Old Sep 08, 2012, 04:13 PM
UB6uJ is offline
Find More Posts by UB6uJ
Joined Jul 2012
binding v911 to th9x
i bought a fs-th9x to use with my v911's. yet, i'm not sure how to bind my v911's with it. not really sure what the fs-r8a receiver thing is either.
anyone know how i get my v911's to bind with this th9x? should i post this somewhere else? thx
UB6uJ is offline Find More Posts by UB6uJ
Old Sep 08, 2012, 04:25 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
First you need to set up a model for the V911 before you do the binding. If you don't it may power up the main rotor and try to fly away on its own because the throttle on the V911 needs negative trim on the 9x. You might be able to manually set maximum negative trim on the 9x without setting up a model but I haven't tried that.
To bind:
Turn your 9x TX off, put a battery in the V911 then very quickly turn on the 9x while holding the bind button on the back of the radio (kind of tricky to do). Keep holding the bind button it until the V911 goes to a steady slow flash or solid. Then turn off the 9x and the V911. Now turn on the 9x like normal (do not press the bind button) then put a battery in the V911. The V911 should eventually go to a solid light and you're all ready.
LittleMo is offline Find More Posts by LittleMo
Old Sep 08, 2012, 04:28 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
If you have a yellow or complete white v911 (clone of clones) you have to repeat the bind procedure before every flight.
But that's not a big deal
mystman is offline Find More Posts by mystman
Old Sep 08, 2012, 04:34 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
How does that work? Do you have to not power off the V911 after doing the binding? Then just power cycle the radio?
Old Sep 08, 2012, 05:57 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Originally Posted by KKDDMM View Post
Today I found NEW version of V911.
WL-TOYS change connector of battery.
Anti-rotation pin moved. Means new swashplate too. This is radical change in how servos control the blades.
Mixer arm is reversed. Flybar is reversed. Blades are reversed. Blade rotation is reversed. No old parts will work on this thing.
Maybe all changed, or a fake, or very much doctored up photo. For left handed flyers?
Ribble is offline Find More Posts by Ribble
Old Sep 08, 2012, 06:14 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
this is probably just a printing error due to the usual "airtight" QC over there - when theř had the new boxes made, someone used the old picture but accidentally mirrored it before giving it to print ... why else would it STILL say CORTER on there, even though it is COPTER now for a VERY long time and these changed smaller boxes must have been printed LONG after the "CORTER episode" ...
Old Sep 08, 2012, 06:21 PM
Bvc is offline
Bvc
Find More Posts by Bvc
Bvc
United States, TX, Houston
Joined May 2012
The image was "Horizontally Flipped".
Regular
same image Horizontally Flipped
Notice the tail motor is flipped as well. Hey.....so is my kitchen.....
Good eye though Ribble.
Bvc is offline Find More Posts by Bvc
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
On my latest Yellow V911's, transmitter always has to be turned on after helicopter battery is plugged into helicopter. That may mean turning the transmitter OFF then ON.
Old Sep 08, 2012, 06:22 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
So flip the image again and post that!
Old Sep 08, 2012, 06:25 PM
Bvc is offline
Bvc
Bvc
Joined May 2012
Here's what's in the box.
http://static.rcgroups.net/forums/at...IMG1791_R8.jpg
Old Sep 08, 2012, 06:26 PM
Bvc is offline
Bvc
Bvc
Joined May 2012
It would be the original again.
Old Sep 08, 2012, 06:29 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Heh, sometimes you have to be careful with the V911 being on first. Depending on the state it was in sometimes the throttle will kick on while the 9x is booting until it loads the proper settings. This may only affect newer 9x radios because the rumor is they modified the TX module. It does affect my Turnigy 9x I just got.
It doesn't always do it and it seems that maybe if you just did a bind it won't do that. It's something watch out for though.
Old Sep 08, 2012, 06:32 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
If they reversed the blade spin direction, then they would have to put the tabs on the right skid.
OK, OK, OK. Take a look at your V911 box if you have one.
Old Sep 08, 2012, 06:33 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
I don't have a 9x
Old Sep 08, 2012, 07:10 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
I don't have a 9x
Well we were talking about the 9x ya know.
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
