Old Dec 16, 2012, 11:23 AM
Budasac is online now
Find More Posts by Budasac
Micro Menace
Joined Aug 2012
Originally Posted by GiantScale View Post
thanks.. I'll need those pics when I install mine.
Instead of removing material to clear the swash-plate push rods.. Could you heat the canopy in that location and push out a blister for clearance?
Maybe. You need quite a bit of room though. May be beyond the limits of the plastic. Here's a pic at full throw.
Budasac is online now Find More Posts by Budasac
Old Dec 16, 2012, 01:25 PM
SMEGS888 is offline
Find More Posts by SMEGS888
Futaba 9CRAPTOR 90V911V922
SMEGS888's Avatar
United States, CA, Hacienda Heights
Joined Dec 2012
Awesome thank you so much.
SMEGS888 is offline Find More Posts by SMEGS888
Old Dec 16, 2012, 03:36 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
OK guess my XP8103 wont bind
So Im reading the FlySky TH9X , CopterX CX-CT9A and Turnigy 9X are the only transmitters which will bind with the V911.
Do any of these transmitters bind with a micro receiver for later heli's? You know.. Versatility?
And which ones the best? Can I use V-tail mixing to mix for example, forward into left tail rotor?
GiantScale is offline Find More Posts by GiantScale
Old Dec 16, 2012, 09:51 PM
SMEGS888 is offline
SMEGS888's Avatar
Joined Dec 2012
Originally Posted by Budasac View Post
Here ya go:
How did you remove te rear fin.
Old Dec 16, 2012, 09:55 PM
siriusflier is online now
Find More Posts by siriusflier
GOT WINGS
siriusflier's Avatar
United States, TX, Wilbarger
Joined Apr 2012
With a hatchet?
siriusflier is online now Find More Posts by siriusflier
Old Dec 16, 2012, 11:06 PM
Micro Menace
Joined Aug 2012
It just slides out. After you have it all together, slide it back in and it'll lock the v911 boom in place inside the fuselage.
Old Dec 17, 2012, 06:32 AM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
MY V911 broke the main shaft in forward flight last night. Spectacular tumbling crash I wish I had on video. Correction I sure the main shaft broke sometime in a crash but only separated in flight. Retiring the black 911 and ordered a new yellow BNF one this morning. Now I’m wondering about the battery. Not sure what one will come with it but if I needed will be able to change out the skids and use my old batteries? It would be nice to be able to convert to the same batteries as the Nano.
Petrie is offline Find More Posts by Petrie
Old Dec 17, 2012, 07:13 AM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
Here ya go:
Just arrived my fuselage, so started to cut upon your images...
Bulesz
bulesz is offline Find More Posts by bulesz
Old Dec 17, 2012, 11:34 AM
redtags is offline
Find More Posts by redtags
Joined Dec 2012
Yellow BNF only come in old plug model right ? I'm waiting for mine as well.
BTW is it ok to put a drop of ca / super glue on the metal part of flybar / balance bar ?
My flybar keeps loosing its metal part during a hard crash.
redtags is offline Find More Posts by redtags
Old Dec 17, 2012, 11:54 AM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
So long as doing so doesn't throw off the balance. Others have used tape, etc.
stonecutter is offline Find More Posts by stonecutter
Old Dec 17, 2012, 12:06 PM
SMEGS888 is offline
SMEGS888's Avatar
Joined Dec 2012
Anyone have any idea how to remove the main motor does it just slide off. I wiring part Is no prolbem for me.
Old Dec 17, 2012, 12:08 PM
SMEGS888 is offline
SMEGS888's Avatar
Joined Dec 2012
Originally Posted by siriusflier View Post
With a hatchet?
lol
Old Dec 17, 2012, 12:18 PM
Sir Crashalot
Joined Oct 2011
Remove the board and pull off the retaining tab, should be able to pull motor straight up.
Old Dec 17, 2012, 12:24 PM
SMEGS888 is offline
SMEGS888's Avatar
Joined Dec 2012
Thanks I have a eagles motor on order.
Old Dec 17, 2012, 01:18 PM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Eventually got time to tinker today, so decided I'd try and get my yellow bird flying again (the one with the broken canopy rod).
I had previously noticed that the canopy was quite tight to the servo rods so instead of just repairing the side which was broken, I decided to cut off the other side too and extend it by a couple of mm to give me more clearance.
What I did was bore a 0.8mm hole through the mainframe and bore about 6-7mm down the length of the rods to give them plenty of hold. Straighten a standard paper clip, cut it to size, shove it through the mainframe, fit the ends and Bob’s your uncle. Flies as good as ever, if not better
It’s no doubt been mentioned before, but I only realised today that the canopy holders on the white and yellow clones are about 4mm longer than on the original V911s. If you look closely at the pics below – for anybody who hasn’t got both types – you can see that the mounts for the servo arms are set further out on the pcb resulting in the linkage arms on the yellow being much more “splayed”, whereas on the blue/white they are almost vertical. No idea if that was deliberate on the part of the clone manufacturer or if it just happened that way. Can any of you physicists out there tell us what kind of effect that would have on the flight characteristics? As usual, just curious for curiosity’s sake
Cheers
Tigg
tiggertoo1962 is offline Find More Posts by tiggertoo1962
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
