Old Dec 07, 2012, 12:28 AM
nizzamms is offline
Find More Posts by nizzamms
nizzamms's Avatar
Malaysia, Johor, Johor Bahru
Joined Oct 2007
just wanna share my video V911 with fire works ..looks like little nitro microhelicopter LOL
Satu Hari Di Hari Raya V911 (0 min 42 sec)
nizzamms is offline Find More Posts by nizzamms
Old Dec 07, 2012, 02:54 AM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Originally Posted by 2_Crash_Thumbs View Post
My fix is to splice all the way through to the unbroken side with a sewing needle, heat shrink and epoxy.
Thanks for all the tips guys. The superglue has held now for 2 flights and a couple of crashes, but when it goes again I'll definitely try the "pin" solution. Unfortunately it broke almost flush with the main frame, so heat shrink isn't an option in this case.
Happy flying
Tigg
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Dec 07, 2012, 03:29 AM
Thwock is offline
Find More Posts by Thwock
United Kingdom
Joined Nov 2012
This perhaps? Basically glue a CF support rod alongside the original strut then use heatshrink to make it pretty. Overkill maybe when you can buy a new heli quite cheap.
http://www.hacksmods.com/2012/11/bla...reinforcement/
Thwock is offline Find More Posts by Thwock
Old Dec 07, 2012, 08:54 AM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Nice! Should enter it in Banggood's video contest.
stonecutter is offline Find More Posts by stonecutter
Old Dec 07, 2012, 01:05 PM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
Originally Posted by Budasac View Post
I was gonna say I have an Agusta fuse on my v911 and then I realized you already posted the link.
But yes, very easy and it was under $10. You just have to reverse the battery mount for COG. It's definitely my favorite v911.
hohohoho, its my weakpont... from where could I get one Augusta 109?
many thanks!
EDIT: I have found an orange one:
http://www.hobby-estore.com/Nano-esk...sky-002845.htm
bulesz is offline Find More Posts by bulesz
Old Dec 07, 2012, 02:09 PM
Sir Crashalot
Joined Oct 2011
white v911 at the park
I don't fly the v911 outside much, this morning had a slight breeze (I estimate 5-10 mph). So took the white clone w/ the msr paddles out for a spin.
White v911 with msr paddles at the park (9 min 35 sec)
Old Dec 07, 2012, 03:03 PM
CCbusa05 is offline
Find More Posts by CCbusa05
CCbusa05's Avatar
USA, NV, Carson City
Joined Sep 2006
Nice flying bro! How many battery changes during the course of your 9 minute plus video? I have the new version stock batteries and they start running out of steam a bit before 4:30, at which point I shut her down. One battery already croaked on me after approx 20 flights. The other 7 I have are still going strong and are now approaching 30 flights each.
CCbusa05 is offline Find More Posts by CCbusa05
Old Dec 07, 2012, 04:30 PM
Sir Crashalot
Joined Oct 2011
Thanks for the compliment. I used up eight batteries in that session, a mixtuere of 120 and 140's. Of course not every moment ended up in the vid.
Old Dec 07, 2012, 05:06 PM
Ricomon is offline
Find More Posts by Ricomon
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
many thanks!
Here's where I got mine for less than $10 shipped.
Rick
Ricomon is offline Find More Posts by Ricomon
Old Dec 07, 2012, 05:26 PM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
Originally Posted by Ricomon View Post
Thanks mate I have ordered an orange from here (for 2 dollars more...)
http://www.ebay.com/itm/Esky-Fuselag...item564fcc2e09
When it will be arrived I think will have some questions comrade!
Old Dec 07, 2012, 06:38 PM
Budasac is offline
Find More Posts by Budasac
Micro Menace
Joined Aug 2012
I redid mine since the pics that were posted. I think I cut away less material the second time around. I also relocated the swash guide so it's straight back instead of being on a 45. When you're ready to do yours I can post some close ups of the cuts and the holes for the posts if you like. It's very simple if you know where to mount it. My first install was a little botched from trying to get the COG correct. I kept having to adjust the fuselage and as a result ended up cutting more then I needed.
Budasac is offline Find More Posts by Budasac
Old Dec 07, 2012, 11:34 PM
legend 550 is offline
Find More Posts by legend 550
Joined Aug 2008
Hi all. After flying fixed wing for 30 years I have been bitten by this affliction of these tiny electric blenders. I just received 2 v911's, One RTF and one BNF and have questions. They appear almost identical except the RTF uses the new style battery and the BNF has the old style. I ordered a new style gear with plug so they'll use the same batteries. The other thing I noticed was the rotor blades, The BNF blades are marked A, and the RTF are marked B. Are these the same ? Or is one new style and one old style? and how can you tell them apart? The rotor head and swash plate look the same. Also when ordering parts how can you tell if the part your ordering is new or old style?
legend 550 is offline Find More Posts by legend 550
Old Dec 08, 2012, 01:13 AM
Heli Pad is online now
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Never quite figured out what those A and B's are on the blades. They are important for coaxial, but not here. And you want to know something funny. Mine has one A and one B as a pair! At any rate, if they look the same and weight the same, go for it. Don't worry about it.
Heli Pad is online now Find More Posts by Heli Pad
Old Dec 08, 2012, 03:39 AM
bflan2001 is offline
Find More Posts by bflan2001
Always borking my corter
United States, CA, Mountain View
Joined Feb 2012
The newest version (version 3) has 'A1' and 'B1' on the blades due to an updated head design, so I think yours are both version 2.
bflan2001 is offline Find More Posts by bflan2001
Old Dec 08, 2012, 05:49 AM
ztoon13 is offline
Find More Posts by ztoon13
Gone with the Mistral
ztoon13's Avatar
France, PACA, 13
Joined Jun 2012
Hi happy flyers,
Nice flying Stonecutter, I also like to fly outside when it's windy, this mod is more and more desirable....
But today, no contest with the wind:
2012/12/08 11:30 LFML 081130Z 33029G41KT 9999 FEW023 07/M01 Q1012 NOSIG
How did you remove the paint from your (red?)/white canopy? I find it easy to remove paint from the blades but somehow difficult from the plastic of the canopy.
Someone had to try that !! You did it ! I want to see a rocket booster copter as version 2 please.
Olivier
ztoon13 is offline Find More Posts by ztoon13
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
