Old Nov 26, 2012, 12:19 AM
Stevez1kart is offline
Find More Posts by Stevez1kart
Trees are bad
Stevez1kart's Avatar
United States, NE, Omaha
Joined Sep 2012
If you land on a non accessable roof try holding power to get it to bounce around until it takes flight. I've seen videos of people doing this after crashing and it works.
Stevez1kart is offline Find More Posts by Stevez1kart
Old Nov 26, 2012, 12:45 AM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Originally Posted by RicksterRC View Post
Speaking of cameras, has anyone had any reall success?
I tried a couple stripped down 808's and the picture quality was not acceptable.
I got a U8, stripped it down and was fairly pleased with the results.
I run it off the Corter battery and that it seems that the camera shuts down when the battery gets slightly depleted, thus videos are short (1-2 minutes).
Has anyone found a good combination?
BTW: The Bravo SX seems to be able to lift about double the weight of the standard V911 motor.
That was my experience too.
I did this a while back, with the #11, stock motor.
808 #11 key cam recording on-board v911 (0 min 11 sec)
808 #11 key cam on-board v911 take 2 (1 min 30 sec)
stonecutter is offline Find More Posts by stonecutter
Old Nov 26, 2012, 01:18 AM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
Does anyone use the free android app "RC-Heli-Pitch"? How do you use it to measure the pitch angle of a micro-micro like the v911 by using the mobile phone cam? A screenshot doing the measurement would help.
Lentar is offline Find More Posts by Lentar
Old Nov 26, 2012, 01:39 AM
Lentar is offline
Joined Oct 2012
I did a test of the various batteries eons ago.
Try lubricating, but with caution - too much is too much.
http://www.rcgroups.com/forums/showp...postcount=7344
For some, this procedure has virtually doubled flight time.
My v911 is only 2 weeks old, should I still do this? And I'm going to use Rem oil with Teflon.
Old Nov 26, 2012, 04:18 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Originally Posted by Dark_Lord View Post
On a side note, can yall tell me where i can get the BNF v911's for $20? I want the hole set! wonder if they will all bind on 1 tx and fly at the same time.. lol
http://www.banggood.com/Wholesale-Re...)-p-39473.html
http://www.banggood.com/Wholesale-V9...f-p-46299.html
http://www.banggood.com/Wholesale-Wh...f-p-49015.html
mystman is offline Find More Posts by mystman
Old Nov 26, 2012, 08:55 AM
ruskky is offline
Find More Posts by ruskky
Australia, QLD, Kangaroo Point
Joined Mar 2012
I heard back from rcshop2011 re the red whatever it is lol.
http://www.ebay.com.au/itm/2-4G-4CH-...item25776c0a20
Its not a V911 so no 9x stock binding dammit, mkipness nailed it, they probably mean v911 upgrade.
ruskky is offline Find More Posts by ruskky
Old Nov 26, 2012, 11:38 AM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Spring mod?? LOL
Daryoon is offline Find More Posts by Daryoon
Old Nov 26, 2012, 11:54 AM
Dark_Lord is offline
Find More Posts by Dark_Lord
Joined Dec 2009
http://www.rcgroups.com/forums/showp...postcount=8245
The 150mAH are the only way to fly. Punch and longer flight time.
Not sure what you mean by type-O.
You should get better than 3-5 even with the 120mAH.
Thx for the information bud.
By by type-O i mean miss print. What i was getting to there was if you look at the link i posted go down to the description of what the package includes it states that it comes with two "180Mah" battery's but i believe that is a miss print because i do not think that mine came with 180Mah battery's. im sure they ment 120Mah battery's as i have not seen any 180Mah's on the market.
Dark_Lord is offline Find More Posts by Dark_Lord
Old Nov 26, 2012, 01:11 PM
ikarous is offline
Find More Posts by ikarous
Greece, Athens
Joined Oct 2012
guys i just got my V911 new battery plug version. Anyone can tell me if there are better batteries for this with the new plug version?
ikarous is offline Find More Posts by ikarous
Old Nov 26, 2012, 01:38 PM
Sir Crashalot
Joined Oct 2011
Originally Posted by Daryoon View Post
Spring mod?? LOL
I remember we had this 'spring' discussion in the 'under $22' thread. Apparently the spring is for 'frog jump' stunts.
http://www.rc-fever.com/by-brand-1/m...hz-orange.html
Old Nov 26, 2012, 01:44 PM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Got my new plug version last week. 5 new batteries are on the way, but unfortunately they are also only 120mAh. Can't wait til they bring out the 150s as it'll be interesting to see what they do for the performance. I suppose in the meantime 7 x 120mAh will give me enough flying time . Even with the 120s it has much better FF than my old version heli with the 150s in it
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Nov 26, 2012, 01:59 PM
Sir Crashalot
Joined Oct 2011
wl toys triple decker 'Cortutle' :-)
I needed fresh ideas for the BG video contest, so expanded on old concept. As expected, hovers nicely, but flies like crap.
WL Toys v911 v929 v939 triple decker (4 min 2 sec)
Old Nov 26, 2012, 02:01 PM
ikarous is offline
Greece, Athens
Joined Oct 2012
did you order them from banggood?
Old Nov 26, 2012, 02:54 PM
Scotsman in Germany
Joined Oct 2012
Yup. I had originally ordered 5x old plug batteries not realising that my new heli had the new plug. Couldn't find the new ones in a 5-pack, so had to ask Cinbe where to find them. If you want I can send you the link later, but the server seems to be down at the moment.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
