Old Aug 31, 2012, 11:51 AM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
The 3mm and 5mm have focus beam so they can be pretty bright. In that case, I agree with your statement.
The smd LED are nice because they are light weight and have very good wide angle.
All our get togethers here in San Diego are at night at the park. (Kids are down so the guys can be kids again. ;D) We still fly it hard and as fast as we can...and the LED does wonders for orientation. Even with the full baseball diamond lights on to illuminate the field. Just my personal experience.
Cheers-
P.S. Often times, at night...without the thermals...it's much more calm for outdoor flight. Just gotta contend with the poor visability.
Daryoon is offline Find More Posts by Daryoon
Old Aug 31, 2012, 12:13 PM
enea 54 is offline
Find More Posts by enea 54
enea 54's Avatar
Italy, Tuscany, Follonica
Joined Jun 2012
Originally Posted by cgpirre View Post
For those that also want to add leds to their aircraft, dx.com has a good selection of smd leds and cheap resistors. I just bought 200 leds (red, blue, yellow, white, 50 of each) and a selection of 400 resistors for about $12.
And banggood even has a package of 2500 resistors for $14 but they don't sell smd leds.
I would like a flashing LED SMD are for sale?
enea 54 is offline Find More Posts by enea 54
Old Aug 31, 2012, 12:29 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Don't buy too many flashing LEDs. Looks cute on the ground, but flying in the dark with high beam and no beam on and off twice a second will blind you.
Even alternate blinking red/blue will drive you nuts making orientation very hard.
Hardest part with my night flying is finding a place dark enough. Lights on the horizon interfere with helicopter lights.
And take some duct tape along to cover the LCD screen on the V911 stock transmitter.
Ribble is offline Find More Posts by Ribble
Old Aug 31, 2012, 12:37 PM
enea 54 is offline
enea 54's Avatar
Joined Jun 2012
I wanted one for v911 tail, I put red SMD stable and I wanted to put the red and green navigation lights, but two
equal confuse
Old Aug 31, 2012, 12:43 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Yea, I have only my tail flashing. One white 805 in the canopy to light up the canopy. 0603 smd red/green for each side. And a 0603 white flashing for the rear.
Old Aug 31, 2012, 01:24 PM
enea 54 is offline
enea 54's Avatar
Joined Jun 2012
oh yes I also want to do smd flashing where to buy them?
Old Aug 31, 2012, 03:07 PM
cgpirre is offline
Find More Posts by cgpirre
cgpirre's Avatar
Belgium
Joined Dec 2011
Oh man, I just noticed that the leds I ordered are even -tinier- D:
cgpirre is offline Find More Posts by cgpirre
Old Aug 31, 2012, 04:21 PM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
0805 is the minimum size i can work with
For "first timers" with SMD LED i recommend 1206 size diodes and resistors !
shafter is offline Find More Posts by shafter
Old Aug 31, 2012, 06:12 PM
maxs0201 is offline
Find More Posts by maxs0201
Joined Jul 2012
Instead of charging the batteries from the transmitter, or instead of charging the batteries with the USB plug to my computer, do you guys think it would be okay to charge the batteries with the USB cable into a wall USB adapter? Like a Samsung Phone charger, but take out the phone cable and insert the heli cable. I tried it for 10 seconds and plugged in the batteries. The lights turned on, so I know it works. It's just the voltage I'm scared will hurt the batteries. Any ideas? Thanks- Max
maxs0201 is offline Find More Posts by maxs0201
Old Aug 31, 2012, 06:19 PM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Perfectly fine ... I use one all the time. You can get them off Amazon for a few bucks. The USB adapter puts out the same voltage as the USB port on a computer. It just uses 120vac from a wall outlet ... otherwise the DC output is the same.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Aug 31, 2012, 06:20 PM
dway is offline
Find More Posts by dway
Joined Mar 2007
It will work just fine. I have been plugging mine into my iphone charging block since I got it several months ago and it works fine.
dway is offline Find More Posts by dway
Old Aug 31, 2012, 06:21 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
That is the only way I charge because my computer doesn't supply enough USB power. It takes a long time to charge them off the computer. My wall/phone charger only takes a fraction of the time. I believe some Mac's and newer PC's supply the higher current over USB so they would probably be faster as well.
Voltage is the same, USB only supplies 5 volts, it's in the spec. It's the amount of current that changes and that is negotiated by the devices.
LittleMo is offline Find More Posts by LittleMo
Old Aug 31, 2012, 06:40 PM
JCMorgan is offline
Find More Posts by JCMorgan
Krueminator
United States
Joined Apr 2012
How is Banggood with shipping? Is it just like it sounds.....a slow boat from China?
JCMorgan is offline Find More Posts by JCMorgan
Old Aug 31, 2012, 06:49 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
As far as my personal experience goes: YES!!
(practically never got anything from them in less than 3weeks ... most times more than that ...)
Old Aug 31, 2012, 07:11 PM
MWShelton is offline
Find More Posts by MWShelton
USA, NC, Winston-Salem
Joined Nov 2009
With Bangood allow two weeks, sometimes a day or two sooner, sometimes a day or two later. I live on the East Coast if that makes a difference. I've always had good luck with them. Just got two more V911's in from them today. That makes 6 LOL. One of them is going to my son. I have no idea how many hrs or flights is on my first one and I'm still flying it. I havent oiled it, repaired anything, not even replaced the blades and I'm an inexperienced pilot. Buying the FSTH9X does make it a little better,other than that, no mods. I bought two yellow ones and I'm flying one of them some. Cant tell you how many expensive micro heli's I have. They're just shelf queens. I'll get one out every now and then and struggle with it in my small place indoors, just makes me appreciate the V911 that much more.
MWShelton is offline Find More Posts by MWShelton
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
