Old Nov 20, 2012, 05:43 PM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Originally Posted by AtlantaV911 View Post
Being brand new to this hobby, it blows my mind.....that you can buy replacement parts that you can't install.....
Oh Atlanta, oh-oh-oh-Atlanta.
That's enough of the singing, welcome to the world of V911
According to some of the other guys (I'm just starting to try things out too), you can install them... it just takes a bit of patience and ingenuity
Greetz
Tigg
PS best bet is to get the yellow or white versions, they have a removable boom. Then when your original heli starts to give up the ghost you have a whole shed load of spares. Much cheaper than buying spare parts. I only got into heli flying about 4 weeks ago, and I already have my 4th heli on order
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Nov 20, 2012, 09:00 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Greetz
Tigg
That's only 1 order per week average, you're behind the curve junior.
stonecutter is offline Find More Posts by stonecutter
Old Nov 20, 2012, 10:58 PM
PurpleShark is offline
Find More Posts by PurpleShark
...if you take the time
Israel, Tel Aviv
Joined Jul 2012
YAHOOOOOOO!!!!!!!!
Was just wondering if there's anything I can change in the menu to decrease the throttle reaction time. I was told by the TX seller that "The double rate settings are at 50% on slow - 100% on quick. The expos are at 120% - so be careful". Can anybody set me straight on what the bit about the expos means?
Cheers guys
Tigg
Actualy, there is. You can control the throttle curve with this TX.
See: http://www.rcgroups.com/forums/showa...mentid=4971241
This TX programming is very simple: menu selects the function, and SEL selects the channel. For end-points you move the stick (up/down or right/left) to switch 'ends'. You need THRO, it has 4 points which are used to build a curve, you probably need to reduce the first and second points a little (say to 15 and 40). I did, and I like it! I can post my exact settings later if you're interested.
PurpleShark is offline Find More Posts by PurpleShark
Old Nov 21, 2012, 02:16 AM
Scotsman in Germany
Joined Oct 2012
Oh dear, that means I need to get a minimum of 60 helis within the year to catch up Wonder what the wife will say when she finds out we're moving to a bigger house
Thanks for the tips, I'll play around with the settings a bit this morning and see how it goes. If you could post your settings that'd be great, would give me a comparison to how mine is set up
Greetz
Tigg
Old Nov 21, 2012, 03:29 AM
Aaron qin is online now
Find More Posts by Aaron qin
Aaron qin's Avatar
China, Guangdong
Joined Oct 2011
Hi guys,new wltoys v922 video!
WLtoys V922 2 4G Flybarless 3D 6CH RC Helicopter (4 min 49 sec)
Aaron qin is online now Find More Posts by Aaron qin
Site Sponsor
Old Nov 21, 2012, 06:21 AM
fauconnier is offline
Find More Posts by fauconnier
Flying a Falcon or a 3D plane.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
Originally Posted by Aaron qin View Post
Same as FLB 100 from hobbyking , another rebrand of the green Friski?????
fauconnier is offline Find More Posts by fauconnier
Old Nov 21, 2012, 08:14 AM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
where can we get the 922 and does it work with the tur 9x trans?
tonytester is offline Find More Posts by tonytester
Old Nov 21, 2012, 08:17 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
http://www.banggood.com/Wholesale-Wl...f-p-55862.html
No infos about Flysky (9x) compability yet
mystman is offline Find More Posts by mystman
Old Nov 21, 2012, 08:43 AM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
I think my tailmotor mount is also glued to the Boom.
Thanks for your help....
Well, you can install a new tailfin but you need to be ready to unglue/cut/glue the parts to make it fit.
I've swapped tail fins out before and essentially I had to cut the top part of the tail fin from the bottom part using clippers. I was able to do this without scratching or scoring the tail boom. Then I was able to wiggle the tail fin pieces until the glue bond broke. Then, to install the new tail fin, I just cut ONE side of the tailfin so that I could slide it over the tailboom. Then I glued that one down with a drop of CA glue.
As to whether the tailfin is needed, it's a safety thing AFAIK. If you land hard or pitch the heli back on takeoff, the tail motor could hit the ground and stall. That's a great way to burn out the little motor if you don't kill throttle immediately... The tail fin helps protect against that happening.
Now, regarding the fact that this heli is partially glued together... Remember that this helicopter was designed to be dirt cheap. It's cheaper to have flat plastic surfaces that require gluing than to have to create parts that can be snapped on and off more easily. Most folks around here just buy a new heli for $20 shipped rather than mess around with spare parts it seems...
RoboHeli is offline Find More Posts by RoboHeli
Old Nov 21, 2012, 12:43 PM
ggnextdoor is offline
Find More Posts by ggnextdoor
Joined Nov 2012
Originally Posted by Bo Lorentzen View Post
Maybe check this link - it kind of visualize things
http://www.buzzflyer.co.uk/rc-helico...ners-guide.asp
:-) but you really need to sit down calmly with a large carpet or grass area. (lawn) pick up the heli gently with throttle.. then keep holding height on the throttle.. and use your right hand getting comfortable moving the heli right-left and forward-backward only for a little while.. as you get used to keeping it in a place with the right hand. you can start playing with rotating it... by moving the left stick right or left.
To do the type flight you used to do.. give a little forward stick on the right stick. that will give you speed forward. (keep it low) and steer with the left stick. as soon as you start this you will get a feeling for exactly what these do.
Bo
Thanks Bo. This link is helpful. and your guidance is perfectly right. ill have to go to a part to practice this as at home with less space and this heli being fast, i just keep banging it or dont use it to the potential like i would in an open space. the link is helpful too. if you ever find a proper Tx manual please email me if you could- vsimmins@gmail.com thanks a ton!! Vicky.
ggnextdoor is offline Find More Posts by ggnextdoor
Yo R Wee Too Lo
Joined Oct 2011
thanks for the help in both thread.
Old Nov 21, 2012, 12:45 PM
Yo R Wee Too Lo
Joined Oct 2011
Originally Posted by LittleMo View Post
I don't know about the stock firmware but in er9x I hold the exit button for a second and it resets.
thanks it works for me
tonytester
Old Nov 22, 2012, 08:27 AM
Bruno956 is offline
Find More Posts by Bruno956
Joined Nov 2012
Hi all,
Anyone know how to remove the tail boom from the V911?
Have 2 of these helicopters, neither have flown, both need new tail motors. Appears as though the boom is glued, need to remove it to get the wires through.
Bruno956 is offline Find More Posts by Bruno956
Old Nov 22, 2012, 09:00 AM
mkipness is offline
Find More Posts by mkipness
Joined Aug 2012
I was thinking the same thing when I decided to rebuild my first blue V911 which had taken a beating. I had won an auction for the complete red canopy, fins, prop, etc for $2. Seems the only way is to cut it off as someone else told you, then cut/glue the new one on. Now I also have the white V911 by the other mfg, and they put a little more thought into building this one. The tail fin comes off with ease. I like the white one much better with the 9116 controller...
mkipness is offline Find More Posts by mkipness
Old Nov 22, 2012, 09:18 AM
mkipness is offline
Joined Aug 2012
Wow, when I saw the post and video, and then the link to the 922 at bangood, I clicked on it and was thinking I'd order it right now. But I was shocked to see $109. The exact same price as the FBL 100 from HK. I was thinking I would see $75'ish. I guess you get free shipping on the WL version, but a 6 week wait if in U.S.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
