX6i Radio
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Nov 30, 2011, 06:42 PM
inspector5419 is offline
Find More Posts by inspector5419
inspector5419's Avatar
USA, TX, Van Alstyne
Joined Nov 2010
Dynam 1200mm Spitfire
Here is my Dynam 1200mm Spitfire
I painted it after the Grey Nurse Sq
& added splitflaps
Stock motor 50 amp ESC with a CC 10 amp BEC
running on 3s 2650mah 40c batteries
inspector5419 is offline Find More Posts by inspector5419
Old Nov 30, 2011, 06:43 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Would love to try GENESIS 55c in GWS A-4 Skyhaw with EFLDF32 fan
3. Post a picture in this thread of the aircraft/helicopter that you want to use with the Genesis Power LiPo battery.
Grey SkyHawk Next to FedEx DC-10
5. If you have a modified aircraft/helicopter that you will be using with the Genesis LiPo, please provide the modified specs in detail. Example: Running power systems, ESC Amp and Brand, Motor KV, type of EDF or Propeller, Avionics (radio gear), Type of Battery connector plug etc.
Power system EFLDF32 with Tacon 2150kv motor
ECS - Suppo 100 amp (HK 70 amp Heli)
RX\TX- Frsky radio and receiver with RSSI telemetry
Battery - 2600mah to 3300mah 6s with Deans
erh7771 is offline Find More Posts by erh7771
Old Nov 30, 2011, 06:49 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
3dhs 51 slick. motrolfly 3615 750kvmotor, 14x7E prop, castle ice lite 100 esc, hitec 5085mg servos, and a futaba 8fg radio with a 6106 reciever in HS mode. Was using hyperion 4s 2600mah 35C lipo Though it looks as though some 4s 2800 40C lipos would be the ticket. Useing deans conectors!
Last but not least the On crap moment
losifanatic is offline Find More Posts by losifanatic
Old Nov 30, 2011, 06:51 PM
Joined Sep 2004
Pioneer 3 electric flying wing in stock form
3536 1000kv motor
40amp esc
3s 2650 40c lipo
deans plugs
9 gm servos
Spektrum radio
Old Nov 30, 2011, 06:59 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
Just copied this off my blog. Check my profile for video and more info. I would need a 12s 4500. Would be happy to try them out!
AUW around 12lbs (used cheap fish scale)
Stumax 110-45
Neu 1524/1.5y
CC160hv Medium timing
Gens Ace 30c 12s 5300
A123 rx pack. No regulator. No switches.
Airpower electronic valves for retracts and brakes.
CG 150mm
Full throttle static results with 82mm exhaust diameter:
6375 watts peak. 6kw after 5sec. 5.8kw after 10sec.
Gens Ace pack holds at 44.4v (3.7v/cell) at 131 amps.
CC160hv with cooling fan peaks at 137F after six 10 second runs with 20 seconds breaks between each run at half throttle. Used 3000 mah.
TheTick is offline Find More Posts by TheTick
Old Nov 30, 2011, 07:17 PM
chq28 is offline
Find More Posts by chq28
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
Extreme Flight 48" Edge, running Motrolfly 2820 750kv, Motrolfly 60A ESC, and 4s 25c 2500 batteries w/deans connectors. Servos HS-65's x 3, 1 HS-85 and spinning 14x7.
Hitec A9 with Optima 7
chq28 is offline Find More Posts by chq28
Old Nov 30, 2011, 07:21 PM
Jimmy1159 is offline
Find More Posts by Jimmy1159
Jimmy
Jimmy1159's Avatar
United States, NJ, Highland Lakes
Joined Oct 2008
Man I would love a 2200 for these guys. all upgraded to power 10 or higher, the spit a power 15, run Parkzone 25c 2200
Jimmy1159 is offline Find More Posts by Jimmy1159
Old Nov 30, 2011, 07:37 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
ExtremeFlight 60" Extra 300 EXP
Reaper GR-60
Xoar 15x8
ZTW 85
4S 4000-4400
Castle BEC
Hitec HS-7245 servos
86 amps, 1300 watts
Would love to try a 4000 or 4500 mah 4S 40-55C.
cwojcik is offline Find More Posts by cwojcik
Old Nov 30, 2011, 07:38 PM
CrashesALot is online now
Find More Posts by CrashesALot
Team 3DHS
CrashesALot's Avatar
Western CT
Joined Aug 2009
Here is my entry:
My 3DHS 70" AJ Slick
I am running 6S 5000's in it. I am running some 20c and some 25c packs in it.
It has a Reaper GR60XL
Mej 18-8 Carbon Fiber Prop
Castle HV85
Castle BEC
CrashesALot is online now Find More Posts by CrashesALot
Old Nov 30, 2011, 07:39 PM
cableguy351 is offline
Find More Posts by cableguy351
United States, PA, Jim Thorpe
Joined Aug 2009
I would like to try one . Sapac T-45 MB-1 motor/fan 5 cell 3300 mah castle ice 100 esc, about 1800 watts ,deans conector
cableguy351 is offline Find More Posts by cableguy351
New Product GEnesis Power Lipos By Banana Hobby pavcon Banana Hobby 2 Nov 15, 2011 12:31 AM
New Product Genesis Power Lipos from Banana Hobby FieldofDreamsFlyer Batteries and Chargers 4 Nov 10, 2011 06:04 PM
Alert Banana Hobby/J-Power 50mm A-10 EDF Failures Ducati0749 Foamy EDFs 5 Oct 27, 2011 05:25 PM
Discussion Banana Hobby Thunder Cat battery problem... Duane Batteries and Chargers 1 Jun 03, 2011 04:32 PM
