Old Nov 19, 2012, 03:55 PM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Originally Posted by Daryoon View Post
Go to hacksmods.com. Search for crystal and you'll get some more info.
On boards with a damaged crystal, you usually get like two rapid blink and then the LED stays lit, solid. I remember it does this whether the radio is on or off.
cheers Daryoon, I'll have a look. What I'm getting is rapid blinking while the gyro sets itself (normal) then the slower blinking you get before binding. When I switch the TX on it stays on the slow blink instead of going solid red.
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Nov 19, 2012, 03:58 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
@Dark_Lord,
What you are referring to is controlling the Rates in R/C speak. Sometimes call Dual Rates or D/R.
The top left button will change the rates, like you assume, putting the Heli into beginner or advance mode as you put it. Some people calls it low rate or high rate. Basically all referring to the same thing.
In advance (high rate mode) the Heli will be faster because the servo has more travel and this, more throw.
In beginner (low rate mode) the Heli servo travel is limited. So you don't get full 100% servo travel. And the Heli will be slower, despite you pushing your stick to the max.
One way to determine which rate you're in is via the LCD is by pressing your left stick (rudder) full left or right. Watch the LCD as you do. You'll see the rudder indicator reduce or increase a bar or two.
Less bars equals low rate.
More bars equals high rate.
Now, the LCD also shows the words Mode1. That's a misspelling to refer to Model 1. Ignore that.
Daryoon is online now Find More Posts by Daryoon
Old Nov 19, 2012, 04:01 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
@tigger
Try to turn the transmitter on during the rapid blinking stage. You're using the stock TX correct?
Old Nov 19, 2012, 04:14 PM
Scotsman in Germany
Joined Oct 2012
@tigger
Daryoon, you are a genius. Don't know why it worked (or if I would understand if you explained it) BUT IT WORKED!!!
Many thanks
Tigg
... and now I know where the crystal is too. Hidden under a massive lump of hot glue
Old Nov 19, 2012, 04:43 PM
Dark_Lord is offline
Find More Posts by Dark_Lord
Joined Dec 2009
That works! thx Daryoon and all!
Sure dont fly like a cp at all. i notised it stops and returns to a hover the moment i let off the cyclic. big difference compared to my blueray 450. easy way to learn nose in.
The canopy strikes got to go!
Do the v911 mods make a big difference in performance?
Dark_Lord is offline Find More Posts by Dark_Lord
Old Nov 19, 2012, 05:59 PM
Scotsman in Germany
Joined Oct 2012
@tigger
... even better, I just tried the fix with the 9116 TX and it worked too. Looks like my old heli and the ori-TX belong to my daughter now
Old Nov 19, 2012, 06:13 PM
Scotsman in Germany
Joined Oct 2012
... my best technical guess would be that the gyro is the most intelligent bit of hardware on the pcb and, if you get in there while it's still trying to tell its ass from its elbow, the other components do what you tell them. When the gyro wakes up, it just throws up its hands and says "what the hell, I'll come along for the ride".
Then again, that could be caused by some of the stuff I used to get up to in my younger days ...
Old Nov 19, 2012, 08:35 PM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
9x reset timer
I've been told how ,but I'm getting old now. How do i reset the timer on my turnigy 9x. I can get it to stop but then I'm lost.
tonytester is offline Find More Posts by tonytester
Old Nov 19, 2012, 08:49 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
I don't know about the stock firmware but in er9x I hold the exit button for a second and it resets.
LittleMo is offline Find More Posts by LittleMo
Old Nov 20, 2012, 01:59 AM
Stevez1kart is offline
Find More Posts by Stevez1kart
Trees are bad
Stevez1kart's Avatar
United States, NE, Omaha
Joined Sep 2012
I think you're right. Just don't do that while turning the TX on as I believe it deletes all model memorys!
Stevez1kart is offline Find More Posts by Stevez1kart
Old Nov 20, 2012, 05:21 AM
Makdaddy is offline
Find More Posts by Makdaddy
Doink-not again :)...aka Greg
Makdaddy's Avatar
United States, MI, Sterling Heights
Joined Jul 2012
I asked this same question a while back - press and hold the exit button to reset timer.
Makdaddy is offline Find More Posts by Makdaddy
Old Nov 20, 2012, 10:32 AM
Aaron qin is offline
Find More Posts by Aaron qin
Aaron qin's Avatar
China, Guangdong
Joined Oct 2011
Hey guys,
We've created a "best video" contest at Banggood, enter and you have the opportunity to win A LOT of great prizes! Including the WLToys CP,The V959 quadcopter and the MJX F47 FP Helicopter.
http://www.banggood.com/forum-topic-2119.html
Aaron qin is offline Find More Posts by Aaron qin
Site Sponsor
Old Nov 20, 2012, 11:58 AM
ggnextdoor is offline
Find More Posts by ggnextdoor
Joined Nov 2012
Hi, I just bought a V911 and its transmitter/controller has so many buttons/operations which i am not sure how to operate. More so i moved from s107g to this V911. On s107g controller the throttle was on left and right was used for moving left/right...on v911 the left one is for throttle and changing direction of heli and right for going forward and backward. Now this is creating an issue for me..i think i will have to practice..but more so i want to get a description of all the functionality of controller and its capability and what i can do to try different things on heli. Are there any threads that specifically talk about this? or any website where i can get that info?
Thank you,
Vicky.
ggnextdoor is offline Find More Posts by ggnextdoor
Old Nov 20, 2012, 12:04 PM
Joined Dec 2009
Is this the direct drop in replacement on the v911 that everyone is talking about?
http://www.ebay.com/itm/Nine-Eagles-...item3cc51b4f5f
Old Nov 20, 2012, 12:19 PM
Bo Lorentzen is offline
Find More Posts by Bo Lorentzen
FPVpilots do it remotely
United States, CA, West Hollywood
Vicky,
The good news is that the V911 radio is about as bone standard as it comes.
The left stick is throttle - and YAW which is rotating the heli.
The right stick is pitch and roll.
pitch is moving forward - backward
Roll (right-left) is how you adjust your hover side to side.
next to the sticks are a bunch of little tabs.. one for each axis, if the helli drifts backwards, you can push up the right vertical tab a bit and that will "trim" the setting so it say better in place.
It is a bit hard to get used to , but this is the general layout of all the bigger radios, and it is your stepping stone to flying any other heli. this is one of the great things about the V911, is works like much bigger helis so you can practice without crashing $1000 when things goes wrong.
Bo
Thank you,
Vicky.
Bo Lorentzen is offline Find More Posts by Bo Lorentzen
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
