Joined Sep 2007
United Kingdom
Joined Nov 2012
Mechanical/manual trim thread, it should be mandatory reading for us new owners. In short, cancel your controller trims and adjust the lengths of the servo connectors first, to get a neutral hovering trim. Once done there is no real need for any trim on the right controller stick, indoors anyway. You will likely still need to trim the rudder per flight. If this doesn't solve it, look for stock swashplate separation or linkage binding near the head which can cause TBE/precession. But I expect you just need mechanical trim. |
Joined Apr 2012
Hi Daryoon, I'm a newbie with this hobby, and I'm planning to buy Turnigy 9x, but could not find the flysky module in hobby king. http://www.hobbyking.com/hobbyking/s...Firmware_.html Still in "backorder" and what is included with the said link is Turnigy RF9X-V2 module. Will this still binds with V911? Thanks! |
Joined Jan 2012
You can get the Flysky TH9X(same as Turnigy 9x) here : http://www.banggood.com/Wholesale-Fl...r-p-47904.html http://www.giantshark.co.uk/flysky-f...-p-406149.html http://www.xheli.com/79p-th9x-r9b-9channel-radio.html |
Joined Apr 2012
However, I am still wondering if the Turnigy RF9X-V2 module can also bind with the V911?
I could see how you don't want to read the entire long thread. But read at least the 1st post and the FAQ there. Your question was answered there. If you tried to use the search function and look for 9x, you'd see that many of us have been using, or buying that exact Tx. |
Joined Jun 2012
Increase flight time at 7000 feet base altitute
I moved from near sea level to 7000 feet. The poor little 911 has to work itself to death to stay up in normal flight for more than one minute, then it flies a couple inches off the ground until the battery is depleted. I am guessing that is because it has something to "push against". I upgraded to the 150 ma batteries, but that doesn't help much. Are there some longer blades, more powerful motor or some other modifications that can be made to keep it aloft longer?
Joined Jan 2012
Beside this, they are totally the same. The Flysky TH9X is the "original" |
@irvinrhey:
Yes, get a Turnigy 9x. The full one with it's module built in. It uses the FlySky protocol and will bind up with the v911, v929, v939, Xieda 9958, Vitality, Syma X1 The FlySky TH9x radio sold by Xheli is the same as the Turnigy 9x. Except in a black plastic instead of the grey on the Turnigy. The antenna is on the top as well. It's on sale for $74.50 and there's an extra 10% off coupon that expires tonight. The company is in the US, so a good source if you live there. ![]() Ok, scratch that. They expired the coupon already even though it said you have until midnight (PST). Perhaps their server time is off. |
Latest blog entry: Syma S105 Battery Mod
Joined Jan 2012
Take Daryoon's offer for the FlySky TH9X! |
| Thread Tools | |
| New Product Jiuchon 9C002, a Solo Pro clone? | SoloProFan | Micro Helis | 103 | Feb 29, 2012 02:24 PM |
| Discussion Interesting Solo Pro? Clone | gordonzo | Micro Helis | 46 | Nov 30, 2011 03:15 AM |
| Question Which 100 sized heli after Solo Pro? | Tuc | Micro Helis | 16 | Jun 13, 2011 01:52 PM |
| Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! | RChelisrule | Aircraft - Electric - Helis (FS/W) | 1 | May 31, 2011 12:26 AM |
