Old Dec 05, 2012, 12:30 AM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Originally Posted by Dark_Lord View Post
I am willing to trade the 2 brand new (old style) battery's for 2 slightly used new style battery's even up if anyone is willing.
Sounds like a fair deal If I lived close to you I'd have taken you up on it, but I don't think you're in Bavaria by the looks of things
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Dec 05, 2012, 12:34 AM
Scotsman in Germany
Joined Oct 2012
Originally Posted by MWShelton View Post
I ordered a new connector V911 from Bangood just because I have so many of the battery's. I fly Ultra Micro Planes, probably have 20 batteries.
Have fun with it. Bet you'll end up buying more batteries by the time they're all used up ... and probably more helis too
Old Dec 05, 2012, 12:43 AM
Scotsman in Germany
Joined Oct 2012
Originally Posted by RicksterRC View Post
Blow (hard) on the tail rotor. It should spin fast and take a while to stop.
If you can't make it spin, or it stops immediately, it's probably binding.
Check for dust/lint. Check that the rotor isn't pushed on to far and binding against the motor.
Consider adding a single drop of light sewing machine type oil to the shaft where it enters the motor.
Hey Rick. Everything's spinning freely so no probs there. Think I'll go get myself some sewing machine oil, thanks for the tip.
Tigg
Old Dec 05, 2012, 01:22 AM
RoboSerg is offline
Find More Posts by RoboSerg
RoboSerg's Avatar
Joined Sep 2011
SP270 swash has the guide pin in the wrong place for original V911 corters.
It should fit the new Y911, but then it's already got the fisheye and CF shaft.
The "fisheye" has two guide pins, so works with old/new corters.
Oh shjt, did I order the wrong swash? I ordered a sp270 swash for my v911. My v911 has "copter" and not "corter" on the fuselage. But my v911 has metal main shaft, not CF. So the fisheye swash wont fit?
RoboSerg is offline Find More Posts by RoboSerg
Old Dec 05, 2012, 03:52 AM
Scotsman in Germany
Joined Oct 2012
wobbles
Well after about a month or more of taking abuse, heli #1 has developed a "wobble" when hovering. Also flies off at a 20-30 tangent to the right when I give forward elevator.
Bent main shaft? ... or does it sound like some other cause?
Thanks guys
Tigg
Old Dec 05, 2012, 06:57 AM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
Originally Posted by Ricomon View Post
Don't cut down the tail rotor. You need that thrust to counteract the torque of the main rotor. If you cut down the tail rotor, the tail motor will have to work harder to hold the heading, thus shortening the motor's life. It would only slow right turns, anyway. The resistors are definitely the way to go.
Rick
Resistors? Can someone direct me/explain the mod which slows down turns with the stock TX?
GiantScale is offline Find More Posts by GiantScale
Old Dec 05, 2012, 08:46 AM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Thanks guys
Tigg
Lots of things can cause this. Unbalanced blades and/ or flybar being probably the most likely issue.
stonecutter is offline Find More Posts by stonecutter
Old Dec 05, 2012, 09:24 AM
subpixel is offline
Find More Posts by subpixel
subpixel's Avatar
United Kingdom, England, Nottingham
Joined Dec 2007
what do I need to convert an old style battery v911 to use the new white plug batteries?
subpixel is offline Find More Posts by subpixel
Old Dec 05, 2012, 09:55 AM
Dark_Lord is offline
Find More Posts by Dark_Lord
Joined Dec 2009
Im in Louisiana USA. the wife just placed them up on ebay for 7 days (over priced aff! she dont know the meaning of a quick "get rid of um"sale) but if anyone wants to swap im up for it after the 7 days are up. less i can fig a way to modify them with the new style some how.
EDIT:
Scratch that, they just sold 2 minutes ago.
Dark_Lord is offline Find More Posts by Dark_Lord
Old Dec 05, 2012, 10:47 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
new style landing skid soldered to your "old style" PCB (board) ...
... or you solder a plug with wires on and use airtime mCPX aftermarket skids (that is what I would do IF I could solder ... [if you would consider this, you might as well consider airtime mSR skids and solder on an mSR style plug - this would provide you access to the most extensive "reservoir" of possible replacement batteries ...)
Old Dec 05, 2012, 11:01 AM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
EDIT:
Sounds like your wife knows what she is doing. Don't let her get mad at your helis. What part of Louisiana? I'm in Arkansas.
Petrie is offline Find More Posts by Petrie
Old Dec 05, 2012, 12:54 PM
Joined Dec 2009
Lake Charles. =)
Old Dec 05, 2012, 02:40 PM
Scotsman in Germany
Joined Oct 2012
Cheers stonecutter, got blades & flybars aplenty so I'll give it a go. Don't see it being the flybar though as both weights are still in place. I've lost a weight before and that just made it completely unflyable... I've only got a "wee wobble"
Old Dec 05, 2012, 02:57 PM
Scotsman in Germany
Joined Oct 2012
I put "resistor mod" in the search for you... the rest you have to do yourself
http://www.rcgroups.com/forums/searc...resistor%20mod
At least it's only 8 pages instead of the whole thread
Cheers
Tigg
Old Dec 05, 2012, 03:06 PM
Scotsman in Germany
Joined Oct 2012
Rick
Hey Ricomon
just trying to understand something here. I recently heard that if you put on a larger tail rotor it'll slow down the RPMs , making the motor work harder to try and keep the torque and possibly shortening motor life.
Does this mean that the motors are generally optimised for the size of rotor they are supposed to have, and any mod - either smaller or larger - will have an adverse effect on the motor?
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
