Old Sep 16, 2012, 01:11 PM
Budasac is online now
Find More Posts by Budasac
Micro Menace
Joined Aug 2012
Hey guys, does anyone know if the V911 will bind with the Blade SR HP6DSM 2.4GHz DSM2™ transmitter. I saw a post where someone was using it but wasn't sure if they had modded it at all.
Budasac is online now Find More Posts by Budasac
Old Sep 16, 2012, 01:18 PM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
Originally Posted by Budasac View Post
Hey guys, does anyone know if the V911 will bind with the Blade SR HP6DSM 2.4GHz DSM2 transmitter. I saw a post where someone was using it but wasn't sure if they had modded it at all.
It will not bind to any Blade Tx
John.
scotsoft is offline Find More Posts by scotsoft
Old Sep 16, 2012, 01:42 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
The only TX i am aware it will bind to ( apart from the original one) is the 9X using a flysky module.
scousethief is offline Find More Posts by scousethief
Old Sep 16, 2012, 01:55 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Originally Posted by scousethief View Post
V911 with Helios paddles and skids ,
Flies fine despite the overly chunky skids, balances nicely with the battery in the cage.
Took 2 minutes , literally
Thanks for the pix, scousethief!!!
I fly with EFlite-style batteries in my V911 so I might pick up a set of these skids for myself as well. The paddles look nice as well.
RoboHeli is offline Find More Posts by RoboHeli
Old Sep 16, 2012, 02:03 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Originally Posted by PurpleShark View Post
One of my (two) V911 developed a strange issue a few flights after replacing the main motor (to a bravo SX). After keeping it in high rpm for a few second the main motor kinda "snaps":
http://www.youtube.com/watch?v=BqSPuZ75xCk
Tried replacing the main gear, but it didn't help...
Thanks for helping.
Lube the motor from the shaft end. I believe the bushing is heating up too much and seizes momentarily, resulting in the motor snatching like that (snatching is a term early v911 owners coin?)
I saw reports of issues like this often in the early days of the v911. Since then, I haven't seen too many reports of bad motors.
Daryoon is online now Find More Posts by Daryoon
Old Sep 16, 2012, 03:42 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
Thanks for helping.
Earlier in the thread, some reported motor "snatching" when overheated.
Sometimes a single drop oil light machine oil at the gear end bearing helped.
I did some motor life testing between a stock V911 and Bravo SX.
The testing was apparently flawed because I ran them from fixed voltage, but with no load.
They quickly heated up, even at relatively low voltage.
The Bravo SX, defintely "snatched" badly as soon as it heated up at all.
Both motors would "snatch" of the shell was squeezed with your fingers even a tiny bit of pressure.
Make sure nothing about the mounting of the motor is causing any pinching of the case.
After the testing, I diassembled both motors.
It was obvious that the Bravo SX windings had been rubbing the inside of the motor shell. All the shellac was worn off the windings in numerous spots.
RicksterRC is offline Find More Posts by RicksterRC
Old Sep 16, 2012, 03:52 PM
Joined Jan 2006
TY
I was going to swap to the Eflite connectors as my next "mod" , at the front of the underslung cage on the skids is a "blank plate" i thought i might glue an eflite connector in there and make the batteries plug in rather than the cable at the back, works perfectly but looks a little untidy to me
Old Sep 16, 2012, 04:02 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Nice, thanks for that info RicksterRC. Very interesting.
@scousetheif: I agree. There's a possibility the battery will disconnect on impact more that way. But I look forward to your modding result.
Old Sep 16, 2012, 05:17 PM
firstadam2k is offline
Find More Posts by firstadam2k
Joined Aug 2012
For those who have run them how much of a difference does the fish eye swash make.
i ask because my bnf red white has a pronounced tbe its only noticable indoors. I have a basic orange black on order from tmart my first was rock solid problem is it took a bath and now the tail won't hold. If i could find someone in michigan to solder a new board in i would do it but my hands are not good.
firstadam2k is offline Find More Posts by firstadam2k
Old Sep 16, 2012, 05:30 PM
Joined Jan 2006
Personally I found that using the centre pin rather than the offset one on the fisheye swash helped it a little with control precision, but it could just be my imagination.
Daryoon, good point hmmmmmm glad you mentioned that.
Old Sep 16, 2012, 06:10 PM
Joined Aug 2012
center pin??
Old Sep 16, 2012, 06:17 PM
Joined Jan 2006
The fisheye swashes that I received had two pins one offset like the original and one central
http://www.ebay.com/itm/WL-Toys-v911...-/110941692901
Old Sep 16, 2012, 06:18 PM
Joined Aug 2012
Well the regular one has two sets one shorter the the other.
Old Sep 16, 2012, 06:21 PM
Joined Jan 2006
Since when ? Must be upgraded
Old Sep 16, 2012, 06:23 PM
Joined Aug 2012
Sorry i mispoke i meant the shorter bits the turnbuckles connect to so is the fisheys worth it then??
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
