Old Sep 11, 2012, 12:41 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Originally Posted by RoboHeli View Post
I have no interest in changing the way I fly. I want a stiffer/shorter flybar to reduce flybar strikes when flying the way I like to fly
Sooner or later modifying the helicopter finds a way to fly better and avoid flybar strikes. Then WL-Toys uses the idea on the next model V911. See what trouble you are causing!
Ribble is offline Find More Posts by Ribble
Old Sep 11, 2012, 12:46 PM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
That's my kind of trouble!
RoboHeli is online now Find More Posts by RoboHeli
Old Sep 11, 2012, 01:05 PM
MC808 is offline
Find More Posts by MC808
My Corter Is Borken
United States, OH, Newark
Joined Jun 2012
So which new FP and/or CP heli should WL Toys clone next?
MC808 is offline Find More Posts by MC808
Old Sep 11, 2012, 01:09 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
How about a Genius CP or Mini CP clone BNF for $50-$60?
LittleMo is offline Find More Posts by LittleMo
Old Sep 11, 2012, 01:11 PM
RoboHeli's Avatar
Joined Dec 2011
z'omg, I would love a MiniCP clone BNF that I can bind to my Turnigy9x. I want someone to keep my (soon to be) nanoCPX company.
Old Sep 11, 2012, 01:35 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
nanoCPX
A 100mm blade diameter fixed pitch helicopter followed by a 100mm collective pitch helicopter would be something WL-Toys could do. Sell at half the price of the 190mm V911 and sell twice as many too.
I need something smaller for indoor winter flying that flies as good as the V911. A v929 RTF is on the way, could be interesting flying it indoors.
Old Sep 11, 2012, 02:34 PM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Id love something at the size of a mini/genius and something around the 150-250 size that could handle wind better. Living at the coast really has it downsides.
Xermalk is online now Find More Posts by Xermalk
Old Sep 11, 2012, 02:40 PM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Order yourself V939, this is INTERESTING indoors !!!
shafter is offline Find More Posts by shafter
Old Sep 11, 2012, 03:13 PM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Got my v929 yesterday...was doing flips and rolls with the tx set on #4...awesome....I even bound one of my v911 to the v929 tx and set on #4, my v911 flys like it is on steroids....
Jake8131 is online now Find More Posts by Jake8131
Old Sep 11, 2012, 04:03 PM
Jasen40 is online now
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
I want one I would settle for a Super FP clone or solo pro 129 clone.
Jasen40 is online now Find More Posts by Jasen40
Old Sep 11, 2012, 04:13 PM
Joined Jun 2012
I would think a stiffer flybar would be more pron to breakage with a side crash.
Old Sep 11, 2012, 04:35 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
I am saying that you fly the helicopter into the flybar. Then to avoid flybar strikes, you stiffen the flybar. This stops the helicopter from tilting into the flybar more than is stops the flybar from tilting into the helicopter.
My very first Yellow V911 flight had about 30 flybar strikes and punched a hole in the canopy. The next flight only had a few strikes. Now I get only the occasional Yellow V911 flybar strike. I did not change the Yellow V911, I changed the way I fly it.
Change the flybar and you change the way the helicopter flies.
Change the way you fly the helicopter and there is no need to change the flybar. Flybar strikes are telling you that you are over-controlling the helicopter.
I agree whole heartedly.
At any point in time, the flybar weights want to stay in the plane they are rotating in. The link arms cause negative feedback on the control surfaces.
With the wet noodle, the flybar bends and has less negative influence, allowing you to force the canopy into the flybar.
If you stiffen the flybar, you increase the negative feedback and you can't force the canopy into the flybar.
While you may be saying, "hey I can use more control stick with the stiffer flybar and not have a canopy strike", I contend that it is because the stiffer flybar decreases the control authority that you can apply.
The wet noodle will teach you to be a smoother, better pilot.
You won't be doing things that require high negative feedback - i.e. won't be relying on the stabilizing flybar to save you from yourself.
As you get better, remove the weights...
RicksterRC is offline Find More Posts by RicksterRC
Old Sep 11, 2012, 05:12 PM
SamNo3D is offline
Find More Posts by SamNo3D
Joined Jul 2012
Just had a tail motor die in flight. How can I tell if it is the motor or control board? Also, where can I get a replacement the fastest?
SamNo3D is offline Find More Posts by SamNo3D
Old Sep 11, 2012, 05:42 PM
Joined Sep 2007
First, look at the FET on the board (lower right on PCB as viewed from the front).
The one I burned out (tail rotor stuck), burned itself up completely.
It left an obvious smoldering crater on the PCB.
Unsolder the wires from the board and touch them to a battery.
An AA might work (haven't tried it).
With the LiPo, it will run real fast... so be ready.
I wouldn't run it full out for long.
Or I guess you could swap the motor wires on the controller board and spool things up.
If the failure goes with the motor, it's the motor, if not, it's the controller.
Old Sep 11, 2012, 05:44 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
I blow at the tail rotor to make it spin. If it keeps turning smoothly for a long time, then the motor is bad - presumably the brushes are gone and nothing to stop it from turning.
If you never did it before and do not have a good one to compare to, then not much help.
Look at the Printed Circuit Board (PCB) where the tail motor wires are connected. Gently bend the wires near the PCB with a toothpick and see if they flex too much, as in a broken wire.
Look at the PCB around the tail motor wires for crispy creatures. Smell that area for smoke.
No visible damage means you cut the wires at the tail motor, scrape enamel off, and touch those wires to a 3.7 volt battery and see if the motor works. Leave enough wire on both sides of the cut. If the motor is bad, replace it and solder to the old wires. If the motor runs, then there is enough wire to solder back again.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
