Old Oct 05, 2012, 10:18 AM
Makdaddy is offline
Find More Posts by Makdaddy
Doink-not again :)...aka Greg
Makdaddy's Avatar
United States, MI, Sterling Heights
Joined Jul 2012
Originally Posted by erdnuckel2 View Post
Dont sweat it ... that is what I get for my curiousity ...
Like I mentioned in the post about pulling the trigger, I really want to KNOW what is going on with these batteries, and from what I can read (here and elsewhere) the only thing I get is confused
So, to me the only satisfactory solution is to get one in my sweaty heli-crackhead hands ...
And someone will be happy once it goes up in the classifieds ... I hope ... (doubt I will keep it, as my "museum" is neither big enough, nor do I have ALL the other different versions ...)
Main thing here is: Friday is review day ... WLT, watch out!!!
I think I might have found the connectors used in this post.
You will see the Pico and Mico connectors in one of the pictures.
I have both chargeing harnesses (pico and micro) and I know the pico is not what is used on the new V911 battery but it uses the micro which is used on the MCPX.
I do not think the parkflyer or msr uses the larger one but the pico.
Ideas?
Makdaddy is offline Find More Posts by Makdaddy
Old Oct 05, 2012, 10:25 AM
erdnuckel2 is online now
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Ideas?
I also saw the "denomination" of pico and micro plugs on HK recently ... just give me a week and I know an answer on this one - tmart already claims it has been shipped (which of course for now only means someone printed a label ... but hey, its a start and FAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAR superior to the wait times from China ... ... )
erdnuckel2 is online now Find More Posts by erdnuckel2
Old Oct 05, 2012, 10:42 AM
Makdaddy is offline
Makdaddy's Avatar
Joined Jul 2012
I ordered a BNF V929 from them 9/22 - shipped 9/26 and it is in status below
October 05, 2012
BETHPAGE, NY 11714
Depart USPS Sort Facility
Might get tomorrow maybe??? Not bad from China and with all the holiday stuff going on.
Old Oct 05, 2012, 11:20 AM
elkabong80 is offline
Find More Posts by elkabong80
Joined Sep 2012
Originally Posted by nagromnewo View Post
Are you sure your tx was in fast rate? I'm able to get fairly decent speed forwards in fast rate. The easiest way to check is to hold your cyclic stick hard right or left and toggle the dual rate switch. You should see the indicator on the LCD toggle from about 2/3 to full over. You should also see the left servo move a bit further.
I could tell it was in fast rate because it spins like crazy with very little rudder input.
One way to maximize FFF is to unscrew the right servo horn from the servo and move it one notch up, then trim the bird mechanically so that it hovers neutrally indoors with the trim almost all the way back. Outdoors you fly with the trim all the way forwards for extra speed. You won't notice it much when hovering outdoors in wind as the extra cyclic forwards is going to help you hold against the wind and you are going to have to work the stick anyway. Moving the servo horn up one notch changes the geometry so that you get more travel forwards than back. These birds tend to be more than fast enough in reverse anyway... Double check before flying that nothing is mechanically blocking the servo at full forwards trim and retrim if necessary.
So, indoors, tx trim all the way back for neutral, full forward tx trim then for outdoor. Hmmm... Maybe I'll be ordering a bnf for outdoor, as I just got this back where I want it for indoor. Lol this really is a sickness... An awesome sickness.
elkabong80 is offline Find More Posts by elkabong80
Old Oct 05, 2012, 11:31 AM
erdnuckel2's Avatar
Joined Mar 2009
October 05, 2012
BETHPAGE, NY 11714
normal for me (but this is specifically personal experience, other people may get very different results) it usually takes another 3, sometimes 4 days once it says bethpage ... it usually says bethpage for 1 or 2 days, then philly sort facility for 1 day and on the 3rd or 4th it says arrival at unit (which usually means I get it delivered by the end of the day).
Now if bethpage happens to be on a friday, then it may take until the following wednesday - but definitely AT LEAST until Tuesday before I have it ...
(and this is pretty much a pattern, not ONE isolated, exceptional case ...
Old Oct 05, 2012, 11:35 AM
firstadam2k is offline
Find More Posts by firstadam2k
Joined Aug 2012
So as most of us have wl toys birds in there air at a given time(some have more then one type v911 v929) i have a question. For those who have a better radio this question is for you.Should i get the FS-TH9X from hobbypartz or wait till they get in the six channel i ask because money is tight. And to be honest i am not sure if i would use all the dials and such on the 9 channel.
One of the reasons i want a better radio is because each of my birds fly a bit different plus it would be nice when things get less tight so i can try more stuff.So as many as have the time chime in please it would help me amensely.
firstadam2k is offline Find More Posts by firstadam2k
Old Oct 05, 2012, 11:48 AM
Ricomon is offline
Find More Posts by Ricomon
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
Gorilla Glue Sticks to Frame!
OK, I just got back from flying the heli I crushed under the chair. It seems that the Gorilla Glue will hold the frame quite well. I'm a happy boy again! If it eventually fails, I'll let you know.
Rick
Ricomon is offline Find More Posts by Ricomon
Old Oct 05, 2012, 12:01 PM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
Rick
Great to hear you are back in the air again Rick
John.
scotsoft is offline Find More Posts by scotsoft
Old Oct 05, 2012, 12:13 PM
Ricomon is offline
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
Thanks! There's nothing lower than a grounded pilot.
By the way, I was out in an eleven MPH wind with a yellow 911 with floats, and I had no trouble traveling in any direction. I just love the wind handling capabilities of these things.
Rick
Old Oct 05, 2012, 12:25 PM
Budasac is online now
Find More Posts by Budasac
Micro Menace
Joined Aug 2012
Made some adjustments last night. Followed Cyrus' lead and turned the battery around and moved the fuselage back. Definately looks better. Flies about the same.
Budasac is online now Find More Posts by Budasac
Old Oct 05, 2012, 12:33 PM
scotsoft is offline
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
Originally Posted by Budasac View Post
Made some adjustments last night. Followed Cyrus lead and turned the battery around and moved the fuselage forward. Definately looks better. Flies about the same.
Looking at your pictures it is looking very good but the fuselage is very high up off the ground.
The skids need shortening quite a bit or something else in their place
John.
Old Oct 05, 2012, 12:37 PM
Micro Menace
Joined Aug 2012
Old Oct 05, 2012, 12:44 PM
Micro Menace
Joined Aug 2012
John.
Yes it is a little high. I don't think I can get it any lower. And even if I could, I wouldn't be able to access the battery for swaps. As you can see, the battery is tight against the belly of the fuselage. I've seen some custom skids made from bicycle spokes I believe. I may have to play around with it a little more. It's getting there though. Once I get it just right I'll order a new body for it and fly this one till it falls off. Then I'll make it perfect.
Old Oct 05, 2012, 12:48 PM
nagromnewo is offline
Find More Posts by nagromnewo
umop apisdn - downside up
nagromnewo's Avatar
United States, NC, Wilmington
Joined Sep 2012
Rick
Was that the one with the Hughes 300 canopy? I've also just fitted a Red/White with the Esky Nano Huges 300 canopy. The canopy is lighter than stock, and the bird actually feels more agile. It looks a lot nicer too. I never liked the "RC Helicopter look". Absolutely love this bird, and floats would look great on it. Maybe the floats actually help with FFF, as a little extra drag low down should help her tilt forwards? I'll be keeping my eyes open for those foak darts the next time we're at the dollar store! Did you weigh your floats?
And.. Does it float? (Not that any of us would be crazy enough to try to land on water...)
My Hughes 300 V911 will be my "daily driver"
I wish WL Toys would start making V911s with different fuselages for those of us who think a helicopter should look like a helicopter.
Owen
nagromnewo is offline Find More Posts by nagromnewo
Old Oct 05, 2012, 12:58 PM
Micro Menace
Joined Aug 2012
Until then we just have to make our own. I love the Esky canopy I got. The Hughes 300 looks great too. I also dig the Blue/white Bravo sx canopy. (the camo one looks cool too).
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
