Old Aug 27, 2012, 07:42 PM
Bvc is offline
Bvc
Find More Posts by Bvc
Bvc
United States, TX, Houston
Joined May 2012
Originally Posted by RoboHeli View Post
My this thread moves fast.
So how about it, folks? Is adding a paddled flybar the best thing I can do in order to improve outdoor performance? Or is everyone happy flying theirs stock?
Stock. I don't like the way paddles handle at all.
Bvc is offline Find More Posts by Bvc
Old Aug 27, 2012, 07:45 PM
Bvc is offline
Bvc
Bvc
Joined May 2012
Originally Posted by zippiz View Post
Now to the second one, as soon as it binds the left servo (aileron?) just go to the lowest end position and wont move at all. The right one, and the throttle seems to work fine.
This is rev 05, or 06 (hard to tell, half text is missing).
Any idea what could be the problem and is there anything I could do to help my new little friend?
http://www.rcgroups.com/forums/showp...ostcount=10966
Old Aug 27, 2012, 07:46 PM
TapouT21 is offline
Find More Posts by TapouT21
Don't Drink & Fly
TapouT21's Avatar
United States, OH
Joined Jun 2012
Originally Posted by Ribble View Post
My wind-surfers are all stock. Fly only low rates with transmitter Elevator trim full forward. Four using new version carbon shaft and swashplate.
Once in a while I fly the one with MSR paddles on a stock flybar though it is harder to fly and doesn't do anything for the way I fly.
One has a 9958 main motor which is promising as the bigger pinion gear wants to make the blades spin faster.. Still testing it and slowly trimming the trailing edges of the blades which increases rotor RPM.
You use low rates in the wind? I never use low rate outside unless a mistake.
Guess I would have to try it and see what it does, I don't like low rates outside at all, but never tried trimming forward all the way either. I love fast windsurfing though now that I stopped flybar strikes. Sometimes I am graceful and strikes don't happen anyway, but sometimes I go fast and hard, then they were a constant occurrence.
What are you doing to trim the blades? Like how much etc...
I don't either. Didn't get to use them much before they broke on a hard crash and still plan to try again and see if I can tune it in better. But most flying is best without paddles in my opinion.
TapouT21 is offline Find More Posts by TapouT21
Old Aug 27, 2012, 08:00 PM
Bvc is offline
Bvc
Bvc
Joined May 2012
Originally Posted by firstadam2k View Post
My v911 had an odd wobble its not constant if i upload a vid can the experts tell me whats up.
I've had this happen to 4 heli's. Bearing swashplate always fixed it.
http://www.aliexpress.com/store/prod...580290309.html
When severe and there's still a little wobble sometimes, adding the carbon fiber braces to the main frame eliminates it, among other things. In my case I think it was stock setup with 'broken in' linkage/buckles and sloppy stock swashplate. Add to that crashes and vibration and wobble, wobble......
BTW; check the buckles and make sure none were pushed in too far in a crash or are too loose/broken (if you haven't already).
Old Aug 27, 2012, 08:29 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Blasphemers!!!!!!!!!!!!
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Aug 27, 2012, 08:41 PM
snailshoe is offline
Find More Posts by snailshoe
snailshoe's Avatar
Canada, BC, Prince George
Joined Dec 2008
HobbyKing 6 Channel Transmitter for V911?
Hi I've been lurking for quite some time, and ended up buying a V911 BNF and controlling it with my Turnigy 9X. Incredible fun until I lost the screw holding my flybar on while flying I was reading about how the 9X is great with all of it controls and settings and read how someone is making a 9X clone to use inside the V911 transmitter. That got me thinking about the HobbyKing 6 channel transmitter that has software that allows you to make mixing changes, etc. The 9X works with its receiver, so I would assume the HobbyKing would be able to bind to the V911. I don't know too much about this transmitter, but it looks like it would be a cheaper, more accessible option for the V911 than the 9X.
Does anybody know more about this? Do you think it would work?
snailshoe is offline Find More Posts by snailshoe
Old Aug 27, 2012, 08:56 PM
TapouT21 is offline
Don't Drink & Fly
TapouT21's Avatar
United States, OH
Joined Jun 2012
lol Did you read what all I wrote? ...."Didn't get to use them much before they broke on a hard crash and still plan to try again and see if I can tune it in better."....
Old Aug 27, 2012, 08:57 PM
MWShelton is offline
Find More Posts by MWShelton
USA, NC, Winston-Salem
Joined Nov 2009
I have a FlySky9X and it works great, supposedly its the same radio as a Turnigy. I got mine on sale a few weeks ago from Hobbypartz for $75. Here's FlySky's new version of the 6 ch. http://www.hobbypartz.com/79p-t6-6ch-radio-lcd.html I wouldnt be scared to buy one. If I hadnt already bought the 9 ch I would be buying one now. If FlySky or Turnigy were using a different 2.4 system from the 6ch to a 9ch they would have to come out with a new line of recievers, which as far as I know they havent.
MWShelton is offline Find More Posts by MWShelton
Old Aug 27, 2012, 09:19 PM
MC808 is offline
Find More Posts by MC808
My Corter Is Borken
United States, OH, Newark
Joined Jun 2012
I did manage to fly two batteries outside just before sunset, and it was nice but the helicopter starts of going forward pretty good but after a few meters almost halts... is this "normal"?
Mine sometimes does too, though I attributed it to the wind. Maybe it isn't?
MC808 is offline Find More Posts by MC808
Old Aug 27, 2012, 09:28 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
More throttle.
LittleMo is offline Find More Posts by LittleMo
Old Aug 27, 2012, 09:32 PM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
@TapouT21 & MassiveOverkill :
LOL you guys. Okay, well I just tried making my first set of paddles. I clipped the ends off of a stock flybar and shoved the Xtreme MSR paddles onto it. It's certainly a fiddly process to (a) get them on so that they're balanced and (b) get them so that they track in the same plane. The plastic for the flybar is really flexible so I'm afraid I'm going to break it while I monkey with it.
I did an initial test with the flybar (unglued so I just hovered--and I wore safety glasses!!!) and I could hover pretty well so I guess I kind of got it on straight. I tried monkeying with it some more after that and messed it up so I've pulled the paddles off to try again.
Still though, not too bad.
MassiveOverkill, I had a question for you regarding the SoloPro CF flybar. On your blog, you attached the paddles to the CF bar but how did you do that? I only have the MSR paddles but not the MSR Xtreme flybar so I don't have any of the mounting hardware (if any) that came with it. I don't see how to mount the MSR paddles to the SP flybar. Any advice?
RoboHeli is online now Find More Posts by RoboHeli
Old Aug 27, 2012, 09:35 PM
MC808 is offline
My Corter Is Borken
Joined Jun 2012
Back on the topic of the FSTH9x/Turnigy 9x, there's ztoons and daryoons posts that have some info, and the odd post here and there amongst the many many many many...many pages in this thread, but....
Perhaps people (JWShelton, I'm looking at you ) could post their successfull settings and tips, provided they differ from Daryoons and ztoons posts (and point out that they don't differ)? Just had a thought that it would be nice to "revisit" this subject and see the bulk of peoples most recent findings, settings, etc..somewhat grouped together.
If people feel this is too redundant, then that's cool, I'll understand, but be a very sad panda.
I'm just desperate to get my pretty new Tx fine tuned, can ya tell?
Here's the aforementioned posts, for referrence:
http://www.rcgroups.com/forums/showthread.php?t=1716388
http://www.rcgroups.com/forums/showt...x#post22091054
http://www.hacksmods.com/2012/08/fly...bration-howto/
Old Aug 27, 2012, 09:36 PM
MC808 is offline
My Corter Is Borken
Joined Jun 2012
Originally Posted by LittleMo View Post
More throttle.
LOL
Yeah, it's a given that we're speaking about what happens when we're already giving it as much throttle as possible for the situation.
Thing is, once it's forward momentum stalls, it's no longer nose down, so more throttle makes you go straight up. lol
Those darn people at cenn2010/banggod STILL haven't gotten back to me about their $10 offer to replace my broken BNF. One more day and I'm gonna have to look elsewhere, and ask them for a refund. I want to fly...NOW.
Old Aug 27, 2012, 09:37 PM
Joined Nov 2009
MC since I'm a relative newb it sounds like a great idea to me. I could really use the info.
Old Aug 27, 2012, 09:43 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Originally Posted by MC808 View Post
LOL
Well it's the nature of the beast when you have a flybar. It's gravity and gravity always wins.
The flybar is always fighting against your input, trying to level the helicopter. You can compensate for a while with more throttle but eventually the flybar wins and then you have to do something like change direction or otherwise get more momentum (eg. losing altitude is great for that).
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 03:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 04:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 02:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 01:26 AM
