Old Sep 12, 2012, 06:07 AM
Budasac is online now
Find More Posts by Budasac
Micro Menace
Joined Aug 2012
Originally Posted by Makdaddy View Post
I found using my wife's acetone nail polish remover to work quite well for debonding. Fancy stuff from the nail pro store.
I used acetone to remove a tail boom as well. Worked very well. The only problem is now the wife is annoyed becasue her nail polish remove became part of my heli tool kit.
Budasac is online now Find More Posts by Budasac
Old Sep 12, 2012, 07:19 AM
S4ntai is offline
Find More Posts by S4ntai
Sloooooow Flyer
S4ntai's Avatar
Australia, NSW, Glenfield
Joined Aug 2012
Help Please Blade Question
Hello,
I broke one of the blade and replace only one instead of the pair,
Is the code on the blade should be matching as a pair?
Cause i notice I'm getting a lot of vibration when it's not matching, but when i replace it as a set it's fine.
What's your though about this?
S4ntai is offline Find More Posts by S4ntai
Old Sep 12, 2012, 08:07 AM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
You have to watch out with acetone on plastic though, it will destroy many types or make them brittle.
LittleMo is offline Find More Posts by LittleMo
Old Sep 12, 2012, 08:38 AM
ercapoccia is offline
Find More Posts by ercapoccia
Italy, Lazio, Rome
Joined Jun 2012
Originally Posted by RicksterRC View Post
I'm not sure what/where the 100mV comes from.
My bad, it is actually 100mW.
I've already seen your post it is very informative.
I was looking for some small led on the bay and i found 3mm brite white led. They should be lighter and draw the battery slower.
My calc was (4V - 2,5V) : 0,015A = 100 ohm
How low i can go with the current? Is 5mA enough?
Thanks for your help
ercapoccia is offline Find More Posts by ercapoccia
Old Sep 12, 2012, 09:03 AM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
The higher the resistor value, the lower the brightness of the LED. A 100ohm resistor should be fine.
Daryoon is offline Find More Posts by Daryoon
Old Sep 12, 2012, 10:44 AM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Always good to do a test run on the same type plastic or carbon fiber to see if it also dissolves or weakens the plastic.
Most times a little heat helps the de-bonding process. Remember though that these plastics melt very easily with little heat.
Hot water will also help to remove superglue or allow bending plastic to a new shape.
Buy extra blades and always replace the pair. Gives you a chance to use a lighter color to see better Then you have extra old blades if you run out of new ones.
Banggood - main blades
http://www.banggood.com/buy/v911/ind...0-0_page3.html
Tomtop - main blades - 30 pairs may be more than you need.
http://www.aliexpress.com/store/7012...eeShipCountry=
Ribble is offline Find More Posts by Ribble
Old Sep 12, 2012, 11:42 AM
Ricomon is offline
Find More Posts by Ricomon
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
All is right with the universe. The heli I ordered from BangGood on Sunday has shipped. ...and not a moment too soon. I've been practicing the four channel heli on the simulator for the last two weeks. Last night I decided to take a flight with my three channel co-ax heli. Aileron input produced yaw, and rudder input did nothing at all. (no big surprise!) It seems that I am no longer capable of flying a three channel heli. ...which is a good thing.
Rick
Ricomon is offline Find More Posts by Ricomon
Old Sep 12, 2012, 11:55 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
I use 56 ohm SMD resistors, because i like to have LED @20mA and full brightness.
Calculator shows that array of 4 LED's and 4 56 ohm resistors for my V929, only draw 80 mA from main battery.
I don't think it effects flight power too much(how much those motors draw under full load ???), those 4 LED's can lit for 7-8 hours from 600 mAh battery
shafter is offline Find More Posts by shafter
Old Sep 12, 2012, 11:57 AM
Judderman is offline
Find More Posts by Judderman
"Beware of the ..."
Judderman's Avatar
Uk
Joined Aug 2003
I got my Helios flybar today from Bangood
Sanded do the ball links with very fine grit sand paper
Centre pivot went straight on with no alteration
First test flight in the house and it hovers perfect hands off
The heli seams to climb quicker on throttle input but maybe its just in my head
Will give it a go outside when the weather gets better
Judderman is offline Find More Posts by Judderman
Old Sep 12, 2012, 12:15 PM
Big_Kid is offline
Find More Posts by Big_Kid
United States, NJ
Joined Jul 2011
Didn't Care For Them
Before my V911 main motor gave up the ghost I tried the MSR paddles. Didn't really care for the way it handled. With that being said, first $6.00 gets you the 4 paddles and stock flybar, fitted with a set of the paddles. PM me if interested.
Big_Kid is offline Find More Posts by Big_Kid
Old Sep 12, 2012, 12:32 PM
Makdaddy is offline
Find More Posts by Makdaddy
Doink-not again :)...aka Greg
Makdaddy's Avatar
United States, MI, Sterling Heights
Joined Jul 2012
Yea was giving me the look (you know the look) .
I found this thread talking about debonders. Acetone does work as I have used it mutliple times (tail boom mostly). Most plastics or CF, as far as I can tell, it does not have any effect.The container is plastic. I know there are many different types of plastics but we are talking about a $20.00 Heli. Actually I have used it to clean the gears also with no effect. I guess use at your own risk.
Makdaddy is offline Find More Posts by Makdaddy
Old Sep 12, 2012, 01:23 PM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Great to hear! How long is the flybar? Can you measure it?
Sorry if that's been posted before, I may have just forgotten to write it down...
RoboHeli is online now Find More Posts by RoboHeli
Old Sep 12, 2012, 01:36 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
White is probably 3.2V, not 2.5 and 5mA is 0.005A.
But anyway, how low can you go? As low as you want. It will just be less bright. Because of the way our eye senses lighty, you can probably cut the current in half and barely notice the decrease. All depends if you want to see it in the daytime, or only at night.
I run white LEDs on the high side, because the battery voltage so quickly drops below 4.2V. As soon as it gets to 3.7, you'll have half the brightness.
(4.2-3.2 = 1, 1 / 0.020 = 50) If you design for 20mA with a 50 Ohm, as soon as the battery is 3.7 it's 10mA...
All depends if you want a headlight, or a side light. Daylight or nitghtlight.
RicksterRC is offline Find More Posts by RicksterRC
Old Sep 12, 2012, 01:59 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Servo hesitation
I had noticed for a while now that my red/white doesn't quite respond as nicely as my yellow, and I have two red/whites and they both seem to behave similarly. So I took a closer look and they both have what I'd call servo hesitations. With the motor running, the aileron servo clearly has an occasional hiccup (responds after momentary delay, is jumpy at times, or ignore input completely if stick is released quickly enough). The following video I hope can demonstrate what I'm talking about.
wl toys v911 demonstration of servo hesitation (0 min 55 sec)
Edit: I had the newer rev 6 boards that KKDDMM's post a few pages back showed. (Square crystal, brown chip connected to aileron servo). Here's the link to that post.
http://www.rcgroups.com/forums/showp...ostcount=12404
Edit2: It's not my imagination, it's impossible to control the aileron servo arm smoothly while the motor is running. It seems to have certain spots along its travel that it just jumps to even when the input is smooth and linear (as smoothly as I could move the stick anyway.) I don't recall the older versions have this problem. If other people observe the same thing please post.
stonecutter is offline Find More Posts by stonecutter
Old Sep 12, 2012, 07:25 PM
TapouT21 is offline
Find More Posts by TapouT21
Don't Drink & Fly
TapouT21's Avatar
United States, OH
Joined Jun 2012
Since so many read this topic, would anyone with a good amount of electronic circuit knowledge please PM me, I would greatly appreciate it! I want to ask a question about a circuit to drop voltage a little bit (will explain why in a pm, and why it may not be as simple as it sounds), THANKS!
Originally Posted by john631 View Post
This forum is a bit different and I didn't realize I should have been posting here as opposed to making a thread for my problems.
Had everything re-soldered but the wires for the tail motor were on the outside of the mount for the tail motor.
I have the thing apart again and have more parts ordered for the re-fix. Do you guys not put the wires inside like it does come from the factory? Should I just run the wires on the outside and cover them with electrical tape to protect them? The replacement might not the the exact same either?
Also want to share how I took the boom, or what was left of it out of the main body. I used a 5/64 drill bit and drilled two holes from the sides, then from there it was cake to pull the old parts out. Even used the drill bit to drill out from the back where the boom enters the body to clean that all up.
I have posted new topics for V911 questions when I first came here too. I have not done a tail boom yet but if possible want the wires inside. I would weight any tape or thin heatshirnk before I use it to see what it adds in weight. I have liquid tape as well I used to use for an extra seal on high voltage deep water splices, but it will add weight as well.
I plan to use the BSI un-cure I have to remove the glue when I need to take a tail-boom off or nail polish remover like other stated, should do the same.
Originally Posted by Pancari View Post
I was surfing thru TY and I came across a WL 319, infrared, a coaxial heli that squirts water but it seems to me that the heli was just p-e-e-ing on the floor, great way to piss off the wife.
Not sure if a WL Toys but I seen a Co-Ax like that and also one with a little claw on it to grab stuff.
TapouT21 is offline Find More Posts by TapouT21
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
