Old Jul 14, 2012, 07:55 AM
leoski is offline
Find More Posts by leoski
Joined Jun 2012
some 911 bashing
Hey guys here is a video of me bashing my v911 around out the front of my house in slight wind, the heli is out of frame quite often but just recorded with my iphone 4s and not exactly wide angle
normally i would fly behind the tree and back but was afraid of hurting a friends nice red car.
V911 OUTDOORS (2 min 50 sec)
leoski is offline Find More Posts by leoski
Old Jul 14, 2012, 08:01 AM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Got my second V911 (black & orange) as a BNF from banggood yesterday. Only took 2 weeks to get to the US. I love the little foam "coffin" that they ship it in. The thing was practically waterproof with all of the tape and shipping labels that they put on it.
Did the skid mod so I could use my Nanotechs in it and it's good to go! Flying backwards figure-8s in my studio is such a blast with this little thing.
RoboHeli is offline Find More Posts by RoboHeli
Old Jul 14, 2012, 09:22 AM
ercapoccia is offline
Find More Posts by ercapoccia
Italy, Lazio, Rome
Joined Jun 2012
Is the bnf from banggood the last revision of the v911? Landing skid with screw?
ercapoccia is offline Find More Posts by ercapoccia
Old Jul 14, 2012, 10:04 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
E,
The dual orange/black set I just received from Aliexpress have the screw and fly very well. It only took about 1/2 to 1 turn on the steering buckles and about a 1/4 turn to tighten the flybar to eliminate a minor TBE on one to trim them both the same neutral trim on the v911 Tx. Fun little helis
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jul 14, 2012, 10:05 AM
FyreSG is online now
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Forward and reverse funnels, next.
FyreSG is online now Find More Posts by FyreSG
Old Jul 14, 2012, 10:07 AM
Bvc is offline
Bvc
Find More Posts by Bvc
Bvc
United States, TX, Houston
Joined May 2012
Originally Posted by Ribble View Post
The swashplate is at a fixed distance from the flybar pivot and can not on average move up or down on the main shaft. The links going up work opposite, one link moves up and the other side moves down, net zero swashplate movement on the shaft.
If the swashplate is moving up or down, then the main shaft is moving up or down. The main gear is moving up and down. Look for plastic burrs on the top of the maingear and possible white lines on the mainframe where the white burrs would be scraping the mainframe.
In rt aileron the main shaft moves 1/16" on one heli and 3/32 (guessing/about) on another. If I lift the shaft to remove these distances the swash will not move up the shaft and works in a 'fixed' position as it is supposed to. If I put a longer spring under the swash it works in a 'fixed' position as it is supposed to but then the flybar is not free. Doesn't the collar keep the shaft from falling? You mentioned removing the screw on the collar but.....
What is the best way to remove the play in the shaft? Or should there be 'some play'?
Bvc, a while back you posted about heatshrink tubing on the pushrods where they enter the servo arms. Is that still the case? It was not clear what you did. Could be binding
I'm sorry, I forgot to mention I removed those too.
Bvc is offline Find More Posts by Bvc
Old Jul 14, 2012, 10:11 AM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Yes. (Thankfully!!!)
As an aside, I got my original set of helis and parts from MyRCMart. I asked them (MyRCMart) about that very issue when they released the "v2" version of the skids (e.g. the one with the screw). They said that the "v1" version sold out VERY quickly. I'm guessing that the "v1" version (the "Corter"?) has moved out of everyone's stock by now. Just guessing though.
Old Jul 14, 2012, 10:14 AM
Bvc is offline
Bvc
Bvc
Joined May 2012
Originally Posted by freedomflight View Post
I'm encountering same issue, which I believe is the flybar being already spinning in the angled angle which made the flybar auto correct with respect to the angle.
Thus it will have constant row even after the turn.
Yes. I get a lot of flybar strikes in hard left bank turns and hard left bank turns is when this happens to me.
I always had trouble levelling the heli after doing a long wide banked turn.
I believe this is due the flybar already spinning tangent to the heli @ banked angle, and not spinning parallel to the ground.
Thus, the angled spinning flybar would stabilise the heli wrt to the banked angle.
If there's no stick input after the long wide turn, it would just fly sideway to the direction of the turn.
Is this phenomenal common to 45 degree flybar? Or the above is just user problem?
Originally Posted by doublock View Post
Ive had the same trouble too. this only happens when u give rudder input to one direction i believe. im not sure which, but whenever u do a banked turn with the rudder turning in the same torque direction of the main rotor (tail motor applies minimal counter acting force), this happens. Mine was all good when i gave rudder counter acting to the main motor torque.
Is this a common problem with tail motor mounted heli's? or this is just typical for all helis?
Makes me wonder about the gyro.
...and us users
Are both of you using the stock flybar? I wonder if using a different flybar would help?
Old Jul 14, 2012, 11:24 AM
eugeniorusley is offline
Find More Posts by eugeniorusley
Joined Jul 2012
How much?
eugeniorusley is offline Find More Posts by eugeniorusley
Old Jul 14, 2012, 11:30 AM
ashtodust2000 is offline
Find More Posts by ashtodust2000
Flying mostly pop-wings now.
ashtodust2000's Avatar
United States, WI, Sheboygan
Joined Dec 2011
Originally Posted by eugeniorusley View Post
How much?
http://www.banggood.com/Wholesale-Re...)-p-39473.html
ashtodust2000 is offline Find More Posts by ashtodust2000
Old Jul 14, 2012, 11:31 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Originally Posted by Bvc View Post
...snip ...
Using a different flybar definitely helps ... well, at least it did for me (quite substantially), but as usual in this "business" YMMV ...
Joined Jul 2012
thank ashtodust2000
Old Jul 14, 2012, 12:18 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Removing the screw from the ring collar does let the shaft drop. I am slowly removing the screw from all my V911's as I like having the main gear drop on clean cutting pinion teeth. Also 0.03g less weight (too small to make a difference) and now I have extra screws.
Ideally there should be no up/down play of the main shaft, though it doesn't matter once the blades generate lift.
I nearly always bank nose-left to circle around, but I make sure to have forward speed first, full left aileron (in low rates), slight left rudder. V911 does end up nose down and minor dive during turn to pick up speed. Flybar strikes if not done correctly.
Ribble is offline Find More Posts by Ribble
Old Jul 14, 2012, 02:27 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
How much?
Originally Posted by ashtodust2000 View Post
Ya. What he said.
Old Jul 14, 2012, 03:01 PM
Pancari is offline
Find More Posts by Pancari
What Do You Drive?
Pancari's Avatar
United States, PA, Folsom
Joined Jan 2012
Originally Posted by Jake8131 View Post
I have 24 helis......too many, LOL.
I like the yellow one best...flys better.
I took the blue/white one outside this evening and had a blast....after flying my msrx this was alot more relaxing....no crashes and had all the neighbors watching.
24 Heli's... is that a World Record?
I'd like to see a photo or video of your fleet. Jake. Actually, I think we should all share a photo of our fleets. My photo is found on my blog including a black, repainted, and red V911 and have a blue V911 and a V929 coming... SOMEDAY.
As someone who flies in close quarters, may I suggest pointing the camera towards the longer end of the room giving you greater coverage.
Buying a cheap table top tripod from EBay and mounting only the screw attachment to the brim of a sturdy cap will create a Hat/Cam allowing you to video anywhere.
Al
Pancari is offline Find More Posts by Pancari
New Product Jiuchon 9C002, a Solo Pro clone? SoloProFan Micro Helis 103 Feb 29, 2012 02:24 PM
Discussion Interesting Solo Pro? Clone gordonzo Micro Helis 46 Nov 30, 2011 03:15 AM
Question Which 100 sized heli after Solo Pro? Tuc Micro Helis 16 Jun 13, 2011 01:52 PM
Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! RChelisrule Aircraft - Electric - Helis (FS/W) 1 May 31, 2011 12:26 AM
