These are the paddles I used:
http://www.miracle-mart.com/store/in...oducts_id=8162 Paddles help greatly in windy conditions because the wind pushes down on the paddle closest to the direction of the wind, helping you head into it in addition to the aforementioned benefits. |
Latest blog entry: Making a Super Sized Frankenquad
http://www.ebay.com/sch/i.html?_nkw=...y+Adapter+Lead |
Latest blog entry: The WLToys V912
Latest blog entry: Change Your Perspective
![]() ![]() What's the use of having a bunch of high capacity batteries when you can't use it?
United States, PA
Joined Dec 2011
A 600mah battery will make the V911 so stable that it will not move. One of my V911's flew with a 300mah 8.24g LiPo. Very stable as I wanted to see what it does in the wind. Also very sluggish, and when you get it moving it feels like it will go through a brick wall. The maximum battery weight that a V911 can lift is about 8.5g to 9.0g. Though I think I got a V911 in the air for a second with about 10g. A 130mah V911 battery weighs about 4.60g and two 130mah batteries about 9.20g - likely won't get off the ground. A 145mah V911 battery weighs about 4.38g and two 145mah batteries about 8.76g - better, still not likely to fly or fly well. Yes, I am confusing weight with mass. Weight (ounces) is what keeps it from getting off the ground. Mass (grams) is what causes the damage when you hit a brick wall. |
Canada, ON, Iroquois
Joined Mar 2012
Well looks like I am back to playing with the V911
First flight of the big CCPM heli didn't go too well, I forgot to set my expos and while taking off I over corrected and tipped it over enough to kill a set of blades and bend the main shaft. Thats a $100 repair bill, how many BNFs could I have bought for that?![]() ![]() ![]() Still it was exciting to hear those big blades starting to thump in the air Its just too bad that this big birds aren't as tough as the little V911, they take a heck of a beating and keep on flying with little to no repairs, and if you do break something is pennies to fix it
Toronto Canada
Joined Dec 2002
Every defective motor that has been examined on these threads has shown no evidence of heat damage. The primary failure modes are brush and commutator wear which have more to do with crashes than heat damage. I have numerous micro aircraft and helis with hundreds of flights and have yet to replace a motor. It is my belief that waiting or swapping helis between flights is a complete waste of time. It fascinates me how this information persists. I hope that owners of the Chevy Volt, Nissan Leaf, Tesla and the San Francisco and New York subways are aware of this so that they can let their vehicles rest after 5 minutes of running. |
![]() Not very pretty, but works great!! |
Toronto Canada
Joined Dec 2002
For this reason, when in fast forward flight or wind, the advancing blade gains more lift than the retreating blade loses. This results in a net increase in lift. This puts a force on the blade and because of gyroscopic precession, this acts 90 degrees later and when in fast forward flight usually causes the nose of the heli to pitch up. The paddle blades can also be affected by wind. Putting pitch in the paddle blades can cause the heli to respond differently in fast forward flight or wind. On a 90 degree system, putting positive pitch in the paddle blades will help keep the heli in one place. Putting negative pitch in the paddle blades will help negate the ballooning that occurs in wind. On their earliest helis, the Germans used negative pitch in their paddle blades. I am going to have to think about the effects on a 45 degree rotor head, but I suspect that they are similar. |
Joined Jun 2012
Österreich
Joined Jul 2010
Got a "new" yellow V911 yesterday.
Do yourself a favour and don't buy this model!!!!!! I have 9 pcs of the "normal" V911 helicopters and all of them fly great out of the box. But the yellow one is a pig. It's heavy and flies - forgive me - like a pregnant cow. It's heavy and unstable, reacting like a dead fish. Also a little picky at binding to my 9x. Sorry, but that's zero points for the yellow clone-clone. |
| Thread Tools | |
| New Product Jiuchon 9C002, a Solo Pro clone? | SoloProFan | Micro Helis | 103 | Feb 29, 2012 02:24 PM |
| Discussion Interesting Solo Pro? Clone | gordonzo | Micro Helis | 46 | Nov 30, 2011 03:15 AM |
| Question Which 100 sized heli after Solo Pro? | Tuc | Micro Helis | 16 | Jun 13, 2011 01:52 PM |
| Sold $100 !NEW ARF Storm 250 (Trex Clone) With Align Upgrades, Tons of Extras! $100!! | RChelisrule | Aircraft - Electric - Helis (FS/W) | 1 | May 31, 2011 12:26 AM |
